Question about Dell Inspiron 6000 Notebook
My Dell Inspiron 6400 battery is overheating and light is flashin
My Dell Inspiron 6400 laptop's battery is overheating. It is un touchable sometimes. The light also flashes orange sometimes, even when it is charging. Also, when the laptop used to charge, it had a constant green light when charging, now it flashes green, and sometimes orange and green. Tried to make sure battery is in place properly but still appears.
Any help would be greatly appreciated.
Simo
Hello I own a Dell Inspiron 6400, i guess what happened was that it must have overheated of so but its on the screen your system automatically powered off because it became warmer than expected. This may have been caused by:o) operating or storing the system in an environment where ambient temperature is too high or o) obstructing the air flow from the system fan vents. if this problem recurs please call dell support with error code #M1004. strike the f1 key to continue. f2 to run the setup utility pressf5 to run onboard diagnostics.
Posted on Aug 03, 2010
  • Pushpendra singh Aug 26, 2013
    Replace the battery and go for a hardware service
  • 61 Answers
Check out this battery site from Dell to see if you have a lemon
www.dellbatteryprogram.com
Posted on Sep 10, 2009
La batteria non tiene più la carica.può essere un problema tecnico
Battery for Dell Inspiron 6400 (5200mAh)
http://www.batteriamondo.com/dell-inspiron-6400.html
  • Availability: In stock
  • Voltage: 11.1v
  • Capacity: : 5200mAh
  • Colors: Black
  • Weight: 310.24 g
  • Dimensions : 156.30 x 120.00 x 23.04 mm
  • Customer review: 4.5star.gif
  • 100% compatibility with the characteristics meet or exceed the original
  • Performance using a spare battery for your dell inspiron 6400.
Feb 15, 2010 | Acer Aspire 5610-4648 Notebook
Dell inspiron 6400 freeze after startup
do a system restore before it started doing it.
Nov 08, 2009 | Dell Inspiron 6400 Notebook
Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
Nov 06, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 touchpad and keyboard work intermittently. battery light was flashing red this morning. i have to hit the keys several times before they work. laptop is plugged in.
sounds like your main battery needs replacing,move your mouse over the battery icon in the system tray(by the clock),to see if the battery is charging. If it is battery needs replacing. This can cause all kinds of strange issues .
Oct 12, 2009 | Dell Inspiron 6400 Notebook
My Dell Inspiron 6400 laptop battery isn't charging, I think :(
Debby
Try booting without the battery installed. You probably will have no change but this eliminates the battery as a source of the problem. If it doesn't boot and you are sure that the external power supply is ok, you probably have a bad motherboard. At that point, the unit needs to be checked out by a pro or a really competent amateur.
Aug 01, 2009 | Dell Inspiron 6400 Notebook
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Facing problem with battery of Dell Inspiron 6400
1. Shut down the system, remove the battery and the Ac adapter from the computer.
2. Press the power on button for 10 seconds
3. Reinsert the battery
4. Power on the computer and as soon as you see the dell logo press the f2 key a couple of time
5. Using the up down arrow keys , go to the option that says battery info. If there is an error message listed kindly post it back
6. Otherwise shut down the computer reconnect the ac.adapter and check if the problem is solved
Also the battery has a diagnostic lights on it , remove the battery from the computer and press the button on the battery a set of lights would glow. If they are steady and come in a series the battery is good , If some lights are missing the battery is bad and may need replacement
Thanks
Proton
May 15, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Flashing red and green battery light dell 6400
Ok, probably not the battery. With Dell machines, once they overheat to a significant level, it locks an overheating code into the bios, so you will have the light codes at start up. I've had three C840 machines with an overheating issue come through my shop. In order to get the machine working again, you will have to fix the problem that caused the overheating, then there is a download at Dell's site to clear the code. If the initial problem isn't fixed the code won't clear. On the machines that I worked on, 1- had a hair wound in the fan and the other 2 had bad fans one burned up the processor. I believe the 6400 and the C840 is basically the same machine. It's been a while since I worked on those machines so I can't remember exactly where the clearing download is at Dell's site, I do remember reading several forums at Dell on the subject. I hope this approach helps a little more than my last. If you have any more questions please ask.
Jul 09, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6000 Notebook Logo
960 people viewed this question
Alun Cox
