Question about Dishwashers
Door has become stiff in operation and does not move up and down smoothly. is there an adjustment?
  • 224 Answers
Most of the time the dishwasher door hinges are located on the framing at the bottom of the unit behind the kick plate. There should be a spring on either side with a series of small holes in the bottom framing. Move this spring closer to the door for less tension, further away for greater tension.
Posted on Sep 10, 2009
When the control is pushed once the door moves about a foot and then reverses. Push a second time and it closes properly. IThe control does not have to be held until the door is closed. Any suggestions?...
Use the pull cord and disconnect the opener from the door. Operate the opener and let the carrier slide back away from the door. Is the carrier moving smoothly when disconnected? Next, lift the door by hand from the bottom to the top. Is it moving smoothly? If not, lubricate the axles of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well. Are all cables in all the pulleys, there are 4. After checking those things, there is a "up force" and "down force" adjustment on the opener, try increasing the "up force" by turning the adjustment in the direction of MORE force.
Gary
May 12, 2011 | liftmaster Chamberlain Garage Door Opener...
Tip
Inspecting a garage door opener.
<p>Use the pull cord and disconnect the opener from the garage door. <br /> <p>Operate the opener and let the carrier slide back away from the door. <br /> <p>Is the carrier moving smoothly when disconnected?<br /> <p>Operate the opener into the down position, does it run smoothly? <br /> <p>Next, lift the door by hand from the bottom to the top. Is it moving smoothly?<br /> <p>Run the door down, ensuring that it moves smoothly. If not, lubricate the axles of all the rollers on both sides of the door.<br /> <p>Check the cable pulleys at the top sides of the door channel, lubricate them as well. <br /> <p>Are the two cables in all four of the pulley grooves?<br /> <p>Are the cables hooked properly to the bottom of the door?<br /> <p>Now, connect the opener to the door and try it.<br /> <p>After checking those things, there is an "up force" and a "down force" adjustment on the opener, try increasing the whichever is needed by by turning the adjustment in the direction of MORE force.
on Jan 09, 2011 | liftmaster Chamberlain Garage Door Opener...
My Chamberland door opener works fine sometimes, and other times it might move an inch each time I push the button or a foot, sometimes it goes up and stops before it gets to the top and same going down.
I recommend this to everyone with garage door opener problems:
Gary
May 01, 2011 | liftmaster Chamberlain Garage Door Opener...
Genie excell garage door open's sooo slow and then stops 3/4 of the way up. Wom't move when instructed to close DOWN. Blinks 7 times in green on indicator light- so Can I trust that it is the Limit Switch...
Gary
Jan 07, 2011 | Genie Company Genie Excelerator Down Limit...
When button is pressed, nothing is blocking the sensors, but the light is flashing on and off
First check the alignment of the eyes.
Jan 02, 2011 | liftmaster Chamberlain Garage Door Opener...
I have liftmaster garage door opener P/N 41A-5483-4. It worked normally. but all of sudden, when door closing, it reverses automatically at half way down, and garage door light bulb starts blicking 6...
LiftMaster Garage Door Opener Frequently Asked Questions
Door only opens partially and stops.
Gary
When I activate the garage door moves up about 2 feet then just continues to go up and down as if stuck but there does not appear to be an obstruction
Gary
Dec 19, 2010 | liftmaster Chamberlain Garage Door Opener...
The springs are not broke, the door sometimes goes up but does not always go down. prees the door opener and you can here it turn on but nothing happens sometimes. Sometimes it will go up.
adjustment on the opener, try increasing the "down force" by turning the
Good Luck,
Gary
Dec 16, 2010 | liftmaster Chamberlain Garage Door Opener...
Every time I push the opener button the chain goes about an inch and stops abruptly. The door is not able to be opened or closed as a result. Is this an adjustment problem?
Disconnect the opener from the door.
Lift the door and ensure that it moves freely from fully open to fully closed.
Try to operate the opener. Does it go all the way from open to cloosed?
If the door operates smoothly and the opener works without the door connected, check the up/down force adjustment on the body of the opener.
Dec 01, 2010 | liftmaster Chamberlain Garage Door Opener...
Dishwashers Logo
184 people viewed this question
Top Dishwashers Experts
Owen Barnes
