Question about Garden
I have a craftsman leaf blower which has worked fine till last week when it suddenly stopped. I did a spark test...no spark....replaced the plug....no spark. What next?
  • 388 Answers
How did you do the spark test? Did you use an in-line spark tester? You need to determine definitively that there is no spark and the only way to do it is to use an in-line spark tester...you can get one at Harbor Freight for about $12. After you've checked it that way, if there is definitely no spark, most likely the ignition module is faulty. You should be able to purchase a new module through Sears Parts but bounce the cost and time of that off of the cost of a new blower...you may be surprised.
Posted on Sep 10, 2009
No spark
To test the spark you will need a spark plug tester. Put one end of the tester on the spark plug and the other in the plug wire. Pull the cord and see if fire is there. If not you will need to replace the coil.
Jun 28, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
Got a craftsman leaf blower cranks up and runs fine for about 5 mins then starts losing rpms
ITs hard to diagnose these things over the internet, it could be so many things.
Is this a gradual loss of power? If so; Im sorry to say; that it sounds like its losing compression as it warms up. It is not cost effective to repair the unit.
If the loss of power is more sudden it could be a failing ignition module. Ive even seen spark plugs that quit working when they get hot.
To test this you will need a proper spark tester, laying the spark plug against the head will not provide an accurate assesment, and a can of carb cleaner. Run the unit with the air box cover and filter removed till it fails and immediately give a shot of carb cleaner in the carb and restart. If it starts right up it could be fuel related. IF it doesnt start right up then quickly test for spark. If no spark then its likely the ignition module. If it wont run on the extra fuel and it has spark then it has probably lost compression.
Nov 05, 2012 | Craftsman 4 Cycle Blower/Vac
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
Nov 22, 2010 | Toro Craftsman 225 mph Electric BlowerVac
Won't start --has gas--has spark craftsman leaf bower
most likely the air filter is clogged, take it out blow it out or spray water through it and allow it to dry completely.
alterinavely, just pouring a small amount of gas onto the filter should make it work, i would do that even if you do clean it properly.
this method works for cars too!
Nov 07, 2009 | Craftsman 4 Cycle Blower/Vac
Craftman leaf blower when I press primer bulb I get air in line. It seems to be coming from block that choke is attached to hoses look good.
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Aug 05, 2009 | Craftsman Blower Attachment
Died and will NOT start.
I experienced a similar problem with mine and I replace the little plastic tube that is immersed into the fuel. It had some stuff in it and preventing fuel from getting to the engine. It was only about 1.50 to replace.
Jan 05, 2009 | Craftsman 4 Cycle Blower/Vac
Leaf blower wont dstart
try replacing the spark plug.
Nov 11, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
237 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
