Question about Samsung DVD-V2500 DVD Player
Clock is not keeping time
Dvd=-sh853m clock is not keeping time I set it to the correct time and the next day iit is slow
  • Samsung Expert
  • 244 Answers
Try doing a complete re-tune
Posted on Sep 11, 2009
Radio controlled Barolo Clock with hands keeps resetting an hour behind.
It sounds like it is receiving a DST signal instead of an MSF signal or vice versa depending on your country, they are one hour apart.
Unless this clock has a choice of signal settings the best way is to gently remove and reset the hour hand to the correct hour.
Mar 04, 2014 | Trenkle Uhren Cuckoo Clock Quartz-movement...
How to set the time on dmr eh59
Automatic clock setting is done if you initially accept to use the guide plus system (should do). Only if for some reason it does not work, you can set the clock manually following these steps Clock Usually, the unit's setup function automatically adjusts the
clock to correct time. Under some reception conditions, however,
the unit cannot set the clock automatically.
In this case, follow the operation steps below to manually set the clock.
1 Press [3, 4] to select "Off" of "Automatic" and press
[OK].
2 Press [2, 1] to select the item you want to change.
The items change as follows:
Hour,Minute,Second,Day,Month.Year
3 Press [3, 4] to change the setting.
You can also use the numbered buttons for setting.
4 Press [OK] when you have finished the settings.
The clock starts.
If a TV station transmits a time setting signal, and when
"Automatic" in the Clock setting menu is set to "On", the automatic
time correction function checks the time and if necessary it is
adjusted several times every day.
Sep 25, 2012 | Panasonic DMR-EH59 250GB Multi Zone Region...
How to operate howard miller clock 645-342
Make sure all winding springs are wound well- but not overly tightened and set pendulum in motion. The clock needs to level across the face and front to back to work correctly. Time can be adjusted by moving the hands of the clock via the minute hand- allow it to strike once at each strike interval to keep strikes synched to clock time, and fast or slow can be adjusted by either the adjustment onthe pundulum arm or on the mechanism where you see an arc with "F" and "S" on either end.
Depending on model, it will need winding at least as often as the name of the clock type- in other words, a seven day clock should only need to be wound every 7 days.
Sep 17, 2012 | Welding Tools
Sony IFC-218 clock radio runs 8-9 minutes fast
Hold the 'Clock' button until the display flashes. It will first show the year, next press on 'Clock' with show the month, then the day, then the time. Use + and - to set your time and press 'Clock' again.
Don't expect this clock to set the time by itself. It is not an atomic clock.
Nov 29, 2011 | Sony Audio Players & Recorders
The clock on our RD-XV48DT is showing the incorrect date (4th March instead of 1st March). We cannot re-set the clock manually (it just reverts to the wrong date), and we can't turn off the "clock...
i've got the same problem. looking arround the internet lots of people had the same thing last year & it corrected itself the next day. (2 march)
fingers crossed
Mar 01, 2011 | Toshiba D-R5 DVD Recorder
My Nokia 5310 XpressMusic has problem with time settings. Whenever i set the clock 5min faster, after some hours i find the clock settings 5min slow OR if i switch off and then on my Handset, my clock is...
If there is a problem in the received mesage time, Do set your time settings as :
Time Zone: GMT +5:30
Day Light Saving as +0
And do restart your handset. This will solve your problem.
Mar 19, 2010 | Nokia 5310 Cellular Phone
RCA model DRC8335 Loosing the date and time
That will be a problem from the text side of the broadcast, the clock is set from the text transmission, ( in other words a problem from the transmitter ) possibly due to digital switchover or work on the transmitters. One possible solution would be to turn off auto clock setting, and/or auto summer time adjustment.
May 16, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
SkyScan 87801 how to reset time
Keep pushing the set button until dst shows on the date window then see the clock window it will read on or off press the + button for on or off.
Sep 15, 2008 | SkyScan 86709 Atomic Wall Clock
Timer
After you set the time ,do you push the Clock button to lock your time??If you set the clock time and walk away its not holding the time ,because its waiting for you to confirm time selected.So after you set the time press the clock key pad 1 more time .Remember this, just because you bought a new clock doesnt mean its a good part.Bad parts get the best of us ,so dont think your new part is ok yet.It probably is not.
Aug 16, 2007 | Rangemaster Proffessional 110 Gas Kitchen...
Samsung DVD-V2500 DVD Player Logo
143 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
