Question about Sony Playstation 3 (PS3) Console
PS3 80GB not spinning DISC
My ps3 is not spinning discs but the lens works (I Think) is this problem in the lens or in the thing that spins? i have a kem-400aaa
  • 148 Answers
The PS3 sony Blu-ray drive is very sensible..you should check the drive sensors first...
Could be a defective motor that´s not spining the disc...
would be very nice to test another blu-ray laser unit...connected with your blu-ray controller board...and you wil find if the logical blu-ray board is ok..or dead..So you must have a hardware to test and prove a second opinion !!!
Good Luck !!!
Posted on Sep 10, 2009
Testimonial: "dude what i buy the whole thing new spin motor and laser"
  • Vandre Soares
    Vandre Soares Sep 14, 2009
    you should try to change the mechanical part with lens...you have to use your Blu-ray logical board...cause it´s married with your PS3 motherboard by the Firmware
Ps3 not spinning disc, replaced spindle motor, did not fix. Please help
If it doesn't spin, chances are, it's your laser. Once you replace that laser, I bet your system will recognize the disc and spin up.
This is the 2nd most common problem with PS3's. This isn't a bad problem. Your laser/lens will need to be replaced. There are many videos on youtube if you would like to do it yourself (I would advise you not to). I recommend that you find a technician who has experience. There are many things that can go wrong.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Tip
Sony ps3 won't load,start,read disc
Clean with Compressed Air
One way to clean your PS3's internal laser is to use a can of compressed air. This is highly pressurized air contained in a can with a thin nozzle on the end. It is designed to get dust and dirt out of small spaces. Cans of compressed air can be purchased at any major electronics retailer, such as Best Buy or Radio Shack. Point the can's nozzle toward the PS3's disc tray and lightly spray for a few seconds to remove loose dust from the lens.
Use a Laser Lens Cleaner Kit
Also available are laser lens cleaning kits that work with the PlayStation 3. These kits contain a disc that is inserted in the PS3 the same way you would a video game or movie. The difference is that there is no data on the disc; it is designed specifically to spin in such a way that it gently cleans that PS3's laser lens, removing all dust, dirt and smudges in the process. These kits will also work on DVD, Blu-Ray and computer disc drives, in addition to the PS3.
Maintain the Discs
One way to make sure your PS3 laser stays clean is to keep track of the discs themselves. Examine a disc before you put it into your PS3's disc tray. If there is any dust or dirt use a dry, soft cloth to gently remove them before play. Dust and dirt are easily transmitted to the PS3's laser lens as the disc spins around at high speeds in the tray. By keeping the discs clean, you can make sure you don't have to go out and spend extra money on cleaning your PS3 laser lens in the first place.
on Dec 12, 2009 | Video Game Consoles & Games
The ps3 will not read any disk that i put in the system
Sounds like your drive is bad.
Unplug from power for a min. Plug back in and try a couple different discs.
Plug back if still not working the PS3 will need to be taken apart for further inspection. If you are somewhat handy you can do your self.
Here is a vid to show how to take apart and replace lens.
Change location: Please enter a location http://www.metacafe.com/watch/2348144/sony_ps3_wont_read_fix_will_not_read_disc_repair_no_read_discs/
I would take it apart so I could see the drive, if the discs are spinning I would replace the just lens, if the disc are not spinning I would replace the disc spin motor.
If it seams to much you can replace the whole drive with a new or a used one.
Sep 14, 2010 | Sony Playstation 3 (PS3) Console
On my ps3 80gb system, the disc never spins up. I don't have a problem replacing the part myself, but I don't know what part to order. can you help. Thanks! Mike
Hi there, the PS3 blu ray is a bit of a complex device. Basically the way it work is before the disc is even spun the laser reads and detects what kind of media is inserted into the PS3. As you are saying the disc is not spinning there are 2 possible causes for this.
1. The blu ray lens has gone and is unable to read blu ray discs, hence the disc does not spin as none is detected.
2. The actual motor that spins the disc has gone. This is a much more unlikely reason, the blu ray lens is a common problem on the PS3.
As a shot in the dark you could try a laser lens cleaner but make sure it is suitable for blu ray. If this does not work you are going to have to purchase a new blu ray drive. You can get them for around £70 on ebay but you need to make sure you get the right one. Check your PS3 model number and google it to find which drive you have.
Hope this helps and thank you for using FixYa
Sep 12, 2010 | Sony Playstation 3 (PS3) Console
Ps3 games won't load. it sounds like the disc is just tryin to spin then it does play after a reset to factory settings and i have to keep reseting it before it plays every time.
No spin or slow spin is related to the lens. The lens detects the disc and spins it. If the lens is dying these symptoms occur and the only solution is a new lens. This will run you about 50-60 dollars.
Mar 28, 2010 | Sony Playstation 3 (PS3) Console
Disc not reading
If you're getting a Disc Read Error (DRE), it could be one or both of these things.
Your laser lens is dirty or broken and needs to be cleaned or replaced, or your disc tray is faulty and needs to be serviced.
Try cleaning the lens and see if it will read. If you can hear the disc spin in the PS3, then your disc tray is fine.
Nov 08, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont play games, dvds, or blurays. The disc doesn't spin??
This may be a case of replacing the laser lens. If your console is out of warranty, take it to your local Game Stop, or somewhere that does Sony repair. PSR does Sony authorized repair, but it usually involves shipping. You can contact PSR at 877-777-3491, or email at psr_repairs@msn.com. Hope this was helpful
May 09, 2009 | Sony Playstation 3 (PS3) Console
CD wont spin
You are unable to play your discs because the Blu-Ray Lens that enables the PS3 to read Blu-Ray movies or games has gone bad.
There is nothing you can do about it. You need to take it to an authorized Sony Service Center and get the lens replaced.
Apr 06, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont spin any disk what can i do to fix it
Try cleaning the lens using a cotton swab and alcohol. The disc won't spin unless the unit realizes that a disc is there. A dirty lens will prevent the system from reading the disc.
Keep us posted.
Dan
May 01, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
996 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
