Question about Samsung SGH-D900 Cellular Phone
Wap/mms settings for Samsung E490
How can we download the settings for wap here in saudi? it seems that we already tried all the options but still it won't work. we tried to call to local server and it seems that the settings is available but when we tried to send the settings the phone can't accept the configuration.
  • Anonymous Mar 22, 2014
    All I find for apn setting changes don't work and have 2 apn inputs but my phone only has one place to put apn options are default mms. Supl. Wap. Doesn't have mms apn spot. How can I get it to work
    Brigadier General:
  • 7,752 Answers
You will need to contact your mobile service helpdesk and ahve them assist you with it.
Posted on Jun 29, 2008
SAMSUNG SCH MICF399 SOLUTION
Setting answer options - Samsung Convoy (SCH-u640)
  1. From the main screen, press OK to choose MENU.
  2. Select Settings & Tools then press OK.
  3. Select Call Settings then press OK.
  4. Select Answer Options then press OK.
  5. Select the desired option, press OK to choose MARK then press the left soft key to choose Done. Flip Open Answer calls when the phone is opened.
    linote.gif Speakerphone is automatically activated. Any Key Answer calls by pressing any key. Auto w / Handsfree Automatically answer calls with a handsfree device On the main screen type *#06#
    Information you get from the IMEI (International Mobile Equipment Identity)
    XXXXXX XX XXXXXX X
    TAC FAC SNR SP
    TAC = Type approval code of your samsung Mobile
    FAC = Final assembly code of your cellphone
    SNR = Serial number of your samsung Phone
    SP = Spare
*#06# IMEI code
*#9998*4357# Help Menu
*#9998*5282# Java menu (GRPS/CSD settings for JAVA server)
*#9999#0# Monitor Mode
*#9999# or *#9998*9999# Software Version
*#8888# or *#9998*8888# Hardware Version
*#9998*746# or *#9998*0746# or *#0746# Sim Infos
*#9998*523# or *#9998*0523# or *#0523# Display Contrast
*#9998*842# or *#9998*0842# or *#0842# Vibration On (until you push OK)
*#9998*289# or *#9998*0289# or *#0289# Buzzer On (until you push OK)
*#9998*288# or *#9998*0288# or *#0288# Battery & Field Infos
*#9998*377# or *#9998*0377# Error log
*#9998*778# or *#9998*0778# or *#0778# Sim Service table
*#9998*782# show date and alarm clock
*#8999*638# show network information
*#9998*5646# change operator logo at startup
*#9998*76# production number
*#9998*968# view melody for alarm
*#9998*585# Non-Volatile Memory (NVM)
*#3243948# Digital Audio Interference Off
*#32436837# Digital Audio Interference On
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
*#8999*8378# Test Menu
*#4777*8665# GPSR Tool
*#8999*523# LCD Brightness
*#8999*377# Error LOG Menu
*#8999*327# EEP Menu
*#8999*667# Debug Mode
*#92782# PhoneModel (Wap)
#*5737425# JAVA Mode
*#2255# Call List
*#232337# Bluetooth MAC Adress
*#5282837# Java Version
Type in *#0000# on a Samsung A300 to reset the language
Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not E710)
Samsung E700 type *#2255# to show secret call log (not tested)
Samsung A300, A800 phone unlock enter this *2767*637#
Samsung V200, S100, S300 phone unlock : *2767*782257378#
#*22671# AMR REC START
#*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
#*22673# Pause REC
#*22674# Resume REC
#*22675# AMR Playback
#*22676# AMR Stop Play
#*22677# Pause Play
#*22678# Resume Play
#*77261# PCM Rec Req
#*77262# Stop PCM Rec
#*77263# PCM Playback
#*77264# PCM Stop Play
#*22679# AMR Get Time
*#8999*364# Watchdog ON/OFF
*#8999*427# WATCHDOG signal route setup
*2767*3855# = Full Reset (Caution every stored data will be deleted.)
*2767*2878# = Custom Reset
*2767*927# = Wap Reset
*2767*226372# = Camera Reset (deletes photos)
*2767*688# Reset Mobile TV
#7263867# = RAM Dump (On or Off)
#*4773# Incremental Redundancy
#*7785# Reset wakeup & RTK timer cariables/variables
#*7200# Tone Generator Mute
#*3888# BLUETOOTH Test mode
#*7828# Task screen
#*#8377466# S/W Version & H/W Version
#*2562# Restarts Phone
#*2565# No Blocking? General Defense.
#*3353# General Defense, Code Erased.
#*3837# Phone Hangs on White screen.
#*3849# Restarts Phone
#*7337# Restarts Phone (Resets Wap Settings)
#*2886# AutoAnswer ON/OFF
#*7288# GPRS Detached/Attached
#*7287# GPRS Attached
#*7666# White Screen
#*7693# Sleep Deactivate/Activate
#*2286# Databattery
#*2527# GPRS switching set to (Class 4, 8, 9, 10)
#*2679# Copycat feature Activa/Deactivate
#*3940# External looptest 9600 bps
#*4263# Handsfree mode Activate/Deactivate
#*2558# Time ON
#*3941# External looptest 115200 bps
#*5176# L1 Sleep
#*7462# SIM Phase
#*7983# Voltage/Freq
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*5376# DELETE ALL SMS!!!!
#*6837# Official Software Version: (0003000016000702)
#*2337# Permanent Registration Beep
#*2474# Charging Duration
#*2834# Audio Path (Handsfree)
#*3270# DCS Support Activate/Deactivate
#*3282# Data Activate/Deactivate
#*3476# EGSM Activate/Deactivate
#*3676# FORMAT FLASH VOLUME!!!
#*4760# GSM Activate/Deactivate
#*4864# White Screen
#*7326# Accessory
#*7683# Sleep variable
#*3797# Blinks 3D030300 in RED
#*7372# Resetting the time to DPB variables
#*3273# EGPRS multislot (Class 4, 8, 9, 10)
#*7722# RLC bitmap compression Activate/Deactivate
#*2351# Blinks 1347E201 in RED
#*2775# Switch to 2 inner speaker
#*7878# FirstStartup (0=NO, 1=YES)
#*3838# Blinks 3D030300 in RED
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
*#7465625# = Check the phone lock status
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
Feb 14, 2012 | Samsung Cell Phones
I have a cect n97c and i can't seem to get the settings correct in the the phone to be able to send and receive mms. I've called t-mobile 20 times and they finally told me that i needed to contact the...
Create Data Account
3. Select Services
4. Select Data Account
5. Select GPRS
6. Choose an empty profile
7. Account Name enter T-Mobile WAP
8. Press Options
9. Press Done
10. APN enter wap.voicestream.com
11. Press Options
12. Press Done
13. User Name >Leave Blank<
14. Password >Leave Blank<
15. Auth. Type choose Normal
16. Press Done
17. Press Save
T-Mobile MMS
Create Profile
3. Select Services
4. Select WAP
5. Select Setting
6. Select Edit Profile
7. Select a profile
8. Choose Edit Profile
9. Rename Profile enter T-Mobile WAP
10. Homepage enter wap.myvoicestream.com
11. Data Account select GPRS
12. Select T-Mobile WAP
13. Connection Type select HTTP
14. Proxy Address enter 216.155.165.050
15. Port enter 8080
16. User Name >Leave Blank<
17. Password >Leave Blank<
18. Press Done
19. When prompted to SAVE please select Yes
20. Select Activate Profile
21. When prompted to Activate Profile please choose Yes
22. Press Done
Create Data Account
3. Select Services
5. Select GPRS
8. Press Options
9. Press Done
11. Press Options
12. Press Done
16. Press Done
17. Press Save
Create Profile
3. Select Messages
4. Select MMS
5. Select Message Setting
6. Select Server Profile
7. Select a Profile
8. Select Edit Profile
9. Select a profile
10. Choose Edit Profile
11. Rename Profile enter T-Mobile MMS
12. Homepage enter http://216.155.174.84/servlets/mms
13. Press Options
14. Press Done
15. Data Account select GPRS
16. Select T-Mobile WAP
17. Connection Type select HTTP
18. Proxy Address enter 216.155.165.050
19. Port enter 8080
20. User Name >Leave Blank<
21. Password >Leave Blank<
22. Press Done
Reboot your phone
this should work i had the same problem
Mar 12, 2010 | Cell Phones
I just purchased samsung gt-b3310 and it will not allow me to text from the qwerty keyboard. Is there something I need to unlock...what should I do?
WAP Settings:
Menu --> Internet --> Settings --> Browser Profiles --> Options --> Create --> Profile Name: WAP Profile, Home URL: http://att.home, Proxy: check box, IP Address: 066.209.011.032, Port: 8080, Linger time (sec): 90, leave DNS box unchecked, GPRS2_bing.gif --> Advanced Settings --> APN: wap.cingular, Login ID: WAP@CINGULARGPRS.COM (case sensitive), Password: CINGULAR1 (also case sensitive). Hit "save" twice then "options" then "activate." This will allow you internet access.
MMS settings:
Menu --> Messages --> Settings --> Multimedia Messages --> MMS Profiles --> Options --> Create --> Profile Name: AT&T MMS, Home URL: http://mmsc.cingular.com, check the box next to "proxy", IP Address2_bing.gif: 066.209.011.032, Port: 8080, Linger Time (sec): 90, leave DNS box unchecked, Bearer: GPRS then go to Advanced Settings --> APN: wap.cingular, Login ID: wap@cingulargprs.com, password: CINGULAR1 (case sensitive). Hit "save" twice, then "options" then "activate." This will activate your MMS so you can send and receive picture messages.
Thanks,
Gus
www.24hrsDeals.com
Feb 15, 2010 | Samsung B3310 Cell Phone
Have samsung b3310 but can't receive or send pics on ATT
Try these they worked for me & I have the same phone:
MMS settings:
Menu --> Messages --> Settings --> Multimedia Messages --> MMS Profiles --> Options --> Create --> Profile Name: AT&T MMS, Home URL: http://mmsc.cingular.com, check the box next to "proxy", IP Address: 66.209.11.32, Port: 80, Linger Time (sec): 90, leave DNS box unchecked, Bearer: GPRS then go to Advanced Settings --> APN: wap.cingular, Login ID: wap@cingulargprs.com, password: CINGULAR1 (case sensitive). Hit "save" twice, then "options" then "activate." This will activate your MMS so you can send and receive picture messages.
WAP settings:
Menu --> Internet --> Settings --> Browser Profiles --> Options --> Create --> Profile Name: WAP Profile, Home URL: http://device.home, Proxy: check box, IP Address: 66.209.11.32, Port: 8080, Linger time (sec): 90, leave DNS box unchecked, GPRS --> Advanced Settings --> APN: wap.cingular, Login ID: WAP@CINGULARGPRS.COM (case sensitive), Password: CINGULAR1 (also case sensitive). Hit "save" twice then "options" then "activate." This will allow you internet access.
Hope this helps!!
Feb 14, 2010 | Samsung B3310 Cell Phone
Does Anybody know the GPRS setting of Apple iphone in Saudi Arabia ( For Mobily )
Dear Friends, HERE IS MOBILY SAUDI ARABIA GPRS SETTING / INTERNET SETTINGS HERE
FOR MMS Settings
1. Server Name : Mobily MMS
2. Gateway : 10.3.2.133
3. Port Number : 9201
4. Server Address :
http://10.3.3.133:9090/was
5. Connect Via : Mobily MMS
6. Size Limit : 100kB
7. WAP Version : WAP 1.2
FOR GPRS SETTINGS
1. Operator Name & Country : Mobily - Saudi Arabia
2. Network Name : WEB GPRS
3. Modem Name : WEB GPRS
4. Modem Access Point Name : web2 (web1 for postpaid lines)
5. Username : ""
6. Password : ""
7. Domain : ""
(if blank insert "")
8. Is there a tick in the 'This network connects to the Internet' box : Yes
9. Is there a tick in the 'This network uses a proxy server' box : Yes
10 Proxy Server Address and port : 10.3.2.133:8080
(10. IS NOT NECCESSARY TO ENTER)
ENJOY INTERNET AND PLEASE PRAY DUA FOR ME AND MY FAMILY take care - sameer2789@yahoo.co.in
May 25, 2009 | T-Mobile Samsung SGH-i900 OMNIA mit 16GB...
I9 wap/gprs & mms settings for O2
First you have to make 2 data accounts,
1 for wap,
1 for mms.
Press service,
Data account,
GPRS, ok,
Pick any one of the settings because you are going to change it,
Press edit.
account name edit to O2 WAP GPRS,
APN to payandgo.o2.co.uk,
user name to payandgo,
password is password,
authentication type normal,
after each one if done is the option press it. this is the setting for wap internet.
You have to do the same again to make a new data account for the mms. the settings for this is
account name O2MMS,
APN payandgo.o2.co.uk,
user name payandgo all others same as before.
Now you have 2 new data accounts you need to set up wap.
press service, wap, settings, edit profile, sim 1 or 2 which ever you are using,
select the O2 WAP GPRS account that was made earlier,
press ok. press edit profile,
rename profile is ok it is O2 WAP GPRS,
edit home page to http//wap.o2.co.uk,
set data account to O2 WAP GPRS,
connection type wap, IP address 193,113,200,195
user name payandgo,
press back and activate profile.
you should be able to get on to o2 homepage now.
To get mms
press text, mms, mms settings, server profile, sim which ever you are using 1 or 2 ,
select the O2 MMS made earlier, edit profile, rename profile is 0k should be O2 MMS, home page is http//mmsc.mms.o2.co.uk:8002,
data account is the O2 MMS you made before,
MMS IP address 193,113,200,195
user name payandgo,
select back when all settings are entered and select activate profile. this should be it.
This works OK for me.
Mar 23, 2009 | Dual Electronics CECT P168 Cellular Phone
To activate gprs in htc p3350
Thank you for choosing Fixya.com
Please follow the instruction below very carefully and make sure that you have load of your sim enjoy.
For Globe Subscribers:
For a complete listing of compatible MMS & GPRS phone handsets — send NOKIA, ERICSSON or SAMSUNG (your handset model) to 2365.
To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1)
Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
Enter 1234 when asked for PIN to save settings.
Send an MMS message for only Php 5.00 to activate the service.
Note: For prepaid subscribers, please make sure you have credits first before trying to access GPRS/MMS. You won’t be able to use the service if you have zero balance.
For Smart Subscribers:
OTA (over-the air) configuration
a) To activate GPRS *and* MMS
- SET MMS send to 211
- wait for the configuration to be downloaded to your phone (up to 24 hours)
- once downloaded, you will have SmartMMS data account, and SmartMMS WAP profile, and your MMS is configured already to use SmartMMS WAP profile
- you will also receive a confirmation message that your GPRS and MMS have been activated
b) To configure internet access (full access)
- SET INTERNET (handset model) send to 211
- wait for the configuration to be download to your phone, in minutes
- once downloaded, you will have SmartPC data account, and SmartPC WAP Profile
- edit this account to include DNS settings. DNS IP addresses are -202.057.096.003, 202. 057.096.004. you only need one.
c) To configure WAP via GPRS
- SET GPRS T68 send to 211
- once downloaded, you will have SmartGPRS data account, and SmartGPRS WAP Profile. SET THIS AS YOUR DEFAULT PROFILE
d) To configure WAP via CSD (Optional - kasi MAY BAYAD ITO, per minute)
- SET WAP T68 send to 211
- once downloaded, you will have SmartWAP data account, and SmartWAP WAP Profile. SET THIS AS YOUR DEFAULT PROFILE
I suggest you clear all your existing data accounts and wap profile beforeyou do this. If you follow the instructions in this order, SmartPC will have a CID=2. Your dial-up number willbe *99***2#
or to simplify it:
Setting up of MMS and GPRS handsets:
To download SMART MMS phone settings, key in SET MMS and send to 211.
To download SMART GPRS phone settings, key in SET GPRS and send to 211.
Activating SMART MMS and GPRS:
To activate SMART GPRS, key in GPRS ON and send to 333.
To activate SMART MMS, key in MMS ON and send to 333
Upon receiving the configuration settings, select "Save All" to save the settings in the phone.
Activation of MMS and GPRS will require a confirmation message from SMART. A message will be sent to the sub once the feature has been activated.
For SUN USERS:
Sun MMS
On the home screen, press the Programs soft key, press More to move to the next page.
Press Accessories then select MMS Setup by pressing the Action button.
Provide the following data on the required field, press Ok when done.
q First field: MMS connection
q IP: 202.138.159.78
q Port: 9201
q MMSC Address:
q Message Expiry: 1 day
q MMS Download: Auto
Press Settings, select Data Connection.
Press the Menu soft key then select Edit Connection by pressing the Action button
Select GPRS Connection. Press Menu then select Add by pressing the Action button
Provide the following data on the required field:
q Description: Sun MMS connection
q Connects to: MMS Connection
q Access point: mms
When finished, press Done four times.
Sun GPRS
Press the Menu soft key then select Edit Connection by pressing the Action button.
Select GPRS Connection. Press Menu then select Add by pressing the Action button.
q Description: Sun GPRS
q Connects to: The Internet
q Access point: minternet
Press Done three times. On the Data connection, select Sun GPRS under Internet connection.
When finished, press Done.
Sun WAP GPRS
q Description: Sun WAP GPRS
q Access point: mms
Press Done three times. On the Data connection, select Sun WAP GPRS under WAP connection.
Sun WAP Proxy
Crate a proxy connection
Description: Sun WAP Proxy
Connects from: The internet
Connects to: WAP network
Proxy (name/Port): 193.113.200.195
Type: WAP
To Activate GPRS:
Create a text message, type "ACTIVATE" then send to 2300
please don't forget to rate our answers properly.
Feb 23, 2009 | HTC P3300 Smartphone
Mms and wap
try to restore factory settings of your Samsung and then try again to have wap configuration . that should help you .
your rating is very important for me , that's why I've helped you
good luck
Jun 06, 2008 | Samsung SGH-U600
Samsung SGH-D900 Cellular Phone Logo
131 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
