Question about Homelite 'Yard Broom' Leaf Blower
Pull cord will not retract
Is it easy to fix the pull string on the yardbroom blower? It will not retract?
  • Anonymous Mar 20, 2014
    pull string won,t retract
    Problem Solver:
  • 3 Answers
Have to take all 3 plastic covers (housings) off to get to the spring and tie the new pull rope or change the spring. Just did mine, spring just unlatched and string wouldn't retract. Did not have to by any new parts....works great! Took me 1 hour to get it done.
Posted on Sep 30, 2009
  • 124 Answers
No it is not easy due to the way it is built. It is just as easy to put in a new piston than to repair the starter. It is virtually a complete tear down.
In the future when you are purchasing a string trimmer or blower or hedge trimmer, be sure that the starter can be removed by removing 4 screws. This makes starter repair a 5 minute $10 job instead of an hour $40 or more job. The problem is that you will not find this in most home centers or box stores. You will have to go to a full service dealer.
Posted on Sep 14, 2009
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
Pull cord broke
take the string attachment off there are 3 or 4 small bolts , maybe 5/16 take them off or it may be riveted drill them out fix cord rewind spring right ,put back on with the bolts or put new ones on , good luck easy job
Mar 13, 2014 | Toro Power Clear 621E - 38452
Blower string wont retract
you might have installed the wrong spring type, check also the stopper or the lock inside that holds the spring secure.
Jun 04, 2013 | Garden
I went to crank it and when I pulled the string it stayed out and won't go back in. How do I get the string to go back into the blower
Open the door that covers the fan. You probably have to remove one screw and it should be hinged oposite the screw. Turn the fan clockwise slightly and usually the cord will retract back in.
Mar 29, 2011 | Garden
Where to get a new pull string for blower?
Any lawn & garden outdoor power equipment dealer
Lowes, Home Depot, Menards: get a recoil rope and handle for a Briggs push mower
Nov 13, 2009 | Homelite 'Yard Broom' Leaf Blower
Won't retract the pull string
The pull cord assembly either has something jammed in there or it's busted. Take the 3 or 4 bolts out that hold in on to the top, and inspect it for damage. If there's nothing in there or it's not damaged it might have just slipped off the spring. Rewind your cord and reinstall it.
Jun 27, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Yardbroom II pull start hard to pull
put a teaspoon of mix oil into the spark plug hole, some times the metal starts to bind in the engine. keep the wire off and the plug in and pull the cord a bunch of times until it starts to get easier, if you need to add more mix directly to the hole then do it. hope this helps
Mar 28, 2009 | Homelite 'Yard Broom' Leaf Blower
The pull cord on my toro powerlite snowblower wont retract
YES YOU CAN JOE,Your recoil has come undone or the spring broke. but it can be fixed.richardm69
Jan 01, 2009 | Toro Blowers Rake and Vac - Electric...
Homelite 'Yard Broom' Leaf Blower Logo
794 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
