Question about Ricoh Office Equipment & Supplies
Ive recently purchased a RICOH Aficio Super 180 G3...used.
Ive recently purchased a RICOH Aficio Super 180 G3 used and am having troube adjusting the basic user settings. I want to change the fax header and the date it prints is completely wrong. help??
  • 68 Answers
Press the "user tools" botton, then select "fax option",than "program fax information".You can change fax header there. "Time and Date" usually in "System" submenu.
Posted on Oct 05, 2009
I've super G3, print comes light and very very light 2 inches from left. pl help
Print the copy counter of the machine, check if the life of the drum unit is already reached. If the drum is ok, then you have to clean the laser unit. maybe dirt is blocking the light coming from the LD unit.
Apr 12, 2013 | Ricoh Aficio 1515MF All-In-One Laser...
Is it possible ot add the printer function to a ricoh 1013F Super G3 copier/fax
I think that it is not possibel.
But the question is: If it was, Is it viable???? The money you are going to spend worth it????
Feb 17, 2011 | Ricoh Aficio 1013F Copier
Appel service technique Ricoh aficio 1232C super G3. code SC571. j'ai rempli le réservoir de l'huile de vaseline d'après les forums.mais toujours le...
code 571 low oil top up oil located back of copier reset code press yellow key 1 0 7 press red
key keep held for 4 secounds go in copy sp press 5 press lower cursor key untill you reach 5 810
sc reset code then turn copier off/ on
Nov 08, 2010 | Ricoh Aficio 1232C Color Copier
I have the ricoh aficio 1013f super g3 and I need a users manual can I down load one somewhere?
i can download it for you. i am a ricoh teschnician and i have access to ricoh websites. you won't be able to download the manual as it is blocked for users. only ricoh people have access. it will cost you a lil bit.
Sep 16, 2010 | Ricoh Aficio 1013F Copier
On my Ricoh aficio super G3 the toner wont load after replacing, the cartridge rotates but wont load
FYI "super G3" is the type of fax that is in your copier, not the Model of the Ricoh. Did you remove the steip after you put the toner in?
Aug 20, 2010 | Ricoh Office Equipment & Supplies
Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Jan 13, 2009 | Ricoh Aficio 180 Laser Printer
Error Message SC320
We are buying a new machine! The price of the motor and labor is more than the machine is worth.
Feb 06, 2008 | Ricoh Aficio 180 Laser Printer
Error code 0-09
Hi there I can only find in the service manual 6-09 and 9-09 I will attach the reasons for both if they are of any help great if not there are no tech bulletins for this machine that says otherwise.
Thanks J
9-09 Paper jam in the fusing exit
area
If the problem persists, replace the FCU.
6-09 G3 ECM - ERR received Check for a noisy line.
Adjust the Tx levels of the communicating
machines.
See code 6-05.
6-05 G3 ECM - facsimile data
frame not received within
18 s of CFR, but there was
no line fail
Check the line connection.
Check connections from the NCU to the FCU.
Check for a bad line or defective remote terminal.
Replace the FCU, FCU or NCU.
Try adjusting the rx cable equalizer
Cross reference
Rx cable equalizer - G3 Switch 07 (PSTN), G3
Switch 08 (PABX)
Jan 04, 2008 | Ricoh FAX5000L Plain Paper Laser
584 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
