Question about Hotpoint Refrigerators
Bottom of fridge iceing up,water not draining out ?
  • 4,070 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 10, 2009
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Frozen water on bottom of whirlpool model evl181nxtq01
I assume that the water is on the bottom of the fridge compartment? It could be that the drain trough has blocked and every time the fridge does an auto defrost, water runs out onto the floor of the fridge rather than down the drain. Once the defrost finishes, the water will stay on the floor of the fridge. Cold air falls to the bottom so its possible to get a sheet of ice in the bottom of the fridge. Locate the drain trough in the back wall of the fridge. See if you can visually locate any blockages or carefully dribble warm water down the drain to clear it.
Oct 19, 2013 | Whirlpool Freezers
Fridge freezer leaks water from bottom
your drain for your evap is clogged...... need to clear drain of ice then will be ok. brand and model # would be helpful.
Jan 03, 2012 | Refrigerators
I have water in my refrigerator on the shelves and in some areas it is freezing?
Could be a clogged condensate drain. Since you did not give a model #, I will assume this has the freezer on top. When it goes into defrost, the water cannot go down the drain hose to the drain pan and accumulates as ice in the freezer, below the bottom liner and may drip into the fridge. Empty the freezer and open the fridge door. The open fridge door can help thaw the drain. Remove the screws holding the bottom of the freezer liner and remove the liner. If there is ice below it, the drain is clogged. Remove as much as possible by hand and then use a hair dryer to carefully melt the ice at the back of the freezer. Blot up any water from the melted ice and concentrate on clearing the 1/2" hole in the center back. That is the drain. When you think the drain is clear, check it with a large glass of hot water. This can be take some time. When done, reassemble, but also make sure the fridge is tilted to the back by adjusting the legs at the front bottom corners of the fridge. You may have to take the grill off the bottom of the fridge to do this. The legs screw down to lengthen them. Adjust them far enough down that the fridge door swings shut by itself. This will help the water down the drain before the fridge comes out of defrost, starts cooling and freezes it in the drain hose.
Mar 03, 2010 | Whirlpool Refrigerators
Water lks bottom of fridge ,also ice tastes horrible
u shd spl ot ur wds fly. Do you mean the water leaks at the bottom of the fridge? If so, you may have a clogged drain hose. Pull out fridge, disconnect power, check & see where drain comes out of fridge, go to front and pour hot water down drain to see if it is frozen. It may be clogged (pea or food). If the drain doesn't work, the fridge will leak. Check the gasket on the fridge door for sealing and make sure it is in good shape.
Oct 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water in bottom of fridge
Probably has ice frozen under freezer tray or drain tube may be blocked by ice diverting water through freezer to fridge vents.
Sep 11, 2009 | Refrigerators
My freezer is still freezing but the fridge is not cold. You can hear it running but nothing. HELP!
is the fan running in the freezer? if not replace fan .if not unplug fridge,,remove all inside pannels in freezing unit,,in the bac ,in the middle, on the bottom ,there is a drain that drains into the very bottom of fridge,is it like aice bottom across the bottom of the freezer?if so,use hot water to defrost all the ice and may be a hair dryer,water will melt and **** down the drain threw the drain tube,to the bottom of fridge into a shallow pan under the fridge,that slides out(could be messey).clean all bottom of freezer out good(crumbs mostley)that stop up drain and pour water threw drain a few time to clear drain good.reasemble and ur good to go.now if there is no ice and drain is good,you might find ice on coils,this means ur defrost timer is most likeely gone out ,just replace timer
Jul 04, 2009 | Electrolux Refrigerators
Water and ice pool in bottom of fridge
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jun 30, 2009 | Refrigerators
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
Water on the bottom of the fridge - then turning in ice
drain is blocked. to check, pour water into drain gulley in fridge and it should flow away. to clear, push sometthing flexible down the hole. good idea to pour dilute bleach down hole now and again
Mar 19, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
83 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
