Question about HP Pavilion DV6500T 15.4" NOTEBOOK LAPTOP PC
Laptop wont start without battery. its was working with battery and charger plugged in. then just died. a friend of mine has got the same laptop. if i take his fully charged battery the laptop switches on and works fine. but only as long as the battery life. if i plug the charger in it does not charge the battery.
  • Anonymous Mar 14, 2014
    In the middle of rebooting and battery died and charger won't work. How can I get it to charge without the charger. Any other way?
    President:
  • 1,335 Answers
It sounds like you have either a faulty ac/dc charger or a faulty charger jack. Have you tried using your friend's charger to see if it charges your system? This would eliminate the charger as the culprit. If this does not solve the problem, you will have to check the adapter jack on the motherboard. You can either take the laptop into a service center and get an estimate to replace (usually less than $100) or try replacing it yourself. A computer shop should carry a suitable replacement jack or you can order on online from http://www.laptopjacks.com/models/HP-12.html
Posted on Sep 10, 2009
    Scholar:
  • 146 Answers
Your AC adapter is dead. Look at the adapter after you plug it in the wall, if it is working, there should be a green LED lit on it. If this is the case and it still isn't working, you need to take a volt meter and read if there is output at the connector that plugs into the computer. Either way it looks like your adapter is defective and needs to be replaced.
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
I was working on my laptop and then it died suddenly and there was a red X where the battery was. I had my charger plugged in though. Then I tried to re-start my laptop and it clicked "start normally" and...
sound like the battery ran down and the pc is now without power, meaning the power supply that was plugged in has failed. the pc ran on battery until it ran down. try another power lead. you can get generic universal one cheaper than oem from any pc shop
Sep 07, 2010 | Computers & Internet
My power button doesnt work anymore
Mine turns on when I plug the charger into it. Have you tried that?
Jul 04, 2010 | HTC Hero Smartphone
My iphone 2g wont turn on, i replaced the lcd, it worked ok, my batter was low. so it died and i was trying to turn it on, but it wont turn on. when i plug in the wall charger nothing happens,but when i...
I have a feeling that when you ran the battery down it is now struggling to get and hold a charge.
If you have a friend with a similar battery perhaps try that, or go to a mobile store and ask them to try a new battery for you.
Nov 09, 2009 | Apple iPhone 3G
The laptop wont charge
Just because the light comes on does not mean the charger is charging. You will have to use a meter and check the actual output of the charger. The problem could be the charger , charger plug, cables or battery. Start the checks with the plugs and cables and go from there. The light can come on but no power going out to the battery.
Oct 12, 2009 | Toshiba Satellite A55-S1063 Notebook
I have a Sny dcr-hc48 camcorder which stopped working some time back. this week i had my friend who came with the same camcorder and i swapped in his battery and my camcorder started working. but if i...
First: put your battery in your friends camcorder and use ur friends charger to charge the battery.
Then put your battery back into your camcorder to see if it works.
If the battery works then this eliminates the battery as a problem.
Next plug your charger into your friends camcorder to see if it will power the camcorder without battery, if this works then the problem will most likley be the connector in your camcorder.
If this does not work then the problem will be the plug or the charger.
Next plug your friends charger into your camcorder if it does not work this will verify that the problem is the connector on your camcorder
binary6
Sep 16, 2009 | Sony Video Cameras
Compaq Presario V2000 battery
if the computer will turn on with it plugged into ac power than it is most likely the battery. batteries on these machines are cheap. Mine died after a year
Jan 18, 2009 | HP Compaq Presario V2000 Notebook
Wont power-up with AC adapters, with or without Battery!
the notebook cannot be charged without the charger and further more if it is not working properly ,try get a new one and it will work.i also recommend that you show it to a technician .
Dec 24, 2008 | MSI MS-1022 Notebook
HP Pavilion DV6500T 15.4" NOTEBOOK LAPTOP PC  Logo
188 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
