Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
HD Picture is slightly blurred
I just installed a brand new Sharp LC37D62U with a Comcast HD top box...
the color is good but the images are slightly blurred instead of crystal clear. Also, the contrast is too deep although I"ve made manual adjustments. I'm pretty sure that the connections are correct and secure (there aren't too many choices)...
  • Anonymous Dec 12, 2007
    Yep, same issue. Blurred faces -- I suspect it has to do with the slow response time and the 60hz refresh rate (120hz is the best -- I hear).
  • 103 Answers
SOURCE: Sharp LC-37D4U 1080i picture problem
have the cable company set the box to 720p whic is the native resolution of the set.this will help with quick signal adjustment
Posted on Mar 22, 2007
SOURCE: 52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Posted on Nov 19, 2007
Highdefjeff
  • 124 Answers
SOURCE: Sharp Aquos LC-65D64U Picture Quality
You need to change your TV's settings and enhancements. Directly from the store and out of the box, the settings are adjusted for easiest sell in the store. That means that:
Your contrast is cranked to 100. Move this down to 50 to 60.
Your brightness may also be cranked up high. Lower it to a level nearer the middle range but not so dark as to lose detail in the shadows.
Your TV is set on "Dynamic" or "Vivid" mode. Pick "natural" or "normal" or standard.
Your sharpness is at least on, if not cranked up. Turn sharpness down or off, and the same with "Edge Enhancement" and "VSM", all to off.
Lastly, I bet you upgraded size and you are now sitting too close to the TV. Roughly, if you are sitting closer than 130 inches (about 11 foot) you might do some rearranging or save some money and get a smaller TV.
Posted on Apr 08, 2008
SOURCE: SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Posted on Jul 09, 2008
SOURCE: Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Posted on Mar 17, 2009
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Cracked LC37D62U LCD TV
It is broken,The outside is a Polorised film.Like window tint,It is repairable,New LCD screen.But may be cheeper to buy a new TV. GET A EXT.WARENTY!!! will not cover accidents but the new tv's do break alot,and are expensive to repair.
Buy a name brand, NOT RCA "junk" Just a name
no longer a company. Samsung,Panasonic,Sony. If you want to support the USA buy another Sharp. Still a great TV. And made in America. NOTE they make after market screen protectors. GOT KIDS? GET ONE. :) Or even a piece of plexie glass if cash is tight. Hope this helps.
Oct 25, 2009 | Sharp LC-37D4U 37 in. LCD Television
Blurred color images
I'm not sure of what brand and/or model you have, but most have a maintenance mode to do color alignment.
Jul 16, 2009 | Office Equipment & Supplies
New vizio 26'' hdtv seems sharp from a distance, but pixalated and
it is important to understand the difference in digital cable and high def. high definision is on a fiber optic display alwing milions of pixels per square inch on your tv. the resolution effects your fuzzy picture you are recieving . the only real way to fix that fuzzy dull picture is to get a HD box from your cable provider and an HDMI cable to conect it to your HD TV. this is the only connection you will need for picture and top line sound. In the end the fee is usually $9.95 or less a month and it is well worth the difference in quality of TV viewing.
Mar 16, 2009 | Vizio VA26L 26 in. LCD HDTV
Figuring out the TV channels for Comcast using the Sharp remote
Unfortunately there is no listing. I suggest taking a little time to sit next to the television with an notepad to go through each channel one at a time to label what stations come in on what channel numbers. Sorry.
Jan 09, 2009 | Sharp LC46SB54U 46 in. LCD TV
Cannot optimize picture width on new flat screen HD
On your cable box remote press the hd zoom button. I have comcast cable box and it worked for me.
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
WD-52525 too much green and picture is not clear...what can i do to fix it
. Suspect the FMT PCB part # 930B924002. Supect the DM PCB part # 934C116002 if green tint
Aug 04, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
69 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
