Question about Oster 76076-010 Hair Trimmer
I don't know how or where to apply grease to my oster classic 76
My clippers start to heat up after only one haircut.
  • 448 Answers
The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). If you don’t have a tube of oster grease, a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear and teeth of bakelite gear). Also, the bakelite gear shaft has a hole down its middle and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The small pads on each side of the lever (in the case) are oiled, not greased.
Oster clippers, by the way, are known for getting pretty warm. Oster blade wash will help with that, as well as oiling the blades.
Hope this helps you.
Posted on Oct 11, 2009
  • carlagregory Aug 29, 2010
    This was very helpful, but maybe someone can video step by step on how to oil and grease the Oster clippper.
  • 193 Answers
Try lubricating your blades. Grease should be applied to the gears underneath the name plate.
Posted on Sep 11, 2009
Classic oster outlaw clipper manual how do u clean grease the gears and oil the blades? how do I properly maintenance my clippers because they are getting real hot way to fast.
normal for clippers if the hair is long or thick
oiling is done with the clipper running
Change over from steel clipper blades to ceramic blades as they run cooler and stay sharper for longer
just place a small drop on the blades and let it work down
AS for others
make sure that the filter in the handle is clear of hair and the same for the vent under the hand
Other than that you can take out the 4 screws and put a small amout of oster grease around the wheel and drive pinion as it can get out and run dry
go to the manufacturing web page and download the pdf version manual
Mar 13, 2018 | Oster Health & Beauty
Tip
When should you change the grease on your Oster A5 or 76 clipper
Oster A5 or 76 clipper need to be grease at lease every 4 month so they can run quiet and cool. when changing and removing the grease, You need to remove the old grease completely, or You are doing more harm than good. By doing this on a routine base, You are saving wear and tear on your gear,lever,link and blades. and the clipper motor will run cooler.
on Mar 30, 2010 | Kitchen Appliances - Others
Want to use plastic attachment. What blade do I need to use with theses?
Oster 76 clippers can be used with a variety of blade sizes and combs. shaveroutlet.com has many in stock. When using comb attachments, you should use one of the following size blades; 000, 0000, 1, 10, 15, 30
ShaverOutlet com Search results for oster 76
Feb 25, 2016 | Oster Classic 76 Clipper w/ Detachable...
What blade do I use with attachments?
In general, Oster 76 clipper combs are compatible with blade sizes 10, 15, 30, 00000, 0000, 000, 1. Many are available at shaveroutlet.com
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
The metal blade fell off my O classic 76 shaver, how can i put it back on? it is the metal changing part
The part that holds the blades on came loose on my Classic 76 clipper. It turns out that the two holes for the inserts are too big. I fixed the problem by removing the inserts from the clipper body (easy since that is the problem), cleaned the inserts and holes in the clipper body and super glued the inserts back into the holes. Be careful not to use too much glue! It only takes a little.
Oct 31, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
Lubricating motor
Here is schematic for repair and service. This is the A5, it is the animal version of the Classic 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
and if u need parts see the link below for schematic and parts list for the 76.
http://www.clipperrepair.com/parts.htm?mid=106
Feb 01, 2009 | Oster 76076-010 Hair Trimmer
Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
Jan 10, 2009 | Oster 76076-010 Hair Trimmer
Oster 76 clippers
Here is schematic and instructions for service and repair. The model in the picture is the A5 however it is the animal version of the classic 76.
Oct 10, 2008 | Oster 76076-010 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
948 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
