Question about Brother MFC-620CN All-In-One InkJet Printer
Error message : ' cannot clean print head'
My printer model is DCP-110c. The 'cannot clean print head' appears every time I try to start the printer or start to print.
    President:
  • 2,306 Answers
Unable to clean means the ink absorber is full and needs to be replaced and the counter reset.
Posted on Sep 10, 2009
Brother DCP-110C printer not printing!
Clean the heads....................
found in printing preferences / maintainance
Jul 16, 2010 | Brother DCP-110C All-In-One InkJet Printer
My brother dcp 110c dosent print clearly on the black faded in colour all the rest of the colours afe fine
goto ink maintenance on the panel and select print nozzle check... check the print out to see if all the ink are printed out .. if not, try doing head cleaning to see if it resolve your print out problem.
May 28, 2010 | Brother DCP-110C All-In-One InkJet Printer
My brother dcp 110c printer is unable to initiate and refers to routine maintenance - it does print out test sheets however and I have undertaken routine maintenance - not sure what else to do
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 48 - defective print head cable or circuit board.If the error is 46 the waste ink tank is full.Follow this:
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value
which is Iassume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.
After you have entered this combination, the purge numeric value will be reset to 00000.
5.Restart printer
Nov 13, 2009 | Brother DCP-110C All-In-One InkJet Printer
Hi i have a brother printer 110c , the printer sayes unable to clean can you help solve the proplem thanks J
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
After you have entered this combination, the purge numeric value will be reseted to 00000.
Oct 27, 2009 | Brother DCP-110C All-In-One InkJet Printer
Brother dcp-340cw error 4F (print head), the same as error 41?
It is the printhead, it comes 2 ways, with or without the circuit board, I usually only change the printhead only and it works fine.
Sep 02, 2009 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-110C multi-function, printed image has shadow/double image. scanner seems to work ok. not really use copier. i need to correct printer to print regular text/image. thank you.
Press Ink.
Press up or down arrow buttons to select Cleaning.
Press Set.
Press up or down arrow buttons to select Black, Color or All.
Press Set.
The DCP will clean the print head. When cleaning is finished,
the DCP will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service
Aug 21, 2008 | Office Equipment & Supplies
DCP-110C
Dear ,
Its mean the The Print Head For CYAN printing is faulty, please bring your printer to Service Centre.
Regards
Mar 03, 2008 | Brother DCP-110C All-In-One InkJet Printer
BROTHER DCP-315N
Have you had this machine apart/head removed?
error 48 = Head flat cables or carriage-head flat cable broken or not connected.......or main P.C.B.
Are you serious, I have never seen this on any inkjet, ........"Try to get temperature of room.. warming up"
Do you live in a igloo?
Nov 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
Brother MFC-620CN All-In-One InkJet Printer Logo
174 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
