While trying to print a document an error message,no paper in printer.paper was present.on investigation a piece of metal about half inch across was found in with the paper.this was removed paper reinstalled and tried again, to no avail.the same error message appears,any ideas on how to rectify this problem.would be really appreciated. cheers peterm.
Printing doesnt start at top of page
Sure the paper is correctly document may be the printer thinks the paper is metric instead of inch check the printer setting
Jul 12, 2012 | Minolta magicolor 2400W Laser Printer
I was in the process of making copies, when my Epson RX700 suddenly made a loud grinding noise. It then stopped working and displayed an error message: Scanner error occurred...Please see...
There are two drives in the printer. One moves the print head (cartridge) back and forth across the paper. Check to see if the "rubber band" drive belt is slipping or broken off. There is also a roller motor which feeds the paper. This has nylon gears which can make a grinding sound if one of the gears gets stuck. Make sure there are no pieces of paper stuck in the gears.
Mar 06, 2011 | Office Equipment & Supplies
I am currently getting the message that the cartridge is jammed and there is no papaer in the printer. Theres no obstruction for the cartridge, it slides across easily manually, just jams when printing. It...
First of all please check inside of the printer. You have to look for any piece of paper, paperclip or something like this. Then, please remove your printer cartridge and try to print with another one. There is an option that your printer "FUSER FIXING FILM" is damaged and that's why the paper sticks in that place. You have to find a skilled person for further assistance.
pif
Feb 19, 2011 | HP LaserJet 1000 Printer
A one half inch strip down the length of the paper does not print. I uninstalled and reinstalled the printer and the problem continues. If doesn't show up in copy mode. I tried printing documents from...
Which model??
Open the front door and pull out the toner cartridge.
Depending on the model, there should be a slot, on the upper half of the toner cartridge. about 1cm wide, across the width of the cartridge, (L to R).
This is the laser exposure slot. Assuming this is a laser printer, you do not specify this.
Check this slot for a foriegn object or blockage, small piece of paper, etc...
Dec 21, 2009 | Lexmark Office Equipment & Supplies
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
EPSON BX300F prints a page and then shows Printer Error.
Try uninstalling your printer, rebooting the computer, then re-installing your printer. If this does not work, it will require the printer top cover to be removed for further investigation. Either take the printer to a technician to investigate, or if you want to have a go yourself, post a new comment to this effect and I will provide information on how to proceed.
Mar 07, 2009 | Epson Stylus C86 InkJet Printer
HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Sep 21, 2007 | HP PSC 2355 All-In-One InkJet Printer
24 people viewed this question
jasbo
jasbo
