GE Washer WPSR3100W1WW the agitator is very lose and water is leaking down into the gearbox.
    Brigadier General:
  • 3,513 Answers
Thank You for contacting Fixya.com
Inorder to fix the agitator I would request you to please follow the step by step troubleshooting mentioned in the bellow mentioned link:
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Have a nice day.
GodBlessU
Posted on Sep 10, 2009
How to replace seal of ge top load washer
You have asked a number of questions. How old is the Washer?
Based on your questions, it may be time to replace. No I am not a
GE Rep. Parts can be ordered online. Google Appliance parts. They may be able to help with "how to's". If newer machine, still warranty? If so check with GE. Otherwise, if the tub isn't being over filled and spin out doesn't send water outside the outer tub which could explain the dripping. Verify gasket leak by leaving water in tub and measure height of water very carefully let stand several days and remeasure.
Remove top should be springs on the front. Push in, to release, tip-up top. Tub must be removed. Remove the agitator by removing the top plastic, should reveal top nut holding down the agitator. You will see a number of nuts holding the agitator tower to reveal gasket. There may be rusting and pin holes causing the leak. I would check this before attempting gasket. I had a similar issue, used JB Weld epoxy about 5 year ago, still not leaking. Possibly the agitator tower has a seal leaking at top. If so that is in transmission and should be replaced as well as the bottom gasket. It may be $200 part.
Due to all the trouble, I replaced it to prevent future failure. You may find a lightly used replacement washer for about that price.
Nov 18, 2014 | GE Washing Machines
Oil in the bottom of washer
The oil is leaking out of the agitator gearbox. The water is coming from the seal on the agitator. I think the gears are badly worn..
Nov 19, 2013 | GE Washing Machines
Model wdss4120aww GE Washer is leaking
If it's leaking during the agitation cycle, and only in 'large' and 'super' water levels, then that's just the way the washer is designed. I got rid of that piece of junk.
Mar 03, 2013 | GE WBSR3140D Top Load Washer
Ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Aug 21, 2009 | GE Profile WPSR3100W
Leaking water while agitating
it sounds like a bad bearing... the tub is leaking it may leak into the bearing and cause your transmission to lose oil and water ...
Nov 29, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
I have roper washing machine
I don't know if the agitator is turning or not but the whole agitator is lose from the bottom part of the agitator. The washer also leaks. We have checked all of the hoses etc and there is no problem with that. We wonder if the leak isn't coming from the agitator being lose.
Nov 07, 2008 | Roper RAS8445KQ Top Load Washer
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
Washing Machines Logo
195 people viewed this question
Top Washing Machines Experts
