Question about Vivitar ViviCam 3740 Digital Camera
I put 2mb card in my vivicam3740 and it keeps coming up with check the card ihave had the camera for about 4years
    Brigadier General:
  • 11,967 Answers
If this is a new card, did you format it in the camera first before using it?
Posted on Sep 10, 2009
PIR MODE SET UP
I use mine set up for motion sensitvity..this means something must enter the units field of view to be photographed..I set it for maximum distance and to take a photo every couple of minutes..I use an sd card thats 2mb yours may use a 4 6 or 8..look into the window display and see how many photos it will take..mine will do 3000 on the 2mb card..make sure the card is unlocked before putting it in the camera..and you have new batteries in it..
Jan 15, 2014 | WGI INNOVATIONS Video Cameras
While I am playing any game even mini games also like city ville in facebook or a games like asssassins creed1 or 2 the fps comes nearly 8. My cpu is very slow. Clicking any game waits for a long period...
Memory upgrade and clean out temp files for your cache memory. You need memory that is why it takes so long to load up ,also your hard drive could be failing or power supply getting weak. I would try memory first and then see if you hear any humming or weird noises coming from the hard drive or power supply.Wouldn't hurt to clean the dust out of it ,heat could be a factor as well.
Mar 29, 2011 | Intel Pentium DualCore E5500 28GHz 800MHz...
I have coolpix 950 and old 128 kb card broke so I put in a 2mb card camera wont work on this card , also 'error' comes on screen
In addition to Nikon's EC-CF series, the COOLPIX 950 may be used with the following CompactFlash Cards: • SanDisk Corporation's SDC-FB4/8/15/30/40/48/64/96 • Lexar Media Corporation's CF016/032/048/064 4× USB, CF016/032/ 048/064/080 8× USB and CF128/160 10× USB
Oct 06, 2010 | Nikon Cameras
Does not work with 8mb memory card. Why not please? Canon A540. Problem occurs when change a 2mb card for a 8mb card. Have not tried anything to fix problem
The A540 is designed to work with SD cards. Your 8GB card (I assume you really mean gig, not meg) is actually an SDHC card (SDHC stands for Secure Digital High Capacity). While SDHC cards will fit into SD slots, they will not work in SD devices. You need to keep using SD cards, 2GB and smaller.
Aug 23, 2010 | Canon PowerShot A540 Digital Camera
I have a kodak easy share c530.ihave inserted a new memory card and it keeps say Memory card requiers formatting,ipresse continue to start the formatting but it keeps giving the same message how do iformat...
The lever on your card might be turned the wrong way. Pls. readjust and try again.
The card might not be supported:
You camera Memory card support : SD/MMC up to 1 Gigabyte
Good luck pls. rate me and/or recommend me if helpful
TXS
Nov 28, 2009 | Kodak EasyShare C315 Digital Camera
Put new SanDisk 4GB card in Canon A620 and get Memory Card Error
The A620 came out in 2005, before the SDHC (high capacity) protocol had been introduced. The A580 came out in 2008 and is compatible with the SDHC protocol. The A620 is only compatible with the SD protocol, and maximum capacity under this protocol is 2MB.
Aug 27, 2009 | Canon PowerShot A620 Digital Camera
What sized memory card can I put in my Canon Ixus 750, I put a 4G card in and it doesn't recognise it!
This camera is specified for SD and MMC cards. SD cards are available in capacities up to 2MB. If you have a 4MB card, it is probably an SDHC (high capacity) card, which uses a different protocol than the original SD card. So the answer is 2MB, but it must be an SD card, not an SDHC card.
Jun 16, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Stops taking pictures after approx. 128-130
Hi, Sue,
Not really sure on this, but if where he bought cam will take it back,try it...
However, it may not be the cam, but different resolution settings on the two different cams. Digital cams by different manufacturers format SD cards using different means; some allow more memory space on card for formatting than others..and if the game cam is set at a higher resolution than the other cam, then the 2nd cam might use space 1st cam left avail.i.e., say cam "sets aside 4mb of memory to format card, but only uses 2mb of this space. Now, the game cam is set for high resolution and take 130 pics @ 15mb each..15x130=1950mb,+ 2mb left by game cam=1952mb(1.952gb), or about 50mb of space left on card...put it into cam set for lower res. and might get several more pics before card was really full...be sure all is equal...both cams, and card,ect. 128-130 pics @ high resolution ain't bad....on a 4gb SDHC card with my I-40's set for High Res., I can get 1000 pics;@ enhanced and I get only about 300. Set at low res., and # goes way up.Hope you understand all this.
ron
Mar 11, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Memory card problems
C-Series : Optical zoom lens cameras with sliding lens cover Product name xD-Picture Card *1-7 SmartMedia
3V(3.3V) CompactFlash Type M+ / M Type H Standard C-990ZS - - - X
2MB - 128MB - C-990 ZOOM - - - X
2MB - 128MB - C-960 ZOOM - - - X
2MB - 128MB - C-920 ZOOM - - - X
2MB - 128MB - C-900 ZOOM - - - X
2MB - 32MB - C-500 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-480 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-470 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-460 ZOOM X
256MB - 1GB X
256MB - 2GB X
16MB - 512MB - - C-450 ZOOM X
256MB - 512MB X
256MB - 512MB X
16MB - 512MB - -
http://www.olympusimage.com.sg/pr/notice/1176786_707.html
check up at this website
Sep 22, 2007 | Olympus Camedia C-450 Zoom Digital Camera
Vivitar ViviCam 3740 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
