Question about The Cellar STC55800 / STC55810 / STC55820 Wine Cooler
Looking for replacement power supply for STC55800 or parts...
Tried replacing power supply still no power any suggestions
The set needs to be professionally diagnosed !!! Are you sure the power supply board you bought was working? If the power supply board is a good part, the you're looking at a main board issue.
Aug 30, 2012 | LG 42LC2D 42 in. LCD HDTV
When switched off takes a long long time to get it on again
Tv have a power supply board problems.That the board where the tv power a/c cord plug into it.U have all the tools and know and understanding basic electronic also can do basic soldering work too?Yes,take the tv aparts and check the tv power supply board carefully,looking for dying and leaking components parts that are calling capacitors parts.These capacitors parts are dying and leaking are alway bulges up or puffing up on to it tops.These dying and leaking capacitors parts must be replaced,will help the tv power on quickly again.Replacing new capacitors parts,with the same Micro Farad but the voltages should go over to 5 or 10 voltages over the old capacitors parts u are replacing.This way the new capacitors parts u are replacing will with stand heat better,will not dies to soon like the old capacitors was on the power supply board before.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 11, 2011 | LG 32LD450 32 In. LCD HDTV
Looking for a 715L1075-1-v Ver B power supply
>> 715L1075-1-V1 PC MONITOR - POWER SUPPLY FOR VIEWSONIC N/A TV
Once you have the _correct_ part-number, you can buy it online:
http://www.discount-merchant.com/We-provide-factory-original-parts-worldwide-p/1049626-viewsonic.htm
Sep 19, 2009 | ViewSonic VX910 19" LCD Monitor
Samsung spn4235 need power supply
You can order the original Samsung replacement Power Supply Board for this model (SPN4235) from a major Samsung parts distributor at the link below:
Samsung SPN4235 Replacement Part SMPS Switch Mode Power Supply Board
Apr 08, 2009 | Samsung SPN4235 42 in. Plasma HDTV
The fan to disperse air inside the STC55800 wine cooler is inoperable.
9721, Boul Métropolitain Est
Anjou, QC, Canada
H1J 3C1
Telephone : 514-374-5343
Fax : 514-374-5344
Oct 04, 2008 | The Cellar STC55800 / STC55810 / STC55820...
Power supply "Starmen TOD0851212" for my AKAI 20
If you can do it yourself replace C31 (1000 25v) also good idea to replace C32,35 also (1000 uf 25v). Theres also C33 (680 uf 25) if you want to replace it.
Dec 01, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
The Cellar STC55800 / STC55810 / STC55820 Wine Cooler Logo
65 people viewed this question
Top The Cellar Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a The Cellar Furniture Expert? Answer questions, earn points and help others
