Question about Canon i9900 InkJet Photo Printer
Most of Group 1inks,(except red) won't print
Bought new compatible cartridges from www.4inkjets.com. Four out of eight don't release the inks on nozzle check, test page or print head alignment. Also installed a new genuine "spare"printer head, because of prior cyan and magenta problems, previously ). After alignments, several regular and deep cleanings for group 1, cleanings etc. still can't get Bk, G, PC, PM to print. When I look inside printer, the waste ink pad looks full, (from all the attempted cleanings on a 4-year old printer) but no pop-up warning or alert, but the "guts" look saturated and dirty, and some ink over-flow blobs on interior "carriages" which I've attempted to clean, gently, with head cleaner and cotton swabs, and waste ink pad. Tried almost everything, except uninstalling and reinstalling printer, from purchase software discs. Running out of options, except replacing a $400, 4 yr old wide-format Canon i9900 printer. How do I know if "compatible" cartridges are just defective? HELP! Can't seem to narrow down the problems....THANKS...Lin
  • hitabandita Sep 24, 2009
    Thanks, but still couldn't solve myself, so took to Canon authorized service facility, with your comments for purge assembly unit, hose, and ink waste pads. I've read a lot of advice re: manual cleaning of print head, to newer drivers, to caveats about using "so-called" 100% compatible ink cartridges, to refilling cartridges with cheaper inks etc. Still not sure where the problem is. Canon ASF said "yet another" new print head and absorber pad replacement, and said little about the "purge unit" or hose?
    Is my recurrent problem due to trying to economize on compatible inks and cartridges with generics? Is it false advertising for companies to say 100% compatible for inks or ink cartridges? I buy several, at a time to take advantage of multiple purchases or free shipping. Is it false economy if generic inks or cartridges are causing (?) printer problems?
    Nobody really addresses that! Of course, Canon only recommends OEM's, but about 6+ x higher cost than compatibles. If printer is out of warranty, repairs can add up fast I recognize new ink absorber pads are likely needed, and inaccessible for the average consumer, so OK, but I can find cheaper oem's on the internet, for print head and supplies, and can do a lot myself. Not sure about the "mystical" purge unit or hose connections! Money's tight everywhere esp. for retirees, fixed income folks, starving artists,etc. but we keep trying to keep stuff maintained and operating. I'm going to be "pissed" if it was a simple fix or DIY solution, after taking it to the canon AFS, vut you gotta do what you have to after trying everything yourself.
    Thanks, everyone, for any responses, recommendations, clarifications.
    Lin
    President:
  • 2,306 Answers
Over on the right is not waste ink pads, waste ink is under the print engine covering the whole bottom of the printer. On the right is the purge assembly and there is ink on the filters on top and on the squeegee that wipes the printhead. You may need a new purge assembly, or just re attach a hose in the purge unit that may have come off. That printer is well worth the repair...
Posted on Sep 10, 2009
Testimonial: "FINALLY,some1!Bit short on techsteps,4 nubees,Solves some issues to try own/prof repairs,or abandon? Worth trying to fixi9900 opinion is helpful."
1 have the same problem & i waste money on
two printhead new inks and the b.s. cleaner
my solution is
stay away from canon printers
Posted on Oct 23, 2009
Problem with fake ink replacement
you will have to get 4x new color chips. and replace it on the cartrdges
Sep 11, 2012 | HP LaserJet 2700n Printer
My Brother LC61, bought in Nov.2010, won't print black. Recently replaced black ink along with all color inks...replaced black ink again when it quit printing...still won't work. Machine whirs...
This is common problem with Brother Printers. I am going to assume you are using Non-Brother branded ink cartridges. Brother cartridges have a cleanser in the ink that most generic cartridges don't have. This in turn causes the jets to clog and not allow ink to pass through them. The fix is to go buy a couple of Brother cartridges and do a cleaning with those cartridges. You may spend some money doing this as a cleaning wastes a lot of ink, but it will clean the injection lines and fix the printer. You could also consider buying a new printer. I know this is not the answer you were looking for, but it is the true answer. I just bought a new printer due to this fact.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Brother Multi-Function Center MFC-240C...
What ink cartridge do i need for my x2500?
You can order the cartridges from
http://www.4inkjets.com/Lexmark-X2500-printer-ink-cartridges-toner
You can get either aftermarket cartridges or OEM.
Please rate this solution. Thanks.
Dec 12, 2010 | Lexmark X2500 All-In-One Printer
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
Kodak ESP 3 doesn't print black ink!
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Had paper jam. Followed instructions to release
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
Don
Dec 12, 2009 | HP Photosmart C6280 Printer
I have a Canon BJC 210. Colors reversed, won't print black
take the cartridges back and stick to official ones. Remanufactured cartridges tend to be more trouble than they are worth and cost more in the long run fixing the errors they cause.
Get a refund as they are faulty and buy some Canon ones :D
Nov 25, 2009 | Computers & Internet
Won't rege ink
how to reset ink cartridge for epson stylus cx6400 I have 2 sets of cartridges half full of ink and it will not print it just keeps saying out of magenta
May 16, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Ink for Dell Photo924 Printer
Here is a site that has refurbished, guaranteed ink for your printer:
http://www.4inkjets.com/Dell-Ink,Photo-all-in-one,924,Ink-Cartridge,2344,printer.html
Refurbished Alternatives for Dell 924 Ink Cartridges and Printing Supplies Our Alternative Remanufactured Cartridges to replace the Dell OEM cartridges for use in the Dell 924 have a one year 100% quality satisfaction guarantee. These cartridges are not refurbished Dell OEM Cartridges. They are Non-OEM products that have been modified and refurbished by a remanufacturer that is not endorsed or associated with Dell and are guaranteed by 4inkjets.com to work with your Dell 924 Printer. They are a low priced alternative to Dell OEM Cartridges. Our refurbished alternative cartridges to the OEM Inkjet Cartridges are manufactured to the highest performance and quality standards and will deliver optimal prints when used in your Dell 924. Since we import our products directly from the remanufacturers we can pass the savings on to you. copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 28, 2008 | Dell 924 All-in-One InkJet Printer
Canon i9900 InkJet Photo Printer Logo
552 people viewed this question
old marine
old marine
