my sony dsc h-7 refuse to record in fine mode video. where is my mistake? i expected a bit better photoes becouse i had HP m512 before and i made prety much good photoes with that camera . i'm shooting in auto mode now becouse i can't manage with all those settings and i think that something is wrong with my camera please help me
Comments:
Dec 10, 2007
- I CAN'T GET ANY HELP FROM THIS LINK THAT YOU SEND ME I'M CERTANLE THANKFULL BUT PLEASE CAN YOU SEND ME ANOTHER SOLUTION
Dec 12, 2007
- before sony dsc h-7 i had HP m-517. so auto mode of shooting is something i know about. my sony dsc h-7 when shooting makes the portrait good but the backgroun blured and i'm not shooting with portrait mode. i think that problem that i have is in the focusing. the camera focuses on a portrait but not on entire image like background and other things that comes with the portrait!!! and in landscape mode is a bit better but almost the same!!! can you send me some more professional instruction manual concreet for dsc h-7 setup but i allready have that that goes in the pakage with the camera!
- Auto Mode (7.0)
The only green icon on the otherwise cluttered mode dial belongs to the
auto mode. The simple green camera icon is an oasis for beginners who
want to avoid the camera’s many options and just shoot. In the auto
mode, there are a few options that and be customized. Image size, face
detection, burst, and red-eye reduction can be accessed in the
recording menu. On the multi-selector the macro, self-timer and flash
can be found. The exposure compensation can also be changed via the
rotary dial to easily brighten or darken the image. This mode seems to
work well in most situations.
Dec 12, 2007
- the auto mode option in your camera has the best setting for a ready to use situation , it's done by the manufacturer for customers convenient use. if this won't solved the problem just give me a feed back and i will try to give you more for another solution.
Dec 12, 2007
- DSC-H7 has only a record MPEG1 video at 640 x 480-pixel resolution at a frame rate of 16
fps. This looks very choppy, so users will want to make an extra
purchase to get a better frame rate. With the Sony Memory Stick Duo Pro
card, the frame rate bumps up to a television-quality 30 fps. Having to
make the extra purchase is a little annoying, but it’s necessary to get
a larger capacity card anyway because the included 31MB of internal
memory certainly won’t be enough.
so increase your your frame rate it can compensate too many activities regarding recording via video or picture taking in good performance and color view...
Dec 12, 2007
- using fine mode video in a recording manner uses a lot of memory because it is the activity from normal to make it fine as enhancement. in the normal mode is the manufacturers default usage using only the capacity to shot normally.
I have a Sony DSC-H7. After removing the memory card to process some photos at a local walgreens, I...
(More)
I have a Sony DSC-H7. After removing the memory card to process some photos at a local walgreens, I went to re insert it, and after I did the camera doesn't seem to read the memory card(SanDisk ProDuo 2.0 Gb). I went to the Internal Memory tool on the camera and it only shows an option to format the cameras built in memory space. I have heard these cards can just go out but I want to make sure there is no option of reformat. Thank you!
For some time now my Sony DSC-H7 often requires a number of attempts to take a photo. Sometime sit...
(More)
For some time now my Sony DSC-H7 often requires a number of attempts to take a photo. Sometime sit works first time b ut other times I need to depress and release the shutter a number fo times. From what I can tell it doesn't seem to lock on to focus but the problem even occurs with manual focus. I've tried resetting the defaul settings but that hasn't made any improvement
I cannot download my 'kb' photos to my computer......some my computer cannot read.....saying...
(More)
I cannot download my 'kb' photos to my computer......some my computer cannot read.....saying 'parameter' incorrect....what can I do as I do not want to loose my photos???
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
