Question about Jenn-Air JFC2089HT Bottom Freezer French Door Refrigerator
Where is the water filter located on the Samsung SRS2028CSS
The light is on indicating the water filter needs replacing but the user manual does not explain where it is located.
    Sniper:
  • 88 Answers
The water filter is located in the
upper right-hand corner of the fresh
food compartment.
1. Remove blue bypass cap and
retain for later use.
2. Remove sealing label from end
of filter and insert into filter head.
3. Rotate gently clockwise until
filter stops. Snap filter cover
closed.
4. Reduce water spurts by
flushing air from system.
Run water continuously for
two minutes through
dispenser until water runs steady. During initial
use, allow about a one- to two-minute delay in
water dispersal to allow internal water tank to fill.
Posted on Sep 10, 2009
I've changed the water filter on my samsung RS7667FHCB and the red filter is still showing, is there something you need to do to reset it?
Do you mean the RS7667FHCBC? To reset the water filter schedule indicator, press and hold the Ice Type button (bottom center of the touch panel) for 3+ seconds. This is described on page 24 and on page 33 of the user manual. If the indicator doesn't respond, you may need to change the position of your finger so that you press on the contact point of the touch pad. Sometimes, it takes a few tries to get a response from the press and hold action. The manual for this Samsung refrigerator is available from the support page: http://www.samsung.com/uk/support/model/RS7667FHCBC/EU/ . Select the Downloads & Manuals tab then scroll down. Expand the section with the View More link. The current direct link to the User Manual is http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_UK&CttFileID=5269131&CDCttType=UM&ModelType=N&ModelName=RS7667FHCBC&VPath=UM/201402/20140225093615091/DA68-02710A_VER0.5.pdf .
I hope this helps.
Sep 17, 2016 | Samsung Refrigerators
Red light
Try firsd doing a complete defrost, leave fridge unplugged at least 24 hours
May 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
SRS580DW Water filter indicator red light is on. Where in the fridge do I find it to take it out to replace pleace?
Resetting the water filter indicator light can also be found in the user manual for your SRS580DW Refrigerator User Manual page 8 The water filter indicator initially lights up green. Press the ICE TIMER and ICE MODE buttons at the same time for about three seconds to reset the water filter installation date. • The green light changes to orange after five months to indicate that you should soon change the water filter. It changes to red after an additional one month (six months after the water filter was changed or installed) to indicate that you must change the water filter. • If you wish to turn off the filter indicator lamp or the filter is not connected, press the ice timer & ice mode button simultaneously for 5 seconds. If you wish to turn on the filter indicator lamp again, press the ice timer & ice mode button simultaneously for 3 seconds. Click Here for the SRS580DW User Manual I am here should you have questions Thanks Sea Breeze
Jun 03, 2013 | Refrigerators
I changed the water filter on our rs2545sh e and i need to know how to get the red light out on the panel.
1) Filter Indicator
1-1)This indicator initially lights in green. The light color will be changed to orange after 5 month operation then to red
at the 6th month. The EEPROM in the control board counts a period of time regardless of a power failure.
1-2)To reset the counter and the light color, press Ice Type button and Child lock button for 3 seconds simultaneously.
1-3)If these two buttons are pressed simultaneously for 5 seconds, this function will cease.
1-4)To restore this function, press these buttons again for 3 seconds.
I was able to locate this information in the RS2534WW Service Manual. Samsung does mention this in the their user manual. I have no idea why. Anyway if this has been helpful please rate my solution. I will be here if you have any more questions, Thanks Sea Breeze
Oct 11, 2011 | Samsung RS2534 Side by Side Refrigerator
After i change the water filter de button of water still red
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
Jul 29, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Where is the water filter located and how do i replace it.
The water filter is located in the fresh food or fridge side of the appliance, at the rear - in the upper right hand corner.
To change the filter, open the fridge door, clear the top shelf and grasp the filter. All that is needed is to turn the filter to the left about a 1/4 turn for it to drop down. A few drops of water may spill onto the shelf. To install a replacement, remove the protective cover (shown as a red cap above), and position under opening for filter. Gently push upward while turning the filter to the right. The filter will pop in, and as you turn about 1/4 of the way around, it will be drawn up a small amount until seated. At this point it will no longer turn any further.
More info about the filter is below (taken from the manual).
Please rate this reply - thanks!
The water "Filter Indicator" light
• "Filter Indicator" light lets you know when it is time to change your water filter cartridge. The light
will change from green to orange. This tells you that it is almost time to change the current cartridge.
It is recommended that you replace the cartridge when the light changes to red. (see "Install the water filter" section for more information)
• If you install water filter, throw away the first six glassfulls of water filter, or until water flows clearly to flush impurities in the water supply system.
Using the dispenser without the water filter
• You can not use the water and ice dispenser without a water filter cartridge because the water line
blocks at water supply.
Ordering replacement filters
• To order more water filter cartridges, call 1-800-SAMSUNG and ask for accessory Part # DA29-
00003A or contact your authorized Samsung dealer.
Jan 04, 2011 | Samsung RS265LABP Side by Side...
We changed the filter on the icemaker but tye light is still on asking for a filter. now what makes the light go out?
The light stays on, actually. RF265/6/7 models have a blue LED water filter indicator that remains lit in normal mode. After about 5 months [on a 300 gal. filter] the LED indicator will turn pink and then red at about 6 months. Derived from RF266 users manual, hope this helps.
Oct 07, 2010 | Samsung RF265AA Bottom Freezer French Door...
Water filter indicator light
On my samsung I needed to press the ice timer and ice mode together for 3 seconds.
Sep 30, 2007 | Samsung RS2630SH Side by Side Refrigerator
Jenn-Air JFC2089HT Bottom Freezer French Door Refrigerator Logo
268 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
