Question about Digital Research UNIVERSAL SERIAL BUS/USB EXTERNAL FLOPPY DRIVE P-N-P W/ CARRYING CASE (iefd) External Floppy Drive
There was a problem installing this hardware
There was a problem installing this hardware Universal serial bus usb controller the driver installation file is missing a necessary entry this might be because it was written for windows 95 or later any help with this ? my system is an amd 2200+ system make is eMachines.
system model L7vmm2 main board is km266-8235
  • eyeless master Sep 10, 2009
    xp home service pack 3
  • Robert Kitaji May 11, 2010
    What operating system are you trying to install on?
    Brigadier General:
  • 10,406 Answers
Access: www.eMachines.com
Search for your type of computer (desktop/portable),
your series (T-----), and your model-number (Txxxx)
and you'll be able to download "drivers" for your specific system.
Posted on Sep 10, 2009
Ethernet controller and Universal Serial Bus (USB) Controller - The drivers for this device are not installed. (Code 28) What do I need this for, what can't I do or what goes wrong by not having these...
An Ethernet controller is a computer processing device used to handle network communications, and Universal Serial Bus (USB)
It can be used to connect keyboards, mice, game controllers, printers, scanners, digital cameras, and removable media drives, just to name, so i think you need booth device...install the 2 device? nothing it is goon to happen to your computer..
Sep 15, 2013 | Microsoft Windows 7 Home Premium Operating...
GhELLO : I NEED TO DO UPDATED THE BIOS FROM USB PORT?
The USB ports are controlled by the OS. Try the following:
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 04, 2011 | Sony VAIO VGN-AW330J/H Notebook
USB DRIVER
You might have to re-install your "Universal Serial Bus Controllers" here is how you do that:
1.Locate "Device Manager" usually by pressing start then typing "Device Manager" into your search menu if you are using windows 7. If not then it is easily found under Control Panel.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the "Host Controller", click "Uninstall" and click "OK".
3. Repeat step 2 until all item under "Universal Serial Bus Controllers" are uninstalled then restart you computer windows will re-install everything for you.
Mar 25, 2011 | Computers & Internet
Pci simple controller comunication not installed .The drivers for this device are not installed. (Code 28)
The "missing" device-drivers could either be:
* a dial-up modem,
* a network-card,
* some serial device, e.g., some USB (Universal _SERIAL_ Bus) hardware.
Access: http://WindowsUpdate.Microsoft.com
Click "Custom" scan
When it completes, click "Optional Hardware",
to see if Windows Update is offering a device-driver.
Jan 23, 2011 | Computers & Internet
Usb ports not wokring . every thing installed when in connect the mouse.its not working . but mouse lights are on. and any other usb device connect its also not wokring.
To scan for hardware changes, follow these steps:
  1. Click Start, and then click Run.
    Note If you are running Windows Vista, click Start, and then use the Start Search box.
  2. Type devmgmt.msc, and then click OK. Device Manager opens.
  3. In Device Manager, click your computer so that it is highlighted.
  4. Click Action, and then click Scan for hardware changes.
  5. Check the USB device to see whether it is working.
If scanning for new hardware did not fix the problem, try restarting the computer. After the computer has restarted, check the USB device to see whether it is working.
If restarting the computer fixed the problem
  3. Expand Universal Serial Bus controllers.
    Note You might have to scroll down the list to find this item.
  4. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it.
  5. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers.
  6. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled.
  7. Check the USB device to see whether it is working.
Oct 24, 2010 | HP NX5000 Notebook
USB ports do not work
1.) Check your CMOS/Bios settings to see if any USB ports are disabled.
2.) If not, check to see that USB ports show in your operating system's device manager or settings. Enable them if they are disabled. Otherwise, you may need to reinstall the drivers that came with your model of notebook computer.
If using Windows XP, for example, go to Control Panel, System, Hardware, Device Manager, Universal Serial Bus Controllers. If the latter is not present and you have USB enabled in CMOS/Bios, you will need to install the drivers. If "Universal Serial Bus Controllers" is present, look within to see if they are all enabled and working properly.
If not, re-install the drivers.
3.) If the above does not work, you may have bad USB ports that will require service by an authorized repair service for your notebook computer.
Oct 16, 2009 | Dell Inspiron XPS M140 Notebook
My laptop doesnt detect USB Pen drives (sony vaio VGN-FJ 270)
Go to start->control panel->system->hardware->device manager. Expand Universal Serial Bus controllers. Right click on every USB root hub and select uninstall option. They will be reinstalled on next restart.
After that plug USB pen drive to usb port - go to start->control panel->system->hardware->device manager. Click Universal Serial Bus controllers then click on Action tab (the one at the top of Device manager window and select scan for hardware changes.
If that will not solve the issue try different USB port.
Make sure you have latest service pack installed so Windows would install proper drivers for the device.
Let me know if this is not solved
May 26, 2009 | Sony VAIO VGN-FJ270/B Notebook
Usb port not working
Control Panel>Performance & Maintenance>System>Hardware>Device Manager.
Expand Universal Serial Bus Controllers and click "Uninstall".
Reboot computer, Windows will report new hardware and install drivers.
Jul 20, 2008 | Toshiba Computers & Internet
Compac n6000 usb port problem
The issue could be due to corrupt USB Driver. I will give you a few steps to re-install the Drivers.
Please perform the following steps to uninstall USB Port.
1. Right-click on My Computer icon and select Properties.
2. Click Hardware tab. Click the Device Manager button and double-click the Universal Serial Bus Controllers.
3. Select a device listed under Universal Serial Bus Controller, right-click and Uninstall.
4. Click Yes to confirm the uninstallation of the device.
NOTE: Repeat step 3 and 4 until all the devices under Universal Serial Bus Controller are removed.
The USB port is now uninstalled. Now, restart the system. The system automatically detects and reinstalls the USB port.
Step 2:-
Try the following update for the USB port.
http://support.microsoft.com/kb/822603
Thanks
Rajesh
Jul 13, 2008 | Computers & Internet
Digital Research UNIVERSAL SERIAL BUS/USB EXTERNAL FLOPPY DRIVE P-N-P W/ CARRYING CASE (iefd) External Floppy Drive Logo
102 people viewed this question
Top Digital Research Computers & Internet Experts
David Payne
David Payne
Are you a Digital Research Computer and Internet Expert? Answer questions, earn points and help others
