Question about Sanyo Katana® II Cellular Phone
My katana 2 phone will not charge. I have two
My katana 2 phone will not charge. I have two chargers and neither will do it. I have replaced the battery and still wont charge. I t was workn up until it died. Is it that charging port on the phone? How much to fix it?
Retrieve Katana LX contacts
Hi Dear..
If the Charging slot is broken the you should buy the one alternate charger china made charger in that charge direct you charge you battery, after charge the batter plug-in and transfer all contact in your sim card. after that your Sim card in you other mobile you can find your all contact.
Thanks to Visit on Fixya .
Sep 22, 2012 | Sanyo Katana LX Cell Phone
My phone wont charge
The phone is not charging because:
1. The charger of the phone maybe bad. Test the phone with another charger or test the charger with another phone to confirm if the charger is defective or not.
2. The charging port of the phone maybe defective. In this case, the charging port needs to be replaced.
Good luck.
Jan 10, 2012 | Motorola Mobility Droid (2 GB) Cell Phone
My katana lx wont charge. It took awhile to connect and charge last time, but now nothing.
I am going to assume that when you say it took you a while to get it to charge last time, you had to wiggle the charger around and then get it in just the right spot to get the phone to charge, if this is the case there are only 2 solutions try another charger if that works you just have a bad charger, if that fails than something in the port on the phone is bent loose or broken and it will need to be repaired in your providers repair center, if u have insurance u might need to file a claim.
Dec 03, 2009 | Sanyo Katana LX Cell Phone
My LG VU charges just fine sometimes, and other times it will say its charging and drain the battery, and other times it wont register that its charging at all.I have 2 house chargers, and one car charger...
well about the arrows being upside down, some phones like this one the charger goes in up side down like for example the katanas. But about the charging issue check in the back of the phone and look for a red or white sticker or maybe pink. if its red then thats indicating that it has been water damaged and if its white then that indicates that if might not be but if you look in the charge port and check if it has like some green and white corosion in it. If you would like some help with this just e-mail me at Purelatina2004@yahoo.com
Jun 15, 2009 | LG Vu CU920 Cellular Phone
Can't find the connection place for plugging int the charger
its covered by a rubber like flap.the flap is on the left near the hinging for the flip. its a vary tiny usb connection
Apr 14, 2009 | Sanyo Katana LX Cell Phone
Cell Phone randomly powers off
most cell phones have lithium batteries that only have a certain life span. It may be worth your while to buy a new battery for the phone
Nov 21, 2008 | Sanyo Katana SCP-6600 Cellular Phone
My sanyo katana scp-6600
i need the driver to download ring tones and pass the phone. I have the cable but I asked the driver
Jul 20, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Katana wont turn on
Try taking out the batteryand putting back in after 1 min, if phone still does not turn on try a different charger if possible, and if that doesnt work it's probably the battery unless the phone has been introduced to any forms of liquid. You can get cheap chargers or batteries on ebay or I can get you one prettycheap as well. Let me know if you have any more questions.
Jun 26, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Sanyo Katana
This is phone's software problem. It comes when u pulled out battery in on phone's position. You can give it to repair to any skilled technician or to company customer support. They will put it right. This is not a big problem. If u found this a step towards solving your problem, do vote here.
Dec 30, 2007 | Sanyo Katana SCP-6600 Cellular Phone
Sanyo Katana
Help!!! I have had Sanyo Katana SCP6600B for about 16 months. My first problem with it arose the other day. The battery ran dry, so I attempted to recharge. After a couple of hours ,I attempted to restart the phone. It wouldn't re-activate. When I plug the phone into the re-charger, it comes on for about five minutes; ( I can call out, retrieve messages , check my contact list , etc.) , and then goes dead. I can only get it going again by unplugging the charger, and then re-connecting it....
So now I have a cell phone which only works when plugged into the mains, and then only temporarily! Not very practical...
Can anyone suggest what is the problem, and if it can be fixed?
Jul 16, 2007 | Sanyo Katana SCP-6600 Cellular Phone
Sanyo Katana® II Cellular Phone Logo
226 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
