Question about Coffee Makers & Espresso Machines
The machine Steams ok, But no coffee or hot water comes out! I turn on the coffee switch, the maker busses, but nothing comes out!
  • 57 Answers
I had this same problem with mine and was able to get it fixed. Here's what I did: There is a water pump that can get stuck from not being used for a while, especially if you have hard water.
Unplung from power & allow the machine to cool completely. I carefully took the machine apart and follow the tubing to locate the pump (mine was about 2-1/2" to 3" long X 1/2" diameter. Remove the pump, disassemble it and carefully clean all the parts. You will probably find 2 parts that are stuck together (I found a plunger & check ball that were stuck from water drying out in it).
Posted on Sep 10, 2009
Ec702 delongi is not pumping for espressor but steamer works
first perform a chemical cleaning, place the chemical in the water tank and then this hot place to make coffee, so that the chemical clean pump and piping hot water, repeat this until you spend all the water,
if not repaired you may have problem with the water pump, solenoid or inlay is great need to remove the tubes and clean them out
ramon
nomarpartsupply.com
Sep 01, 2014 | DeLonghi EC701 Espresso Machine
It busses when the water if supposed to come out.
The cable may be kinked when you pushed it back
May 13, 2014 | Coffee Makers & Espresso Machines
Bunn vpr steams everything out fill hole and nothing comes through copper tube, even after cleaning tube and head.
Fill water tank until water comes out from sprayhead, THEN plug it in it should be OK.
IF the machine keeps blowing steam/keeps boiling the water, The thermostat is defective and must be replaced.
NOTE: If you don't use the machine for a couple days, UNPLUG IT. The water will evaporate if you don't unplug it.
Jan 13, 2011 | Bunn VPR Coffee Maker
Gaggia Titanium bought new in Italy. tested it to make coffee ALL OK. tested to see if steam came out and it did. Took it on a plane with me plugged it in coffe good but steam does not come out for...
When you twist the steam knob all the way, it actuates an electrical switch. The first part of the turn just opens a mechanical valve to allow the steam or water to come out but doesn't turn on the heater nor does it start the pump. You need to turn it far enough to trip the electric switch that starts the heat and the pump.
If it still isn't working, then perhaps the switch was knocked loose when it was taken on the plane.
Oct 13, 2010 | Gaggia Titanium Espresso Machine
Hi, My machine starts the process allright. It grinds and starts brewing. A few drops comes through, then it just stops and a red light shines up. I have tried to remove some parts and cleaning them. It...
Sounds like the grind is too fine. If its (the big knob) below 8 in the bean hopper, turn it to 16. You can turn the knob to a larger # anytime but you have to be grinding to turn to a smaller #. Make 3 coffee but push the button when it starts to brew to stop the brewing until you get to the third coffee and just let this one brew. If it brew correctly then turn the knob down to a # a couple higher than you had before.
Sep 21, 2010 | Saeco Vienna SuperAutomatica Coffee...
KPES100PM Espresso Machine - will not make espresso
While I am familiar with Kitchenaid espresso makers, I am not familiar with this problem. I would suggest calling Kitchenaid Customer Service, as you will have options under your Pro Line warranty. Their toll-free telephone number is:
1.800.541.6390.
Jul 03, 2009 | KitchenAid PRO LINE KPES100PM Espresso...
No coffee.....but hot water spiggot is OK.
yes there is clogged inside its either the hose or the keypad / connection of the control is corroded.
Mar 09, 2009 | Bunn CWTF15-TC
Saeco Royal Digital Not brewing Coffee
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
Best regards
/Mirran
Oct 13, 2008 | Saeco Royal Digital Plus Coffee...
Water steams away and nothing drips into the caraffe
I had this problem too and finally found a fix for it.
I don't know if the cause of this issue is the same for everyone experiencing the problem, but the issue for me was hard water. The fix is to run vinegar mixed with water through the machine quite a few times, until it starts to run normally.
If you do have hard water issues, it's recommended that you run vinegar or citric acid through the machine about once a month, to keep deposits from building up.
Feb 15, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Coffee Makers & Espresso Machines Logo
151 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
