Question about SanDisk Sansa e260 MP3 Player
Undeletable video file
First of all I tried the master reset
now I put the first 4 ep. of dexter on my sansa right and as I'm watching them all is fine untill halfway through ep. 2, the converter had split each episode into two parts and the second half of ep 2 didnt work insted it left my screen blank for 7 min the sansa could not respond to anything I did wouldent even turn off untill finaly turning back on . I plaugged it into my computer and took a look at the vid file and all but the first ep where replaced with strange read only files with wird named like yya but with ~~ over some you know real wird stuff anyway i deleted all but three which cantbe deleted so i try the master resetand there still there and still undeletable, also these files somehow incresed in size from the original vid files beacuse i only got 2099.9 MB out of 3800.9 MB available and the rest of the sansas now empty. oh its a e 260. i hope all the detail i included will help you find a solution.
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
Wont let me put certain videoes on
p.20 of manual:
Sansa Media Converter software lets you convert photos and videos as appropriate,
and then transfer them to your Sansa player. Sansa Media Converter offers
features such as cropping, rotating, and resizing before transferring them to your
player as well as the ability to transfer photo and video files to your microSD card.
Refer to the Sansa Media Converter software for file formats supported.
To transfer photos and videos to your Sansa player, follow these steps:
1. Connect the Sansa player to your computer.
2. Select Converter using Sansa Media Converter on initial connection.
3. Click Add Media to select photo or video files to be converted.
4. The Sansa Media Converter will store all converted files in My Album. Click
the Album Name box and type in the name you want.
5. Click to start the conversion process. A status box will appear
showing which file(s) are being converted.
Mar 11, 2008 | SanDisk Sansa e260 MP3 Player
Tip
Delete An "undeletable" File!
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br> <p><b><span> </SPAN></B><br> <p><span>Open a Command Prompt window and leave it open.</SPAN><br> <p><span>Close all open programs.</SPAN><br> <p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br> <p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br> <p><span>Leave Task Manager open.</SPAN><br> <p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br> <p><span>At the command prompt type DEL &lt;filename&gt; where &lt;filename&gt; is the file you wish to delete.</SPAN><br> <p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br> <p><span>Close Task Manager.</SPAN><br> <p><span>Or you can try this</SPAN><br> <p><span>Open Notepad.exe</SPAN><br> <p><span>Click File&gt;Save As..&gt;</SPAN><br> <p><span>locate the folder where ur undeletable file is</SPAN><br> <p><span>Choose 'All files' from the file type box</SPAN><br> <p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br> <p><span>put a " at the start and end of the filename</SPAN><br> <p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br> <p><span>click save,</SPAN><br> <p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br> <p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br> <p><span>1. Start</SPAN><br> <p><span>2. Run</SPAN><br> <p><span>3. Type: command</SPAN><br> <p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br> <p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br> <p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br> <p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
on Dec 10, 2010 | Computers & Internet
Tip
Delete An undeletable File
At the command prompt type DEL <filename> where <filename> is the file you wish to delete.
Close Task Manager.
Or you can try this
Open Notepad.exe
Click File>Save As..>
click save,
1. Start
2. Run
3. Type: command
4. To move into a directory type: cd c:*** (The stars stand for your folder)
5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:progra~1kazaal~1
7. Now to delete the file type in del ***.bmp, txt, jpg, avi, etc... And if the file name has spaces you would use the special 1st 6 letters followed by a ~ and a 1 rule. Example: if your file name was bad file.bmp you would type once in the specific folder thorugh command, del badfil~1.bmp and your file should be gone. Make sure to type in the correct extension.
on Oct 09, 2010 | Computers & Internet
Sansae250
connect to your pc using usb connection. sansa should be recognized as storage media drive. navigate to the drive. Drag and drop files to music/video folder. Enable show hidden files and folders in your windows folder settings. Tools>Folder Options>View. Some of the folders are hidden. You can delete the preloaded music also.Some of them are in the radio folder.
ThePlague...
Feb 02, 2008 | SanDisk Sansa e250 MP3 Player
Watching Uploaded Videos
i don't know how to put videos on the sansa mp4 e260
Dec 29, 2007 | SanDisk Sansa e270 MP3 Player
Tip
Enjoy Video and Music on Sansa View, Sansa Fuze, MP3 Media player
Questions: You are so excited to the large capacity and nice sound quality of Sansa player, yet you are confused to put your favorite videos to your Sansa Fuze, Sansa View, Sansa MP4 Movie and other Sansa players. How to convert MP4, MOV, M4V, AVI, FLV, SWF, MPG, ASF, WMV, MP3, AAC, M4A etc. to Sansa media player? This guide enables you to full enjoy on your Sansa MP3 and Video player by Sansa Video Converter for Mac. Solution: step by step guide to enjoy music and video on Sansa media player.
Preparation:
Software: Doremisoft Sansa Video Converter
System Requirements: OS Supported: Mac OS X v10.5
Hardware Requirements: 512MB RAM, Super VGA (800×600) resolution, 16-bit graphics card or higher
Download Now
Step1: Connect your Sansa video or MP3 Player to your computer through the USB connection.
Step2: Download Sansa Video Converter for Mac and run it.When you have installed this Sansa Video Converter, it will pop up the screen like below.
Step3: Add Video or audio files to Convert.Click "Add File" button to load your videos from your computer. Select the video files you want to convert. Also you may preview your video by clicking the left play button.
Step4: Preview and Select Click a file in the List or select several files. You could preview videos to play the file.
Step5: Edit the video with the function button:Clip(Merge, +/-), Edit(Crop, Effect, Rotate), Settings
(1)Clip:
You can cut your long videos into small clips or get more than one segaments just clicking "+/-". Besides, merge two or more video files into the whole successive one.
(2)Crop:
This function helps you cut off the undesired area from your movie video and choose your favorite clips to convert.
(3)Effect:
In the "Effect" selection, You could tune the Brightness, Contrast, Saturation and Volume to get special effect movie, in addition, you can Select Emboss, Gray, Old Film effect from Special Effect.
(4)Rotate:
Change video play direction in180, horizontal or vertical way to watch videos.
(5)Settings:
If you want to customize the output video’s quality, you can click the "Settings" button to open the settings window and set video Resolution, video Bitrate, Audio Channels, Audio Bitrate. Also, if you do not set them, the software will use the default setting to convert.
Step6: Select the format for your Sansa files. You may select "Sansa Video MPEG-4 (*.MP4)".
Tips: This format is to generally use. If you want to convert your videos into portable players you'd better select format according to your player. Then the output videos would be much more compatible with your player.
Step7: Start to convert the files.Check: Click the right convert button. The converting process will begin. Please wait before the converting successful in a few seconds.
Well done. Now you can enjoy your favorite music and videos on Sansa player everywhere.
on Feb 25, 2010 | Computers & Internet
Tip
Delete an undeletable file...
Delete an "undeletable" File.
Close Task Manager.
Or you can try this:
Open Notepad.exe
Click File>Save As..> locate the folder where your undeletable file is Choose 'All files' from the type box
Click once on the file you wanna delete so it's name appears in the 'filename' box.
put a "at the start and end of the filename (the filename should have the extension of the undeletable file to is will overwrite it)
click save,
It should as you to overwrite the existing file, choose yes and you can delete it as normal.
1. Start
2. Run
3. Type: command
on Feb 11, 2010 | Computers & Internet
Sansa e260 4mg
Download latest verison of Quicktime to resolve
Sep 02, 2007 | SanDisk Sansa e260 MP3 Player
Tip
Delete an undeletable File
Open a command Prompt window and leave it open.
close all open programs.
click Start, Run and enter TASKMGR. EXE
Go to the Processes tab and End Process on Explorer. exe.
Go back to the command Prompt window and change to the
directory the AVI ( or other undeletable file) is located
in.
Go back to Task Manager. click File, New Task and enter
close Task Manager.
or you can try this
Open NOtepad.exe
click File>Save as..>
choose "All files" from the file type box
in the "filename" box
pur a " at the start and end of the filename
click save,
1. Start
2. Run
3. Type: command
5. If you cannot access the folder because it has to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces.
7. Now to delete the file type in del ***.bmp, txt,jpg,avi,etc... And if the file name has spaces ypu would use the specific folder throgh command, del badfil~1.bmp and your file should be gone. Make sure the type in the correct extension.
on Jan 31, 2010 | Computers & Internet
Tip
Close Task Manager.
Or you can try this
Open Notepad.exe
click save,
1. Start
2. Run
3. Type: command
on Dec 02, 2009 | Computers & Internet
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
