Question about Sanyo Microwave Ovens
Sanyo Microwave EM-G4775
During cooking it suddenly stopped & nothing worked. However later it seemed to be ok, diagnosed overheated & was ok for a while when cooled down. However, last night although it appeared to be working it didn't actually heat anything that was put in it. I have cleaned all vents etc but still the same problem. However I think it may be retaining a memory from yesterday when it first stopped working - there is a symbol 1s showing sometimes, which I have discovered stands for First Stage on the Memory Cook facility - which I have never used before. How do I get rid of it? The only instructions in the manual state:
'When programming the oven to cook by time, use the MEMORY button when setting both the 1st and 2nd stage. The respective lights will come on to indicate which stage the oven is operating in.' -
Doesn't say HOW to actually programme or de-programme the memory cook facility.
MicrowaveSvc
  • 9098 Answers
SOURCE: LG 1925 Microwave suddenly stopped cooking, other functions work fine!
What you said about the the clock leads me to suggest that you first unplug it for a few minutes then plug it back in. It may just need a good reset. If you don't have your owner's manual you can download one here: http://www.lge.com/support/manual.jsp The mention of odor concerns me. It may just be a bit of food or grease on the waveguide cover, which is a small sheet or panel on the wall or ceiling of the cooking cavity, but it may indicate the failure of a part in the high voltage section. You may have an intermittent door switch. You can see some of my other responses for info on how to get our important text file that helps you diagnose and repair door switches and gives important safety tips.
Posted on Dec 11, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Sanyo Microwave EM-G4775 - doesn't heat up......
It's probably a loose connection at the magnetron or a bad magnetron.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Some manufacturers (in the US anyway) will send you the magnetron to do it yourself. If nothing else, you can save about $75US by taking it to the shop yourself.
Apparently you're in the UK, judging by the model number.
You can find Sanyo UK microwave owner's manuals here.
You can find Sanyo UK support, parts and authorized servicers here.
Posted on Oct 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: How to changee clock on
You can find several models of Sanyo microwave manuals here. Even though yours may not be there, there might be one close enough to help you here.
You can locate Sanyo manuals, part distributors and authorized servicers here.
Posted on Nov 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: oven won't heat and shuts down after approx. 20 seconds
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Dec 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
How do I use power feature?
Sanyo EM-S5002W Instruction Manual & Cooking Manual
www.manualslib.com > ... > Instruction manual & cooking manual
Sanyo EM-S5002W Manual Online: Control Panel And Features. OPERATION (1) ...Sanyo instruction manual microwave oven em-s5002w. Hide thumbs ... cooking. (4)POWER LEVEL. Use to set power levels other than. 100%. (5) KITCHEN ...
Oct 09, 2015 | Sanyo Microwave Ovens
Maytag microwave suddenly stopped working, overheated, nothing was cooking.
It is more than likely the magnetron is fried, to replace fuse! unplug microwave oven, remove top, "several screws" look to the right to the keypad control board, look down to a printed circuit board, clipped fuse should be near by, pop it out and replace with same current rating, assemble before testing, "lethal voltages present"
Apr 22, 2012 | Maytag MMV4205 Microwave Oven
How to preheat my new microwave model EM-C5796V of sanyo
you really don't pre-heat a microwave. set it for the time you want to cook and it reaches the temperature for cooking almost instantly
Sep 27, 2010 | Sanyo EM-Z2100GS Microwave Oven
Replace fuse in sanyo em-z2000s microwave onen
try replacing the fuse.there might just be a voltage fluctuation in your locality
Mar 16, 2009 | Sanyo EM-Z2000S Microwave Oven
How to changee clock on a Sanyo EM G4775 Microwave ?
Nov 01, 2008 | Sanyo Microwave Ovens
Oct 12, 2008 | Magic Chef CMV1000B Microwave Oven
Micro wave does not work EM-Z2100GS
First you check the fuse at the out put of highvoltage of the transformer. If the fuse is ok, replace the magnetron.
Feb 28, 2008 | Sanyo EM-Z2100GS Microwave Oven
Microwave runs when door open
This is probably a a bad door switch or door switch mount. Chances are only the fan and light are running when you open it, but better safe than sorry. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure but not the only one. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files by searching at Yahoo.com (not Google) for this: microwave display safety.txt If you still have a problem, please write back with more detail. Be safe!
Nov 20, 2006 | Sanyo EM-P790 Microwave Oven
Microwave Ovens Logo
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
