Question about Black & Decker 18", 6.5a Electric Mower
B&D Belt Replacement
B&D website doesn't list this old twin-blade electric mower. Where can I buy replacement belts for this mower? It's a great little mower and the new ones are bigger and bulkier than this little powerhouse. tenlee
5 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: I have an old Black and Decker 18 electric mower
Here is the black and decker website:
http://www.blackanddecker.com/ProductGuide/CategoryOverview.aspx?cPath=1498.1670
Most the old models where 6 amps. 1/2 hp
You can get another one from ebay or craigslist
Posted on Sep 04, 2009
SOURCE: elect mower blade replacement
mower, then blade, then plastic part, then metal square washer, then nut
Posted on May 08, 2010
co7196
  • 3433 Answers
SOURCE: Cannot tighten blad for 18" Electric B&D Mulching Mower
You may be missing a couple of washers, 2 flat and one lock waasherAre all the pieces there. Sometimes it calls for a spCER
Posted on May 26, 2010
  • 6 Answers
SOURCE: need a replacement blade for a black & decker 18
you should get a blade at any hardwere store
Posted on Jul 17, 2012
How do you change a blade on a black and decker Rota-twin GR101 mower
my search shows that up as a
black and decker /flymo electric mower type
no picture on the parts list
of the rotating part being metal
two types of blade sets ...says its plastic and just clips on
is that for real ....plastic clip on mower blades
will this work
pull to the larger slot to release the old blade and back to the smaller slot to hold the new blade in place
Jun 15, 2016 | Cars & Trucks
Snapper mower 42 inch with brigg stratton vanguard 16 hp v twin engine lopes when not under load
I would start by cleaning the air filter and the spark plug, or replace both if they are old.
Aug 08, 2014 | Briggs & Stratton Garden
Changed blade belt on husqvarna cth194 had difficulty restarting engine but got it going. When blades engaged going uphill lawnmower starts to struggle and threatens to cut out. this is a two month old...
I do not think this is a belt issue, i had some problems like this, it turned out to be a fuel issue, with the fuel tank completley full it was ok, as the fuel level became lower the mower stalled, the problem was the fuel tank did not have enough fall for gravity to allow the fuel into the carb, we ended up fitting an electric fuel pump.
Aug 10, 2013 | Husqvarna Garden
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Replacement grass catch bag for Black & Decker mm600 electric mower
It appears that you will need to contact the service center as in your parts diagram, the bag is not listed. A mulching blade is listed, which doesn't require the use of a bag.
http://servicenet.blackanddecker.com/Products/Detail?isId=true&productNumber=MM600&selectedType=4882
May 07, 2011 | Black & Decker 19" Electric Lawnhog...
I have an old Black and Decker 18 electric mower that has reached it end of life. I don't have a model number, it has two 9 or 10 inch blades with belts back to the motor. It is an old orange version. I...
Sep 04, 2009 | Black & Decker 18", 6.5a Electric Mower
Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Jun 30, 2009 | Ariens Garden
Need diagram to replace blade belt for 19hp twin turbo cool mower
You have to post the model number from under seat. Not all Craftsman decks are the same. There are 38", 42", 46" w/3 blades, 46" w/ 2 blades, 52", etc.. Better yet, Get the model number under the seat (starts with 917) and go to... http://www.searspartsdirect.com/partsdirect/index.action Then enter the model #, hit search, then scroll down to Browse Subcomponent List and click on Mower Deck. There's your diagram.
Jun 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
1957 Sunbeam Twin-Blade electric lawn mower shaft bushing
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=654762
Generic problem for all Vacuums
1957 Sunbeam Twin-Blade electric lawn mower shaft...
Posted by mower man on Jun 08, 2008
I have a late 50's series Sunbeam twin-blade electric lawn mower that I use regularly. The shaft bushing(s) on the left blade has worn out, and there's too much play for me to run it w/o ruining the machine.
It appears that the belt-run cog inside the housing is the part that is supposed to come off of the shaft to get to the bushings, but instead of a cotter pin or other fastener holding the cog in place, it looks like a rolled metal pin that may have been pressed in place.
How do I replace the shaft bushings so I can keep using this great vintage appliance!? I found a website that supplies parts for this model year, but no schematics or user manuals. Thanks!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. This website is for vacuums and you would need to contact a local lawn mower shop in the yellow pages, they are amazing about the way they can fix old lawnmowers.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 08, 2008 | Vacuums
Black & Decker 18", 6.5a Electric Mower Logo
55 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
