Question about Car Audio & Video
Hi. Have a 2000 s80t6. Stereo works for a bit and then out of no where a loud static/interference noise happens and it doesnt stop by turning the stereo off. Only when ignition is turned off. Stero repairer said that he wasnt sure if it was the Stereo or amplifier. Can you tell me whats happening. Thanks
  • manuelw Sep 11, 2009
    Hi. Thanks for your reply. Re. Antanae ground; where do I find this?
    I have tried all suggestions given so far.
  • 691 Answers
It hard to say what is wrong, it can be numerous issue from your ground, bad connection between your amp and radio, or radio is faulty, amp is faulty, bad speakers...etc. most newer radio come with rca jack and plug in for that main reason although some older radio doesn't equip with rca jack but one have to rig all the wiring to make it work and thing get mix up and now you have bad sound. best thing to do is eliminate one things at a time. check and make sure you have good ground to both radio and amp if you have them. most important is to make sure all your speakers wiring connected to the right post, like positive to positive and neg to neg, if not chances are you will short your amp out or the radio. test all your speakers first one at a time making sure they put out good sound. next test your amp checking one channel at a time with another radio, next test the radio it self without the amp, this way you can eliminate what good or bad, if all check out fine, that its you bad ground wire.
Posted on Sep 11, 2009
    Top Expert:
  • Car Audio & ... Master
  • 77,194 Answers
Having done 100's of stereo installs have seen this many times, the usual problem is that the Antenna ground is bad, clean the antenna ground to the sheet metal of the car, it that doesn't cure the issue the noise filter inside the radio is defective and the radio will need to be pulled out and repaired by an authorized repair station for your car. In rare cases this problem is caused by a defective electrical noise suppression capacitor in the alternator.
Posted on Sep 10, 2009
  • 19,396 Answers
That it is probably the Amp built into the stereo (final section of circuit), or the external car amp.
What happen is that one of the Amp power ICs is faulty, and after overheating it will cause general fault.
If stereo becomes completely irresponsive when this happen, then it can be the Stereo itself.
You can find out if it is the stereo or the Amp bypassing the AMP, bridgeing wires to speakers to connect straight to stereo, and removing fuse from Amp, so that it will not start.
Why is my Samsung DLP Television is making a static noice when turned on?
Hi, what do you mean by static noise. Is your station unclear. Does this only happen on the cable coax connection or is it a loud noise. If its a loud noise then its your colorwheel if its an unclear station or channel then more then likely its your main input board. Please let me know if that helps any.
Jan 02, 2011 | Samsung HL-S5087W DLP TV
Loud static noise without warning
The audio may be randomly disconnecting or something. I know that when my TV has no signal coming in, that it makes a bunch of loud static.
Jun 04, 2010 | Tatung V20KQDX 20.1 in. LCD Television
Loud squealing noises when I turn the wheel of my 2000 ford range
It sounds like the power steering belt is too loose, tighten it up a bit but not too much just enough to make slipping belt stop.
Jul 01, 2009 | 2000 Ford Ranger SuperCab
How do i get rid of the static in my model CKS2235B radio? The original literature which i no longer have indicated that the power cord is an antena. There is no one position that works with that approach....
You will have to place the radio away from any noise sources. Like television,lamps, fans, other stereo equipment,refrigerators. These all cause noise on the a/c line current. This is the source of noise. You can try using a/c line filter/surge protectors to stop the line noise interference. Plug the radio into this and place it near a window so it can easily find the signal source.You can also look on line for more information on how to limit noise interference on a/c line connections. I hope this information help you with your problem.
Apr 17, 2009 | Emerson Smartset Clock Radio
Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
GE Dect 6.0 Cordless - Loud Static
question is are you running a pc and router/ modem on the same land line
if so you will need the line filters to the phone base
the computer data is transferred by the same land line and there is every possibility that the different frequencies is what is causing the static
reference from a uniden trouble shooter ( will be common as the phones use the same medium)
lots of noise or static on the line === possible solutions --check for interference from appliances ( microwave , tv etc ) or wireless devices ( baby monitors wifi equipment etc)
move the handset base away from the source
if you have any device that uses the phone line , add a DSL or telephone line filter to the system
it is possible from the times you state that the interference could be coming form a neighbour or further down the line so the filter may be the option
available from phone shops or places like JAYCAR
Jul 11, 2017 | Uniden Cordless Phone
Static noise from car stereo
change youre speakers they are blown if they are making staticy sounds i have recently chnged my speaker cuz of the static and it was kuz they were blown
thats all i can think about
hope it works
Oct 28, 2008 | iLO XM-MP3-CD Car Stereo
Static
git a good grond on it or it will go sky hi
Dec 05, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
