Question about Matsushita (UJDCD6731) CD-ROM Drive
Matsushita drive problem
Hi there, as well as the "does not recognise disc" problem, when it does i cant seem to burn anything "burn process failed, calibration error code 011-02-3058"
Can you help?
Re: Matsushita drive problem - Matsushita (UJDCD6731) CD-ROM Drive CD Drives
Posted on Dec 13, 2007
0 characters
3 Points
Cant burn dvd
You need a dvd burner a burning program and a dvdr burnable disk to be able to burn a dvd
Burning computer files on a DVD can be a great way to backup your information.
Most one-sided writeable and rewritable DVD discs can store nearly five gigabytes of information, while two-sided writeable and rewriteable DVD discs can hold over eight gigabytes.
There are many programs available for purchase that you can use to burn a DVD.
For the sake of this tutorial, we will be using one of the most popular CD and DVD burning utilities Nero Burning ROM.
Read on to learn how to burn a DVD.
Insert your writeable or rewriteable DVD into your writeable DVD drive.
Click on your start menu and select "All Programs," "Nero" and "Nero StartSmart."
Locate the pull-down menu at the top of the window that shows "CD" displayed.
Click on the arrow to view the rest of the menu and select DVD.
Find the icons under the pull-down menu you just used.
Click on the "Data" icon. Then click on "Make Data DVD."
Click on the "Add" button when the Nero Express window opens.
Find the files on your hard drive that you would like to burn to the DVD and select them.
When you're done selecting files, click "Finished."
Select "Next" to get to the Final Burn Settings screen. If you can select the speed at which to write your disc, select the 8x option.
Click "Burn" and wait as your files are burned to the DVD. Click "OK" once the window pops up telling you the burn process was completed successfully.
List of nero programs including a free Data Backup program
There are lots of freeware alternatives on the internet
Burn audio, video, and data CDs/DVDs and create and burn ISO files.
Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner.
nero 8.1 essentials free
This is the newest version of the most known CD and DVD burning software, but now with the capability to burn HD DVDs, and Blu-ray Discs
Nero 9 .4.12 free Create, rip, copy, burn, edit, share, and upload online
Feb 18, 2014 | CD Drives
Hi I have a G640 model laptop, when I am trying to download to disc the drive seems to be making a very loud noise when the disc is being read, could you please help or offer any advice? Thanks
Does the disk get scratched when you take it out?
What is the loud noise like exactly? One continuous long scrrrr noise, or something like a tapping noise?
By download, you are referring to burning? Do the disks come out working fine and readable by other devices or computers?
You can try to put in a disk cleaner disk, such as :
You can find disk cleaner things like that in bestbuy or radioshack. I am referring to cleaning the disk drive lens, not the disk itself.
Try to use a different disk brand, and if all else fails, I suggest giving it back via warranty, as most likely it is a mechanical problem with the drive itself, in which case you would not be able to fix it yourself unless you take it apart and try to find what is making the noise, which could take a while depending on your experience with electronics.
Jun 11, 2011 | E-Machines emachines (emachinees) CD-ROM...
Can lite-on-ltn4865 48x play dvd movies
If your Drive is a CD-Rome drive, surely it cant, for the drive cant read dvd disc. Replace the drive of yours with DVD-Rom or DVD-RW in order to play dvd disc, DVD-RW simply has the added capablity to burn on DVD discs
Jan 12, 2011 | Lite On (LTN486S) Internal 48x CD-ROM...
I was trying to create the Recovery Management disk but everytime I try to burn the CD it keeps ejecting. I would really like it if you could provide some help. I recently bought this E-Machine computer...
Welcome to Fixya
Please see procedure below on how to create recovery disk. Let me know if smae thing will happen.
  • 1
    Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
  • 2
    Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
  • 3
    Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
  • 4
    Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
  • 5
    Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
  • 6
    Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
  • 7
    Set up Windows Vista with your own personal settings.
  • Thank you for using Fixya!
    Dec 04, 2010 | E-Machines emachines (emachinees) CD-ROM...
    The CD drive doesnt seem to pick up anything! you can hear it scanning but then it just stops and doesnt do anything or recognise a disc being in there
    cd works on the lazer ray i think ur ray is somewhat weak that the photo detector cant detect the light so u need to change the ray but it is better tho change the whole drive nowadaya drive are becoming cheap.
    Oct 22, 2009 | CD Drives
    Forgot password ,cant log into windows can that be bypassed
    well u need to get out the CMOS battrey from the computer and it get it back in.U will find it on the mother board.
    If u dont want to play with the hardware,u can do a recovery on the computer.
    Jun 21, 2009 | Dell Latitude C840 24X CD-R W/ DVD Combo...
    Writing DL disc
    If the drive is violently rotating, and only doing it for these discs, it may not be able to handle them. This sounds like a product issue (not the software you are using as it funtions ok with past items. Your sytem may not support double layer discs.
    Jan 23, 2008 | CD Drives
    CD RW/ DVD RW Drive Will not read and Burned discs or burn to blank discs
    I suggest a firmware update from Toshiba. If this does not help then your laser in the drive is no longer capable of this task. Also just thought about it but make sure the media that you are burning to is the same as the drive + or - R's
    Jan 22, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
    CD-ROM won't read discs
    there is no problem with the system. only you need to clean the lens using CD/DVD cleaner.
    Jan 05, 2008 | Gateway (5500778) Internal 32x CD-ROM...
    Cd drive
    media player needs configuring,select all file types.reason it wont find songs previosly burned is probably because burned as compilation and not can download a player called VLC (for free)it will play any file type a lot of which media player cant.whatever media you have it'll play
    Dec 06, 2007 | CD Drives
    CD Drives Logo
    273 people viewed this question
    Top Matsushita CD Drives Experts
    Brian Sullivan
    Brian Sullivan
    Michael Thomas
    Michael Thomas
    Are you a Matsushita CD Drive Expert? Answer questions, earn points and help others
