my monitor displaying OSD menu Automatically.......and monitor screen is also disturbed(as it shrink and its contrast will goes automatically at 100...and many more problems like this)
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]
Comments:
Oct 29, 2009
- corrigendum: a little bit add n modification:....
in case case of 45Bn & 55V..look for Controller Reset IC201/IC202
(KA7045/KA7045AP) [it is a small alike transistor 3 pin IC !!] along
with the afore said..
and in case of 56V..look for +14V SW. Transistor A1281 & C945 (therein) along with the afore said..
Sounds like your monitor is dying. I s it plugged into the computer properly, this may remove the menu from appearing, but it sounds like you need to consider a new monitor. Monitors are so cheap , its not worth trying to repair, the cost would exceed a new monitor
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Samsung SAMTRON 55V 15 in.CRT
The display of Samtron 55V monitor has shrunk horizontally to the middle of the screen. The...
(More)
The display of Samtron 55V monitor has shrunk horizontally to the middle of the screen. The horizontal width control in the front panel does not work.
