Question about GE Profile JDP47 Electric Kitchen Range
F7 code flashes and beeps
I have a GE jdp47. The F7 code comes on with the beeps. I tried turning off the circuit breaker for the range,waiting a few minutes, and turning it back on. It works fine for about 5 min. then the F7 code comes back on again and the oven is inop. The stove top works fine. I would appreciate any suggestions you may have for this problem
Aloha,
Pineapple
  • pigfordinner Dec 10, 2007
    I found out that the F7 code is a control panel problem. I bought one for $111.00 and replaced it. Works like new. Thanks anyways for this service.
    Aloha....................
  • 725 Answers
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Sep 21, 2009
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
GE Profile 30" slided in range/oven. Ran standard
shut down the power to the machine,disconnect the touchpad ribbon,turn the power back on and let it sit for a day,if the code comes back you have a bad board,if it doesn't come back you have a bad touchpad
Apr 02, 2011 | GE Profile 30" Self-Cleaning Slide-In...
F7 screens flash and beep,but not every time we use range
There's a lot of info missing here, but any tech should be able to tell you what the F7 indicates. Each F code indicates a specific problem. In my case, an F-1 indication which says the circuit board has a problem, was resolved easily by fixing a problem with the momentary contact convection oven switch. You may have a faulty switch like that which could be causing the problem--in all likelihood, it was NOT a circuit board problem. If it was, then it was caused by another problem somewhere else, and they owe you a new circuit board, and a repair on whatever is causing the circuit board to fail. But more than likely they owe you a refund for the board you bought, and a fix on whatever is causing the problem....
Jan 29, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Nov 17, 2008 | GE JKP45 Electric Double Oven
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Dead Control Panel - F7
Easiest fix: open the circuit breaker for the stove...wait a minute and reset. Should get you going.
Sep 23, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
F7
No F7 in my tech sheet Could it be a F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad if you want to do it yourself let me know...
Aug 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven and keypad will not work.
longtallez The first thing I would recommend you to do is to reset the power. Locate the circuit breaker for the range and turn it off, wait a few minutes and turn it back on. It works the same way like you reboot you PC when it gets stocked. Let me know if it would not help and we will go further. Gendos...post back
Jan 16, 2007 | GE Profile JDP47 Electric Kitchen Range
Open Questions:
See all GE Profile JDP47 Electric Kitchen Range Questions
GE Profile JDP47 Electric Kitchen Range Logo
686 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
