Question about Samsung CLP-315W Laser Color Printer
Wireless problems Just the same as above, i cant even find it as an adhoc wireless devise
My new tablet will not connect to internet. i have the usb plugged into mt laptop. i do not have a wireless router?
open network connections on your laptop and select both the wireless adapter AND the internet connection adapter in there and right click on them and click bridge connections. Then go into the network setup wizard (XP) or network and sharing center and click connect to a network and choose adhoc connection. then open wireless settings on the coby kyros and connect to the adhoc connection on your laptop. You should then be able to connect to the internet on it
Mar 26, 2011 | Coby Kyros 716829701508 Tablet PC
I have a wireless network of computers, one wired and 2 wireless. in the correct setup, my other acer laptop doesn have internet, but s connected to the router, and this laptop im using CAN connect...
All the computers should have the same NETWORK NAME or SSID.
Recheck the settings and make an adhoc connection for each of the computers to your router.
You can also get a USB wireless adapter to enable ht NO internet laptop and connect them.
Just keep playing with the NETWORK SETTINGS.
Make sure all are connected to the SAME SSID.
Hope it helped.
God Bless You!
Feb 05, 2011 | Linksys WRT120N Router
Need UWA-BR100 drivers
When I install de UWA-BR100 driver with the fix mentioned above it works but it does not show all wireless networks available. When I look at the hardware properties I see 802.11b Preamble and a mention of Adhoc 11n.
When I look at the properties of my other wireless adapter there is mention in the properties of: 802.11n 20 MHz, 802.11n, 802.11n modus, Adhoc Qos, Adhoc 802.11b/g. This adapter shows more available wireless networks then when I use the UWA-BR100. With the UWA-BR100 I can not see my own wireless network.
Does anyone has a solution for this problem?
Thanks
Sandra.
Jan 23, 2011 | Sony UWABR100 Network adapter USB ...
My husband has Netgear in our house but i need an IP address for my lap top and Ipod, can you help me with that?
If your laptop has wireless card installed, turn on wireless radio of laptop. It will show the networks available and will allow you to create a new adhoc network. Try to create a new adhoc network and assign a new network name. It will broadcast an IP over adhoc network and you can connect other wireless device to the laptop using this adhoc network name.
May 29, 2010 | NetGear WGR614 Wireless Router
How do i set up a wireless network connection between 2 laptop
computer to computer networking is called adhoc networking without using any router, in this you need to create adhoc network on one pc and then search for that signal on other pc. it your want to know more about adhoc networking search on google. but u need to do adhoc networking
Feb 08, 2010 | HP DeskJet 6840 InkJet Printer
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
How does the pc wireless adapter work for laptops with embarq equipment. currently using dsl with embarq.
pc wireless adapter will work then if you have also another network like wireless router or another PC or Laptop with wireless adapter, if your going to use this wireless adapter network in pc to pc is you are going to setup by adhoc to adhoc connection, itself detect for sharing a network without any router needed, but if you do such simple network connection use wireless router, its definitely work easily. Aumatomaticall detect wireless router on your wireless adapter network.. Good luck!
Jul 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
I want to add a printer in adhoc mode
Hi
The Deskjet F380 will not support wireless ADHOC
Thanks
Riz
Jan 08, 2009 | HP DeskJet F380 All-In-One Printer
Wireless printing
hi vlewis, if you are trying to print directly from your Pavillion to your Officejet wirelessly, you should set an AdHoc type of connection. but if you have a wireless router that you are connecting to, you should have an Infrastructure type of wireless connection. here are some key points you may need to look at.
AdHoc (PC to Computer wireless printing)
1.make sure that the wireless adapter on both devices are turned on.
2.the wireless network name or the SSID should be the same with both devices.
3.you will have to set the same wireless security (like WEP or WPA depending on the capability of the devices)
4.install the printer drivers and utility and make sure that your printer utility shows connection to the computer
-voodoomox
i will follow this one up for infrastructure.
Aug 05, 2008 | HP Office Equipment & Supplies
Samsung CLP-315W Laser Color Printer Logo
288 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
