Question about HP Photosmart C5180 All-In-One InkJet Printer
I took out the paper input tray and it will not go back in
    President:
  • 2,306 Answers
There's a spring loaded lever on the bottom where the tray goes, you need to position it towards the front, and slightly lift the center of the paper tray as you install it. With a little wiggling it should go in again...
Posted on Sep 10, 2009
I pulled the main input tray out- how do I put it back
Try looking at HP's page on your model here:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=65515&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3315742
Is it a 'carriage jam' or an 'out of paper' error?
The paper input tray on your machine should go back in similarly to a kitchen cabinet drawer. Lift up slightly and push in, and it should slide back into place.
Mar 15, 2013 | HP Photosmart D7260 Printer
PAPER FEEDS OUT OF THE BACK INSTEAD OF THE FRONT
If the paper output tray is pulled out at the back then paper will exit through the back (face up). If you push this tray down then paper will exit out the top and lie face down on top of the printer. The tray that pulls out of the front of the printer is a input tray only and cannot be used to output any pages.
Jul 26, 2011 | OKI Electric Industry B4600 Laser Printer
Our mfc5460 brother printer is giving the error message "print unable 30" and "print unable 50" alternately. WE had a paper jam, removed everything we could see from top and back, and are now stuck. We...
  • Remove the input paper tray and take off the output tray. Remove all loose paper from the input tray.
  • Step 2Pull out the paper support flap and unfold it to its greatest length.
  • Step 3Flip through the stack of paper before inserting it back into the input tray. Place the paper in the tray and adjust the paper guides so they press against the margins of the paper.
  • Step 4Ensure that the stack of paper is below the maximum paper line on the inside of the input tray. Unplug the power cord from the back of the printer.
  • Aug 09, 2010 | Brother MFC-5460CN All-In-One InkJet...
    Pen gartridge jam
    Is it an ink cartridge jam
    Please follow steps below : STEP: Disconnect and Reconnect the Printer Power Supply
    Unplug the power cord from the wall socket. Disconnect the power supply from the back of the printer.
    Wait 15 seconds.
    Reconnect the power supply to the back of the printer.
    Plug the power cord back into the wall socket
    STEP: Raise and Lower the Scanner Assembly on the Printer
    Lift the lid of the scanner until the locking bar catches to move the ink cartridge carrier to the center position.
    Release the locking bar and close the scanner assembly.
    If the ink cartridge carrier fails to center, repeat steps 1 and 2
    Scanner Assembly Open but Without the Cartridge Carrier Centering
    STEP: Check to See if the Ink Carrier Latches Are Open
    Open the printer.
    Check inside the printer to see if the cartridge carrier latches that hold the ink cartridges down have popped open.
    Close the carrier latches
    STEP: Remove any Torn or Stuck Pieces of Paper from the Input Tray and Output Tray
    Disconnect the power brick from the back of the printer.
    Lift the scanner unit.
    Look down inside the printer and remove any torn or stuck paper from the input or output tray by pulling firmly.
    Close the scanner unit.
    Reconnect the power brick to the back of the printer
    STEP: Clear Obstructions From the Input Tray
    STEP: Fan the Paper
    Grasp the **** of paper at one end (Figure 1).
    Place your thumb on top of the opposite end of the paper and fan the paper like a deck of cards.
    Flex the paper back and forth, and then fan it.
    Straighten the edges of the stack on a level surface.
    Top of Form 1
    Bottom of Form 1
    Additional Information
    It is quite possible for objects such as pens, pencils, paperclips, and other small items to fall into the paper input tray causing paper jams to occur. Follow the below steps to try and clear any obstructions that may have fallen into the printer.
    Caution:
    The next steps involve lifting the printer and turning it upside down. Only perform these steps if you are willing and able to do so.
    Remove all paper from the input tray.
    Unplug the power brick from the back of the printer.
    Unplug the USB cable from the back of the printer.
    Lift the printer up and turn it upside down.
    Caution:
    Make sure that you are holding onto the scan bed to prevent it from falling open when the printer is turned upside down.
    Tilt the printer from side to side while it is upside down to see if any obstructions fall from the input tray.
    Jul 19, 2010 | HP OfficeJet t65 All-In-One InkJet Printer
    The printer was working fine but ran out of paper. I refilled the paper tray, but now the printer will not pull the paper. I took some paper out & it will still not pull paper. HELP !!!
    Take some more paper out.
    If the input try is to full, the pick-up rollers can not overcome the upward pressure and fails to release and drop.
    Just another thing to check, make sure the application you are using is selecting the correct printer and input source.
    Don
    Jan 29, 2010 | Lexmark E234 Laser Printer
    I had a paper jam and I took the back off and this
    Step one: Remove any loose paper
    Remove all loose paper from the input and output trays.
    1. Turn off the product.
    2. Unplug the power cord from the back of the product.
    3. Push the button on either side of the rear-access panel or the duplexer (two-sided printing accessory) and then remove the panel or duplexer.
    4. Find any jammed paper inside the product, grasp it with both hands, and then pull it out of the product, toward you.
    5. If the product has a duplexer, push the latch on the top of the duplexer and lower its cover.
    6. Carefully remove any jammed paper.
    7. Close the cover.
    8. Reinsert the rear-access panel or the duplexer into the product.
    9. Plug the power cord back into the product.
    10. Turn on the product.
    Step three: Open the top cover and clear the jam
    3. Open the carriage access door. The carriage moves to the right side of the product.
    4. Gently pull the paper out of the rollers.
    5. After clearing the jam, close the carriage door.
    6. Plug the power cord back into the product.
    7. Try printing a document.
    · If the issue is resolved, do not continue troubleshooting.
    · If the issue continues, proceed to the next step.
    Step four: Clear the jam from paper tray 1
    1. Remove all paper from the output tray.
    2. Turn off the product.
    3. Unplug the power cord from the back of the product.
    4. Lift the output tray and then check for jammed paper in input tray 1.
    Use these steps to remove any jammed paper.
    a. Raise the output tray.
    b. Grasp the jammed paper and pull it out of the product, toward you.
    c. Lower the output tray.
    5. Plug the power cord back into the product.
    6. Try printing a document.
    · If the issue continues, and if paper tray 2 is not installed on the product, proceed to 'Step six: Clear the jam from the automatic document feeder (ADF).'
    · If the issue continues, and if paper tray 2 is installed on the product, proceed to the next step.
    Step five: Clear the jam from paper tray 2
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    3. Remove the ADF input tray and open the ADF cover.
    4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside.
    5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
    6. Check the ADF paper path for jammed paper.
    7. Check for jammed paper where paper enters the ADF paper cleanout.
    o If the paper comes out with gentle pulling, proceed to step 9.
    o If the paper does not come out with gentle pulling, follow these instructions.
    1. Open the ADF, and then use both hands to gently loosen the paper.
    2. When the paper is free, gently pull it out.
    3. Close the ADF.
    8. Lower the green lever.
    Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
    9. Replace the ADF input tray.
    10. Check the following to make sure that the ADF frame and parts are secure and correctly set up.
    o Make sure that the ADF frame is secure and attached correctly.
    o Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
    o Make sure that the ADF pick mechanism is secure. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
    Make sure that the two-catch is holding the roller mechanism securely in place and that the stack stopper is in the correct position.
    1 - Stack stopper
    2 - Two-catch
    11. Plug the power cord back into the product.
    12. Turn on the product.
    13. Try printing a document.
    Jan 01, 2010 | HP Officejet Pro L7680 All-In-One Printer
    Paper jams always appear
    According to the top of page 13 of http://h10032.www1.hp.com/ctg/Manual/c00696169.pdf,
    Avoid paper jams
    To help avoid paper jams, follow these guidelines.
    ● Remove printed papers from the output tray frequently.
    ● Prevent curled or wrinkled paper by storing all unused paper flat in a resealable
    bag.
    ● Ensure that paper loaded in the input tray lays flat and the edges are not bent or
    torn.
    ● Do not combine different paper types and paper sizes in the input tray; the entire
    stack of paper in the input tray must be the same size and type.
    ● Adjust the paper-width guide in the input tray to fit snugly against all paper. Make
    sure the paper-width guide does not bend the paper in the input tray.
    ● Do not force paper too far forward in the input tray.
    ● Use paper types that are recommended for the HP All-in-One.
    Dec 02, 2009 | HP Photosmart C4180 All-In-One InkJet...
    HP Color LaserJet 8550DN input device failure, check cables and cycle power | error code: 66.01.02
    This error message indicates a lifter malfunction has occurred. When the 2000-sheet input tray (Tray 4) is closed, the paper deck lifts the paper stack until it is just below the feed rollers. Photosensor flag PS34, the paper surface photosensor, determines when the paper stack is lifted into the feed position. When PS34 does not detect paper in the expected time, the printer reports a 66 error. SOLUTION: Follow the steps below to troubleshoot and resolve the issue.
    1. Turn the printer off, open and close the tray, then turn the printer back on to see if the error clears.
    2. Open the drawer and check for extra paper or items stored on the left side of the tray. This will prevent the tray from lifting due to excess weight or blocking the lift of the tray.
    3. Remove all the paper from the tray. Remove the tray guides and reseat them. Verify the guides are not bent or broken.
    4. Lift the paper deck manually to verify there are no obstructions in the path.
    5. Pull the tray out as far as possible and observe the white bushing on the back right side of the tray. If the white bushing is broken, the tray will not lift properly.
    Oct 23, 2009 | HP Digital Sender 9100C Multifunction...
    It says to load paper in the MP tray
    Pull down the front cover where it says Brother, the manual feed input is behind that panel (above the main input tray)
    Nov 19, 2008 | Office Equipment & Supplies
    "out of paper" error
    new_caution.jpg Caution: The next steps involve lifting the printer and turning it upside down. Only perform these steps if you are willing and able to do so.
    1. Unplug the power brick from the back of the printer.
    2. Uplug the USB cable from the back of the printer.
    3. Lift the printer up and turn it upside down.
      new_caution.jpg Caution: Make sure that you are holding onto the scan bed to prevent it from falling open when the printer is turned upside down.
    4. Tilt the printer from side to side while it is upside down to see if any obstructions fall from the input tray.
    Dec 31, 2007 | Dell 922 All-In-One InkJet Printer
    HP Photosmart C5180 All-In-One InkJet Printer Logo
    41 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
