Need instructions to replace the drum on Minolta CSPRO 3050
  • nreynoldsjr Sep 14, 2009
    I am very handy, though not a copier tech. Yes it is an EP3050. I have the instructions to recalibrate the drum, just don't have the instructions to physicall remove/replace. Thanks
  • sam gerban
    sam gerban May 11, 2010
    how handy are you?is this EP3050?
    Scholar:
  • 136 Answers
Are you a Technician ?
Do you know how to recalibrate the Drum if you have Copy Quaility issues ?
Posted on Sep 13, 2009
I have a Minolta CSPro 3050.. legal paper drawer won't close..and it won't copy
To the rear cover located one hole before waste toner box.Introduction one long screwdriver and push the unlock button.
Jan 18, 2013 | Konica Minolta Copier Toner EP6001 CS Pro...
Minolta cspro 1083 makes gray copy
has the developer been replaced and the required F8 run along with the drum counter reset. Also was the F5 run and F3 all of these F# are run in service mode.
Nov 13, 2012 | Minolta EP1083 CS/PRO Copier
Have a Minolta CSPro 3050 with error code C004A. What does it mean
There is a fan located under the big glass section remove the glass an check the fan clean it or replace it.
Feb 01, 2012 | Minolta Office Equipment & Supplies
Have a MINOLTA CSPRO 4000, erro code C0040----"FAN
The fan is not easy to replace...... The fan is located under the black transport belts. The fan is part
of the unit that brings the paper from the transfer & drum to the fuser unit. The unit is black and it looks like tank tracks. From what I remember the fan is acturely in the transport unit ... Good Luck
Apr 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
My minolta EP3000 CSPRO shows error code coooo
Main motor remove the fuser unit the hot part check for broken gears also look in the back where the fuser go for bad gear, then check the drum assy. for old cleaning blade if yellow replace it or the drum is stuck use thumbs on the edge of the drum to turn it clockwise looking at the front counter clockwise messes with the cleaning blade. Worse case the motor is dead and or the control board, you try the below web site try for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 25, 2011 | Minolta EP1031/1031F CS/PRO Copier
There are black spots and lines on my paper when I
Clean the optical section(mirrors,lens,glass).Remove tje IU unit,change the OPC drum cleaning blade and clean the drum,charge corona and transfer/separator corona,after perform F5.
Sep 25, 2009 | Minolta Office Equipment & Supplies
Code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
Minolta CSPRO EP 3050 turning it On appears display Code: C0200
A C0200 is a problem with one of the coronas - could be the charge, transfer, or separator.
First try resetting the code by opening and closing the main front door with the machine powered up and the error code showing. This should make the code go away.
It may or may not come back. If it does, clean the coronas.
It is necessary to remove the drum assembly in order to access the charge corona.
The EP3050 originally came with a self-replacing charge corona. It actually had a small spool of corona wire in the charge corona assembly, along with a small motor that advanced the wire every few thousand copies. This was prone to malfunctions, and there was a retrofit kit which replaced the whole thing with a conventional wire.
If you still have the code, and have no idea what I'm talking about, then it is probably time to call a technician. :-)
You will need to call an independent, as Konica Minolta no longer supports this model.
Nov 12, 2008 | Minolta EP1030/1030F CS/PRO Copier
77 people viewed this question
jasbo
jasbo
