Xerox Workcenter 2424 connected through network to a Desktop mac intel comp OSX tiger Upon turning on the machine it blocks by a system error 07,10.43:35608. Please help
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error 07,10.43:35608 on Xerox Workcenter 2424 means The printhead is stuck in the tilted position, or is not tilting properly over the CAM, due to problems with the process motor gearbox.
Step Questions and Actions Yes No
1 a. Reboot the system.
b. Did this correct the problem? Go to Step 2. Complete.
2 a. Do the printhead lock arms rotate correctly? Go to Step 3. Repair or replace the lock arms.
3 a. Is there spilled ink around the printhead? Clean the printhead area. Go to Step 4.
4a. Check the process gearbox for obstructions or damaged.
b. Ensure the gears are correctly aligned and homed.
c. Verify the process shaft and drive module shaft are at their home positions.
d. Did this correct the problem? Complete. Go to Step 5.
5 a. Verify the headtilt gear will engage. You can manually set the head tilt gear.
b. Is the gear engaged properly? Go to Step 6. Set the head tilt gear.
6 a. Use service diagnostics to run the Tilt Axis Drive test.
b. Did the test fail? Replace the process gearbox. Go to Step 7.
7 a. Use service diagnostics to run the Process Motor test.
b. Did the test fail? Replace the process motor. Go to Step 8.
8 a. Use service diagnostics to run the Head Maintenance Wiper Clutch test.
b. Did the test fail? Replace the wiper drive clutch. Go to Step 9.
9 a. Ensure the wiper is properly aligned.
b. Use service diagnostics to run the Wiper Drive Test.
c. Did the test fail? Go to Step 10. Replace the exit module assembly.
10 a. Use service diagnostics to run the Load Maintenance Clutch test.
b. Did the test fail? Inspect the maintenance drive system, replace any defective parts.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 10, 2009
The usb ports does not work how can i fix it
Seriously USB ports with Mac OSx on sewing machines ?
1. What is your error message on screen.
2. Have you checked the usb stick on any other computer ?
3. backup and initialize.
how to repair non readable USB on mac
Apr 16, 2016 | Sewing Machines
Were can I find the mac-adress of the 2015 avocent
In windows, connect it and use the "getmac" command under a command prompt .
If on OSx, Open System Preferences from the Apple menu
Click on "Network"
Select your currently active network connection from the left menu (Wi-Fi, Ethernet, etc) and then click on "Advanced" in the lower right corner
Look at the bottom of the window for "Wi-Fi Address", the hexadecimal characters next to this are the machines MAC address
Jun 27, 2014 | AVOCENT-EMERSON Avocent AutoView 2015 -...
Apple mac osx 10.4 tiger
you need system disk. cannot upgrade across os platforms without disc.
Apr 09, 2013 | Apple Mac OS X 10.4 Tiger for Mac
Setting password on OSX tiger
I taking it that you mean you want to change your password on a mac you have already logged onto. This is quite simple go to the apple menu which is located at the top left of the white menu bar, then go to system preferences and select network. Once network preference pane has come up click on the account called my account on the left hand side then on the right hand side there is a change password button, click on this and insert your Old password and then insert the new password in the New password box and then the new password in the Verify box. Then click the change password button on the bottom right. Hope this helps.
Jan 08, 2012 | Computers & Internet
I have install osx 10.4.11 on G5 intel, internal harddrive.Then i install the harddrive to mac mini PPC 1.42 GHZ . Now it will not boot. Only gray display. If i take harddrive out i will boot. What's the...
Did you use a system specific install of Tiger (OS X 10.4)? If so, you need to use the retail version of the OS so it will work across the board with all Macs.
Mar 05, 2010 | Apple Mac mini
Windows vista cannot connect to xerox workcenter pe16 networking printer, error not enough memory
not surprised..vista is a nasty program. not enought memory refers to vista not your PE16
try downloading from xerox website..website is useless but try
Nov 17, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox workcenter 7665 communication problem
This was an issue with earlier models and is usually attributed to the "USB" connector on the bottom of the control panel not being attched securely. Note: although the connector is USB, it is NOT hot swappable and will crash the machine if unplugged while the power is on.
Power off the machine. Ensure the cable is securely attached and restart the 7665. Make sure when you turn it off that it is completely off before restarting or you could corrupt the system software.
Aug 07, 2009 | Xerox Office Equipment & Supplies
Tally 8008 not printing mac OSX 10.5.6 leopard
Found a solution. We connected 8008 printer to imac running Tiger & we can now print via network on any of our emacs running Leopard. Not ideal but at least we can now use the printers. I would still love a dedicated driver to work direct but I suppose this will do for now.
Jan 13, 2009 | TallyGenicom 8008 Laser Printer
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
