Question about Canon PIXMA MX310 All-In-One Printer
I have a mp310 and both ink lights are blinking and it is not allowing my to make copies. Help (There is a new ink cartridge in the unit)
    Genius:
  • 1,043 Answers
If you have installed a generic ink cartridge the printer is not recognizing the circuit board on the ink. If they are genuine Canon cartridges they might be defective. Try uninstall and reinstall the drivers. If this doesn't solve the issue then you may have to swap out the cartridges.
Posted on Sep 10, 2009
Cannon MP990 C610 error
Inkjet cartridges dry up very soon. You have to use it everyday. Or clear the nozzles using hot tap water soak. Or try new cartridges again.
Apr 03, 2012 | Computers & Internet
Show e on copies and check ink cartridge light is blinking with new ink cartridge
With "E" ,check cartridge LED which is blinking mono or color replace it, or else check paper LED if its blinking check for the paper jams..
Sep 27, 2011 | HP PSC 1210 All-In-One InkJet Printer
Hello, my printer is able to scan and copy but it doesn't print. Both the cartridge lights are blinking but their is sufficient ink the cartridge. Can you help? I have Cannon MP190. Thanks
If the lights are blinking for the cartridges, then there is not enough ink.
Get new ones or refilled ones and try it again.
Or there may be enough ink, but the electronics on the carts are not working, could be a short, or an open circuit.
May 26, 2011 | Canon PIXMA MP190 All-In-One InkJet...
The color ink cartridge that is " blinking " is
Don't buy Canon as they absolutely ROB you for the ink!! They are worse than ****** dealers! At least HP allows you to use non (rip-off) OEM cartridges without all the hassle! My printer will be thrown out after the ink runs out as I will not be ripped-off by Canon again!
Apr 30, 2011 | Canon Pixma MG5220 InkJet Printer
`HP Deskjet F380 All-in-One Printer-Scanner-Copier E light is on seeming to refer to an ink cartridge issue. I installed new black and color ink cartridges. Light is still on and printer won't make...
Issue: Print Cartridge light is blinking
NOTE: In addition to the blinking light, an "E" might appear in the Copies area.
Solution
Close the print cartridge door.
Cause
The print cartridge door is open.
Oct 28, 2010 | HP DeskJet F380 All-In-One Printer
Colour ink cartridge empty but the on off light and red ink light flashes alternately and the carriage will not move to allow access to remove the empty cartridge.
hello, are you sure its not the error light that is blinking alternately with the power light, or is ink light indicator blinking , and just the power light blinking. i would first problably pull the power cord. then plug back in, and try again. the alternating error light and power light would be inkjet service, maint or waste pads are full, as far as the other error, i looked it up, and that error not coming up, unless there is something else going on. maybe cover for ink cartridge is caught, and not allowing printer to cycle.
Oct 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
Blinking check print cartridge light and "E" for copies
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 19, 2010 | HP PSC 1410v All-in-One Printer
The oclor light is blinking and check ink cartrige
You must need color cartridge. this printr all cartridge require for detect ink cartridge. If one is not detected that there is no cartridge. the printer does not work.
Thanks
Sk. Abdus Sabur
Nov 30, 2009 | HP Photosmart C3150 Printer
Canon mp160 error
E5 means one of three things.
1. The ink cartridges are not installed
2. The ink cartridges installed are not compatible
3. The ink cartridges are not installed correctly.
Are you using genuine Canon or a copy cartridge? If copy then they may not be correct. If they are genuine Canon you may need a new printhead.
Nov 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
old marine
old marine
