Question about Whirlpool Duet GHW9150P Front Load Washer
Washer will not move through cycles automatically
    Brigadier General:
  • 3,513 Answers
Thank You for contacting Fixya.com
The problem is a defective water control valve. This is the only thing that will cause the water to continue to run when your washer is turned off. It most likely has particles that were dislodged when you were cleaning the hose and they are keeping the valve from closing. Replace the valve and you will have no more problems with the water running all the time.
Have a nice day.
GodBlessU
Posted on Sep 10, 2009
My washer will not switch from one cycle to the next
I understand that your washer is not advancing and stuck on one cycle. If you provide a Model and serial number, it will be helpful.
Jul 22, 2016 | Washing Machines
Why wont my kenmore elite sm9711034 wont cycle automatically?
This is almost always caused by a bad time. The solution is to replace the timer. What happens is the timer has a small motor on it that turns the timer, if the motor burns out or the timer gears wear the timer doesn't advance like it should.
Jul 01, 2014 | Kenmore 24032\24036 Top Load Washer
Washer when set turns on and fills and agitates. But will not move to next cycle automatically. I can manually move the dial to rinse / spin and it works properly. But again won't move to final spin...
From the way you discribe it, sounds like you have a bad timer.If you decide to fix it yourself be sure to mark the wires before removing the timer.
Apr 06, 2011 | GE Washing Machines
Washer does not move to next cycle; does not turn off automatically
MY GE WASHER CONTINUALLY WASHES AND DOES NOT DO ANY OTHER CYCLE OF THE WASH IS THE PROBLEM MY TIMER IS MESSED UP??
Sep 25, 2009 | General Electric Clothes Washer Timer -...
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
Machine won't move thru cycles automatically
Looks like the timer needs replacing.
It would be advised to contact a serviceman to confirm this is the case.
Hope this helps!?
Jun 19, 2009 | Kenmore 22642 Top Load Washer
The washer will not move forward automatically. I
it may be the timer or the heater has gone faulty in which it will not advance the timer from the stats. is it heating ? if not theres your answer, if so it may be the stat or the timer itself.
Mar 16, 2009 | Washing Machines
Timer stuck on cycle will work if manually moved
The timer has a small motor that advances it through the cycles. It either works or it's DOA. unfortunately you probably have to replace the timer complete.
Nov 01, 2007 | Roper RAS8445KQ Top Load Washer
Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Oct 30, 2006 | Kenmore 15944 Top Load Washer
Washine Machine
-Sounds like the timer is out. Check it out and replace it
Good luck
Mai
May 16, 2017 | Kenmore 22642 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal De
