Water does not drain after spain&drain cycle - Washing Machines
  • 6,784 Answers
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Sep 10, 2009
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: Miele W3725 - normally i
I dont think there is any link that after you used the soft cycle a fault had crept in.
In fact the fault appears more as a program controller working erratic.
hence I would like you to clean the inlet valve filters, the outlet drain filters, check all the connections to the program controller unit and finally making sure that there is no loose connection at the supply point.
Tighten all connectiions , check the door switch - clean and reset as a faulty intermittent connection can make it reset the program.
Posted on Oct 29, 2010
My indesit WIB111 is full of water & clothes. how can I manually drain the water out?
put the machine in the emergency drain mode press the start button when it stops
http://www.manualslib.com/manual/76755/Indesit-Wib-111.html?page=13#manual
Dec 12, 2014 | Indesit Washing Machines
Wh60f60w1
Just had the exact same issue with my F&P it would stay in the drain cycle(without draining). It would show 2 minutes left in the cycle, dropping to 1 minute, but would never complete the cycle.
For some reason the machine would not drain the water from the drum and would continually remain in the drain cycle, spinning the load(back & forth), but not draining the water.
This is how I sorted the machine: -
1. I turned off & unplugged the machine.
2. I drained the machine manually. Opening the manual drain compartment located at the bottom right of the machine.
a). Firstly drained the majority of the water using the small black hose into a plastic container(ice cream container will be fine). Took a little while as the machine was quite full and I also didn't want to flood the laundry.
b). Once I had drained most of the water I undid the filter plug to drain the remainder of the water, which wasn't too much & was able to mop up with a towel. I gave the filter a good clean, removing as much build up in there(which in actuality was very little lint, gunk, etc. Though I did find a small button & a collar stay wedged in there).
3). I blew very hard into the washing machine drain hose a few times(read this on another forum so thought I'd give it a try!). Use a plastic bag, etc. to cover the hose etc. for hygiene purposes :)
4). I then plugged & turned on the machine. The machine went straight back into the 2 minute drain cycle. It attempted to drain/pump remaining water, however this time machine successfully went through the 2 minute drain cycle. Machine stopped, counted down, click and I was able to open the door.
I put the washing through a rinse setting to see whether the machine would complete cycle. I can happily report that the machine completed the rinse cycle on the washing with no issues. I also put through another load to see if it would complete a full wash cycle, which I can report it happily did so.
This may have just saved me a grand$ :)
Good luck.
cheers
Monkeyboy :^)
Apr 28, 2013 | Washing Machines
Kenmore portable air conditioner Model 484.35338 serial no AP0000320252 made in spain code X5RKMFE709/01 quit running after 4hrs run. DRAIN WATER light is on. How is the water drained?
The drain plug is on the rear of the unit, just above floor level. You can either drain it into a low sided pan that can hold a least a quart of water. Or roll it to an area, where you can allow it to just drain. If you drain it in place into a pan, be sure to turn the unit OFF & unplug it, before draining the water.
If you have misplaced your Owner's Manual, you can get one online from Sears Parts Direct.
Hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | Kenmore Heating & Cooling
Water not draining from washer. cannot open door. isnt there just a spin cycle i could go to instead of the entire wash cycle? i have already put it through 2 more cycles hoping the spin would drain...
Hi lauraeuschwa,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Kenmore HE2 Plus Front Load Washer
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
Hi I have a DD603 F & P dish drawer. I had an F2 fault, found the rotor motor seized. I've replaced that but F2 still comes up & the water doesn't drain away. Any ideas?
Before we talk about water not draining away, can you confirm if the wash arms rotate during the wash cycle. The rotor works as a wash pump and drain pump depending on which cycle it is in.
If F2 keeps coming then it is also likely there is some debris in the rotor cavity which is grinding on the rotor. But one needs to be sure if F2 is coming up only in drain cycle or is it already on during wash cycle.
May 16, 2011 | Fisher and Paykel 23 in. DD603H SS...
Kenmore 58715162400. Does not drain water. Water stands in bottom after wash cycles. Have to **** water out with shop vac hooked to the drain line to the sink.
As the water did not drain completely then check the drain hose & drain pump filter for any clogs/obstructions, if you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 13, 2011 | Kenmore Dishwashers
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
Doesn't drain; glasses have film; rinses with used, soapy water
The white film problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Sep 02, 2009 | Dishwashers
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
