Question about Health & Beauty
I have a Andis AGC 2 speed clipper and it keeps shorting out
I have a Andis AGC 2 speed clipper and it has started shorting out while I am grooming, It depends on how I am holding the clipper. When it is facing down it turns on but when I hold it up or turn it on its side is shorts out. I have a LIMITED budget and I can't afford to buy new ones right now. Any other options on fixing them??
  • 191 Answers
No need to replace the clipper they are usually well worth repairing.
This sounds like a problem with you power cable they are just under £10, try moving the cable in different directions around the rubber strain relief coming out of the clipper.
Posted on Sep 11, 2009
The mounting hinge will not raise on my clippers when I push up on the button below the blade
whilst pushing the release button (latch) you must also pull the front of the blade away from the clipper.
Jul 30, 2014 | Andis Agc Single-speed Clipper Lightweight...
Blade not staying on tight
If you can pull the blade away from the clipper without pressing the blade release button then either the hook on the Latch is broken (which will mean all blades have the same problem) or the blade socket on the blade may need adjustment or replacement. Please view the part in question Latch
Mar 12, 2014 | Andis Agc Super 2-speed Clipper...
Single speed
Maintenance must be done and clean the engine
Jan 25, 2014 | Andis Agc Super 2-speed Clipper...
Moser max 45 won't cut
Most common cause will be the blades have gone dull and should be sharpened or replaced. Check that the 2 screws on the blade latch assy are tight where it screws onto the front housing, blade off to check them. 3rd thing to check is for excessive wear in the lever that drives the blades, if it is worn replace it.
Sep 15, 2013 | Andis Agc Super 2-speed Clipper...
Andis Clippers not locking
Make sure you are putting the blades on with the clippers running otherwise the blade will not locate correctly. Failing that it could b e a broken 'latch' AGC
May 01, 2013 | Andis Dog Clippers - AGP Super 2-Speed...
Problems Andis AGC 2
Sounds like it's time to replace the clippers with something much better.
Apr 24, 2013 | Andis Agc Super 2-speed Clipper...
Why is clipper over heating
Either your blades need cleaning and oiling or it's possibly a faulty armature without testing the clippers and part mentioned with a multimeter it's hard to say. Armature
Apr 01, 2013 | Andis Agc Super 2-speed Clipper...
My clipper smoked and now it wont run at all
Sounds like your motor went out. You might as well buy new clippers for the price to fix them. One thing that causes that is when you spray your coolant to not hold your clippers blade up. Keep them blade down. The coolant can run into your clippers and burn them up. You only want to use grease inside your clippers.
Jan 21, 2013 | Andis Agc Super 2-speed Clipper...
Andis clippers are shaking and loud
sometimes it is the blade and not the clipper
Jun 20, 2012 | Andis Agc Super 2-speed Clipper...
Andis Super 2 Speed AGC Clippers - The blades get very hot !
Buy some Kool Lube (Oster) or Andis Blade Coolant. Both are aerosols. Your 2-speed runs faster, so your blades heat up quicker. Check them often by touching them to your inner wrist, and spray them when they are hot. A bonus is that the sprays also disinfect! (FYI a hot blade can badly burn a pet, so make sure you keep them cool)
Apr 09, 2009 | Andis 29745 Clipper Headliner Hair Trimmer
Health & Beauty Logo
143 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
