NEED TO TURN OFF CONFIRMATION WHEN RECEIVING FAX ON A CANON 2060P
  • 1 more comment
  • denisehauser Sep 10, 2009
    There is no place to go to user tools on this machine.
    there is no way to get to user tools that I can find on this machine. What am i missing? cannot turn off confirmation of faxes that we are receiving,,,not sending. canon 2060p
    exactly what i needed. thank you
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You can turn off this feature by selecting "OUTPUT NO" from Report Settings menu. You can do it as mentioned below--
Accessing the REPORT SETTINGS Menu
1. Open One-Touch Speed Dial panel.
2. Press Data Registration.
3. Press Set.
4. Use UP or DOWN ARROW to select 2.REPORT SETTINGS.
5. Press Set, then use the UP or DOWN ARROW to display the item you want to set or
change.
Report Settings—
RX REPORT – Print a reception activity report. You can select the following options--
  • OUTPUT NO -- No report prints for document receptions.
  • PRINT ERROR ONLY-- A report prints for reception errors only.
  • OUTPUT YES -- A report prints for every reception.
REPORT SETTINGS
TX REPORT— Print a transmission report.
  • PRINT ERROR ONLY-- Print a report only if an error occurs.
  • REPORT WITH TX IMAGE--ON Print the first page of the document to remind you of what it contains.
  • OFF -- No first page is printed.
  • OUTPUT YES -- A report prints for every transmission.
  • REPORT WITH TX IMAGE –
  1. ON -- Print the first page of the document to remind you of what it contains.
  2. OFF -- No first page is printed.
  3. OUTPUT NO-- Print no report, even if an error occurs.
ACTIVITY REPORT – Print an activity management report. Print an activity report after every 20 transactions.
    • ON -- An activity report prints after the 20th transaction is completed.
    • OFF No activity report prints after the 20th transaction is completed. (Default settings are shown in bold type)
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 10, 2009
  • 11,896 Answers
Under Fax Settings in User Tools, go to the User Parameters in the Key Op Tools tab and change switch 03, change bits 0 and 5 from '1' to '0'. Bit 0 disables the confirm page for memory TX and bit 5 kills the confirm for immediate TX.
  • Nate Stansfield
    Nate Stansfield Sep 10, 2009
    copy and paste this link in your address bar for directions on how to turn this off and other things you may want as well:
    www.usa.canon.com/cpr/pdf/Manuals/MF5550_FacsimileGuide.pdf
Is there a cleaning kit for the 2060P? New rollers perhaps,,, my paper jams all the time when feeding a multi page fax
Open the adf where u put in the faxes and u will see a big black roller!Try cleaning it with a damp cloth and see!Good Luck!
Apr 06, 2010 | Canon LaserClass 2060P Plain Paper Fax
User guide
If you go to this web page, you can download the op manual.
http://aaabusinesssystems.com/pdf/_2060_Users_Guide.pdf
Hope that helps...
Lbcoaster
Jul 14, 2009 | Canon LaserClass 2060P Plain Paper Fax
Turn off fax ringer - turn on phone ringer Laserclass 2060P
Hi
You can set it for manual mode.
Or set it for fax only but set the incomming ring count to more than 8 times that will give you time to answer a call before it go to fax.
Jan 05, 2009 | Canon LaserClass 2060P Plain Paper Fax
Canon LASER CLASS 2060P
we should 1st go to cannon.com download your latest driver over using cd one ok manaul is also n ther web site so do that 1st download latest driver for xp or vista whatever u may need form www.cannon.com k thx nick
Oct 06, 2008 | Canon FAX-L360 Plain Paper Laser
Alarm setting
The alarm sounds for only 5 seconds.When you receive a fax and the paper jams, the fax will be received into memory. When it has finished receiving the fax, the alarm will sound momentarily. When you remove the jammed paper, the fax will print automatically.
Feb 26, 2008 | Canon LaserClass 2060P Plain Paper Fax
Need manual for canon laser class 2060P super G3
I need to be able to change the fax # so when I fax a document that it will show the reciving party my new fax # . And or I need a Manuel for this machine
Jan 25, 2008 | Canon LaserClass 2060P Plain Paper Fax
Canon fax 2060P not recieving faxes
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Dec 06, 2007 | Canon LaserClass 2060P Plain Paper Fax
Canon laser class 2060p super g3 fax machine
The error keeps flashing and the machine will not work. The error reads, "check cover/cart". We put the cartridge in and out about 10 times and the same error message keeps flashing. the fax machine is still not working. Help!
Apr 24, 2007 | Canon LaserClass 2060P Plain Paper Fax
180 people viewed this question
jasbo
jasbo
