Question about Canon Office Equipment & Supplies
Paper when out put then see spot in middle page portate
When paper easyly out but spot in paper middile site partate condition
  • 29 Answers
I don't know the model of Canon Copier you have, and I don't know if your problem happens when you copy and print, or only when you copy, so it's hard to tell with the little information you've provided.
Let's assume the easiest solution is the correct one...
Is the "Spot" in the same location on every copy? Then clean glass.
does the spot move left to right across the page with each successive copy? Then replace the drum unit.
Posted on Sep 12, 2009
My lexmark x544 gets a black line down the page when i put it in the tray feeder. What do I do?
Is the black mark in the same place on all print outs? If so, it could be that the paper feed rolls may be dirty.
Oct 16, 2014 | Lexmark X544dn All-In-One Laser Printer
I have an HP 4515 and we are getting black spots on various pages. Is it time to replace the fuser assembly
Put paper in the manual feed tray. Print a few pages. As the paper gets pulled half way into the printer, open the top cover, pull out the toner and look down at the paper. If you see the spots replace the toner. If you don't see the spots replace the fuser.
Nov 22, 2011 | HP P4515n LaserJet Printer
When I fax or make copies using the document feeder there is a line that runs down the middle of the page, this does not happen when using the glass for single pages. What can I do
Get a paper towel and a little glass cleaner and clean all the glass under the doc feeder. The line comes from the scanner seeing a spot as the paper is passed by it.
Aug 25, 2010 | HP Officejet 6500 Wireless All-in-One...
Sharp AL-1631 bottom paper feed will not pick up paper.
A few things could be the problem.
  1. The paper in tray could be damaged
  2. The drawer separator pawls (metal taps on the right side of tray where paper touches)
  3. Paper backstop not in or in wrong spot (green plastic piece at back of paper)
  4. Feed tires are worn or dirty
Does the copier try and feed from tray 2? If it tries but the paper doesn't leave the try look and see if there is a dark mark on the page (top middle towards the right). If so then most likely the feed tire is worn.
Oct 12, 2009 | Sharp AL 1631 Copier
How do i restore my laptop when system restore
Your DV 6000 came from the factory with a recovery partation as well as a partation for your user files and data.
If you have not removed this partation, you may be able to bring this partation back into play by hitting F-11 while starting unit.
If the partation is damaged or if you have hard disk damage, this will be useless...
Give it a try, F-11 when starting unit.
Hope this has helped.
Jul 23, 2009 | HP Pavilion DV6700Z Notebook
Where are these taps located ?
What is tape such as docoments position if the machin is supported canon middile position or kyocera supported left position or you quary middle left or right
Jun 28, 2009 | Dell 1125 All-In-One Laser Printer
My brother 775 fax machine when makin a copy of something on it, it leaves a black strip right down the middle of the page what causes this?
either the exposure glass is dirty of it has a dead spot on the exposure lamp assembly, open the area the originals are fed through, you should see a long narrow peice of glass, if this has a spot or streak on it it will transfer that to everything that passes through. Clean the glass throughly with a good quality glass cleaner and a soft paper towel. then try again.
Hope this is of some help.
Ed
Apr 26, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Paper tears when printing
Helllo sir; I would say 99 % you have paper chip stuck in the paper path , ckeck the fusing unit,
Apr 14, 2009 | HP Color LaserJet 2600n Printer
Brother all-in-one printer
According to page S-1 of the Specifications chapter of the Users Manual, the maximum paper weight that the MFC-3240C can tolerate is 80 g/m². This section of Wikipedia's article on Paper says that anything over 160 g/m² ranks as card stock, which includes your 180 g/m² matte paper. Card stock has choked just about every inkjet printer into which I've seen it fed, but even if that was not so, you are still using paper that is more than twice the "legal limit."
May 08, 2008 | Brother MFC-3240C All-In-One InkJet...
Copies paper great except leaves a long invisible 1 inch thick line down the middle
You can try to clean the scanner light, but the light does not cast a straight one directional beam. It is more like a flood light, if one spot is blocked it will still cast light on that spot of the paper.
Try checking the print cartridge. Normally if it is an inkjet copier, it will leave a line in one spot if there is a defect in the cartridge or if it is running low on ink.
I woul try another cartridge first, then we can go from there.
Feb 13, 2008 | Canon PC1061 Copier
35 people viewed this question
old marine
old marine
