Printing is readable but very light
I have a canon mf3110. I just put in a new toner cartridge and all the copies are coming out very light. Readable but barely.
    Master:
    Sergeant:
  • 460 Answers
Pls refix the catridge after shaking.
Posted on Sep 14, 2009
Printing very light
Try performing a stop test. Send a test page and turn it off mid print. Retrieve the page from the printer to see if the image is readable before it went through the fuser. If so the the fuser may need to be replaced.
Jan 16, 2014 | Oki Electric Industry B410D Laser 30PPM...
Printing very light Okionly B410d printer usesblack toner cartridge
Jan 16, 2014 | Oki Electric Industry C3300n Laser Printer
U051 error message. Won't print
Well, you must be using PG30, CL31 cartridge for your printer.
Did you refill your cartridge?
For error 051 means printer is not reading the cartridge. (cartridge is not readable)
When you put refilled cartridge, that's what it happens.
(after 3~4 times of color refill, color cartridge is no long to use, only applies in Canon
and there is no solution for it.)
Pls replace with new one.. and will work again.
Or if you need to refill again with other cartridge, pls....unplug your printer before you taking out the cartridge. In this way, you can re use your cartridge. Little trick... but no solution will work, once cartridge is not readable.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 11, 2011 | Canon PIXMA MP470 All-in-One Printer
My printing colour is not dark enough to be readable. I changed another new toner cartridge but the prints were still the same
Hi..
Not just the print cartridge but make sure that the "Print Head" is also working fine. ink clogging has not taken place on print head.... Print head is a hardware, on which cartridge is attached.
Hope this has helped you.. Thanks..
Sep 29, 2010 | Samsung ML 1610 Laser Printer
Need to replace drum on canon mf3110..how do i do that..printer is printing light even with new toner
The drum is replaced when u replace the toner as it is a unit!It can be the transfer roller making it light!The transfer roller is under the cart!Good Luck!
Apr 16, 2010 | Canon MF3110 All-In-One Laser Printer
Skipped Print Areas on Printouts
You may have a bad toner cartridge, if the cartridge has contaminants in it, it will not put toner on the drum in these areas, Try removing and giving the cartridge a good shake, try installing a new or at least another cartridge to see if the problem is here.
Hope this is of some help.
Ed
Apr 30, 2009 | Office Equipment & Supplies
Smasung clp 300 will not print in blk
check if your toner cartridge(s) is moving the toner supply spiral,
you can see it in hole where toner leaving bottle. (you must push the
valve in cylindrical output of cartridge inside about 20mm).
When you rotate anti-clockwise gear of cartridge, the spiral inside must rotate too.
My original toner has this broken and print was light.
You can have also bad developer unit, blade, or contacts, or printer electronic board.
Mar 07, 2009 | Samsung CLP 300 Laser Printer
Canon C100 copier
Its the drum unit that you need to replace and clean the optics-call service
Aug 29, 2008 | Canon C130F Black and White Copier
Zerox workcenter m151 when i print i only get on both sies of page light coverage not readable copy if i copy with cover open i get two solid black strips do i neeed a new drum or is it something...
Your toner is empty and just not indicating it's empty.
There is a light sensor and windows through the cartridge. Sometimes there is a little ink left on the window and it doesn't report empty.
Jul 17, 2008 | Xerox Office Equipment & Supplies
Canon PC140 light copies
Press button to print does not work
Dec 12, 2007 | Canon PC-140 Black and White Copier
63 people viewed this question
jasbo
jasbo
