Question about Microwave Ovens
Mounting plate for whirlpool microwave MFG 2005 MH1140MQ2
  • 8,197 Answers
To get the mounting plate you need to contact whirlpool at the link below.
http://www.whirlpool.com/custserv/email_form.jsp
Good luck and please rate
Posted on Sep 10, 2009
Microwave turntable stopped and is now burning food
The turntable is driven by a small electric motor mounted underneath the cabinet. The motor may have failed. Also check whether the rotating plate was binding which also causes failure of the motor
Dec 23, 2012 | Whirlpool GT4175SPS Stainless Steel 1200...
Whirlpool mircowave making grinding noise
The grinding noise could be from the turntable motor, or the fan. Remove plate from oven and put a cup of cold water in, set for 30 seconds and run the microwave, if no grinding is detected it means the turntable motor is near end of life. If there is no change unplug microwave and remove top check the fan mounts tighten if loose, if straps are tight suspect the fan motor.
Jun 11, 2012 | Whirlpool Microwave Ovens
I have a whirlpool cabinet mount microwave model gh5176xpq-0 I need to remove from the cabinet. I have removed the top mounting bolts but there seems to be something else holding it.
IS THERE A PLATE HOOKED TO THE WALL IT IS RESTING ON. TRY PUSHING UP THEN OUT. IF THERE IS A CABINET ABOVE IT YOU MAY HAVE TO LOOSEN IT ALSO
Mar 06, 2010 | Whirlpool Microwave Ovens
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Matag under oven microwave
You'll have to remove and/or modify the frame & existing mounting plate as required, which may require some amount of cutting and drilling too.
The dimensions of the mount that the new one needs will be detailed in your installation instructions.
If for some reason you don't have yours, you can download Maytag (made for Whirlpool by L.G.) owner's manuals and installation instructions here.
Jun 26, 2009 | Microwave Ovens
How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Jun 25, 2009 | Frigidaire FMV156DC Microwave Oven
Wall mounting needed for a top mount microwave/hood combination Whirlpool Model MH2175SB1. The cabinet above the stove is too flimsy to support the heavy microwave (50-60 pounds). Called Whirlpool. Sent me...
Is there a wall behind where the microwave is to fit?
Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
Jan 29, 2009 | Whirlpool Microwave Ovens
Kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
Jul 01, 2008 | Microwave Ovens
Can I reuse mounting plate for new microwave?
i always reccomend to my custs that they stay with the same brand for same mounting bracket, dontreally know a way to verify other hten removing hte old micr first and then before purchasing ask to open box to check
Mar 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How can I install this oven GH9115XE?
You may be looking for this flat head 1/4 x 28 threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded holes in the top of the microwave:
GE # WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites)
or a set of three
GE # WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites)
Jan 21, 2008 | Whirlpool GH9115XE 850 Watts Convection /...
Microwave Ovens Logo
90 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
