Question about Singer Sewing Machines
Singer model 20 threading how to? - Singer Sewing Machines
  • 8,197 Answers
You can get the manual here on how to thread.
http://www.singerco.com/accessories/manuals.html
Posted on Sep 10, 2009
Testimonial: "Don't know yet,they may not have it..thanks."
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
e-Guru
  • 3917 Answers
SOURCE: top thread not picking up
You need to adjust the thread tension of your machine.Please check this link for the owner's manual of the machine and ccheck on page 14 to adjust the thread tension:-
http://docs.google.com/viewer?a=v&q=cache:3mhkD7MPwrIJ:parts.singerco.com/IPinstManuals/20U.pdf+singer+20u+manual&hl=en&gl=in&pid=bl&srcid=ADGEEShKXZNsdSREqPS4ErGzZs4kgHL9ze5jW2EwsJWZ1GoQgEghndZdE04iR4A9xL5AoVrqfS6mLzTTnW_jP87tckVvfcbV1bL3cQu2cj_-7VTDY7ffmKXD1vJzHZF4CUQyTp-wtPGQ&sig=AHIEtbR-X6T21qSVGFdfRY5TnZ3S9VNX-A
Check as per the owner's manual that you have threaded your machine correctly. Also Remove your needle plate/throat plate and your bobbin case and clean out any lint, threads, doughnut crumbs, or other debris and clean your machine thoroughly .Also check the condition of the needle whether its bent or not. Also, make certain your bobbin is locked into position in its case and the thread is coming from the bobbin in the correct direction.Also adjust the pressure,threadin the bobbin case ,winding the bobbin as per the owner's manual.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 26, 2011
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
SOURCE: how to thread the bobbin on a singer touch and sew model # 625
how to wind the bobbin of the singer touch and sew model 625
Posted on Jul 26, 2011
  • 460 Answers
SOURCE: don't know how to thread the bobbin Singer model
Try here for an explanation.
http://www.ehow.com/how_7164323_wind-bobbin-singer-9113.html
Posted on Sep 15, 2011
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
How do I thread the Singer merritt Lock serger?
Which model is your sewing machine? There may have been several with the Merritt Lock name. The 14U44 Merrit Lock uses the same manual as the 14U44B. The manual for 14U44B UltraLock model is available from Singer here: http://www.singerco.com/uploads/download/4268b9ecf6c0ad26e8810365518e68cfea086994.pdf . See pages 10 - 17 (12- 19 of the PDF). There's also the 14U44B manual here: http://www.singerco.com/uploads/download/1292_14u44b,244b.pdf . The threading diagram is on the same pages. I'm not exactly sure which manual will help you. Additional manuals are available here: http://www.singerco.com/accessories/instruction-manuals . Enter the first part of the model number (up to any alphabetic characters). You can order copies for $15-20, depending on the machine.
I hope this helps.
Jul 18, 2012 | Sewing Machines
I need a manual for my singer 9020T, also the thread spindle, which I'm certain is listed in the manuals parts index.
Try Singer.com. I looked but could not locate one for 9020T. But if you go there you can check models from 1990 and make sure you are using the correct and full number. They will show you how to find the model number. You can also google it Singer 9020T manual and there were a lot of websites that might help you.
May 11, 2012 | Sewing Machines
Singer sew handy model 20
To get the User Guide you may have to part with $20 here.
Here's the User Guide for model 20U free download.Also,checkout your machine's complete model no. and see if you'll find on this list for a free download.
Hope this helps.Thanks!
Dec 16, 2011 | Singer Sewing Machines
How to thread a singer precision 7444 sewing machine
Have a look at the manual, you can download one free from the Singer site.
Just type in 7444 and click on search. On the next page are two options, click on free download!
The instructions for threading the machine are on page 20.
Hope this helps!
Sep 22, 2010 | Singer Sewing Machines
How to thread the bobbin on a singer touch and sew model # 625
Jun 13, 2009 | Singer Sewing Machines
Singer simple 3116 jams up every few inches
Use a SA 156 metal bobbin (buy on ebay 20 for $8.99 and free shipping) and double check your threading. Refer to your manual
Mar 18, 2009 | Singer 3116 Simple
Sewing Machines Logo
483 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
