Question about GE Nautilus 24" Built-in Dishwasher
When i turn my dishwasher on it runs it wont change cycles and wont wash stays in the same cycle
  • 268 Answers
This sounds like a bad timer.
It could also be a defective thermostat. This problem will become apparent with the water heat option selected. Check by running the dishwasher with this option de-selected and see if it proceeds normally through the cycle.
Hope this helps.
Posted on Sep 10, 2009
My GE dishwasher will not change cycles when pressing the normal wash cycle button. The lights are all on, but I cannot change the cycle from light wash to normal wash. Any ideas? Can it be reset?
Most likely the keypad will have to be replaced. If the lights change, but the cycle stays on light, it's in the control module or the switch.
Have you tried cutting the power to the unit and re-powering? If it's connected to an always on circuit, shut off the fuse that controls it and turn it back on in a minute.
Jul 11, 2015 | GE Dishwashers
Samsung DMT300RFW Builtin Dishwasher will not run past wash cycle. I start it and it fills and the wash cycle starts but won't cycle past the wash cycle. No error codes.
What do you mean, it won't "run past the wash cycle"? Do you mean it stays in the wash cycle forever? Or do you mean it quits in the wash cycle and doesn't rinse or dry?
Oct 18, 2014 | Samsung DMT300RFW Builtin Dishwasher
My dishwasher wont drain.. water stays in the tank..
When you run a dishwasher, there is usually food particles left over from a cycle. First thing is to check the lent screen. The lent screen is located on the bottom usually in the back of the dishwasher. If you want to put some gloves on and remove it and turn on the drain cycle on your dishwasher. If that doesn't do it turn off the power to the dishwasher by the breaker box, and check your hoses inside the dishwasher.
May 11, 2011 | Maytag 24 in. Built-In Dishwasher w/...
When i push the normal wash button and it changes to another cycle after a few minutes then wont run at all just freezes up some water was in the basin modelmdb9100
What you're describing as changing to another cycle may be the dishwasher trying to display diagnostic information. For example, if you ran a Normal cycle and it appears to switch to Light Wash, check to see if the "Clean" indicator is also lit. This would indicate a motor fault, which would explain why it appears to "freeze".
May 12, 2010 | Maytag MDB9100A Dishwasher
My dishwasher is seeming to stay on the wash cycle. How long is a normal wash cycle?
Dishwashers today use a lot less water and energy to do this they filter the water like crazy this makes the wash times go way up, the motor used today uses only a little power so a long cycle does not cost much.
They average wash time for a new machine is 90 - 120 minutes. Some high efficiency units can run 4 hours per cycle.
Apr 24, 2010 | Kenmore Dishwashers
Will not change cycles
please give model and make of machine but sounds like the module
Feb 24, 2010 | Dishwashers
Washing cycle wont complete
I had the same problem. Called the repair man, who said it was a defective control board. He ordered a new one, replaced it and now the problem is fixed.
Dec 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher wont go through the cycles
Hi. this will occur when the timer control or control board has experienced a major fault within the circuitry. in most cases, the actual timer mechanism will fail. this will stop the forward advancement of the wash cycle.
Total replacement of the timer control module or control board will fix this issue.
Jul 19, 2009 | Dishwashers
How long does it take a cycle to run? The wash light stayed on but when I turned it off it was already dry
the cycles take between 75 minutes and two hours depending upon which cycle and chich machine.
Jun 17, 2009 | KitchenAid KUDR01TJ Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
210 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
