Question about Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV
Where can I find a replacement cooling fan? Cooling fan is very loud from the time the set is turned on until a few mins. after it is shut off. Are they hard to replace?
  • 491 Answers
The best replacement is a good flowing computer fan....new or used.
The "used" can be had for almost nothing and they last longer than the factory TV fan.......check computer repair shops,they will have a large pile of good used fans of all sizes.
Posted on Sep 10, 2009
My sharp R409Y*A microwave overheats after 4 min every time and shuts itself off for a few min. It will turn itself back on, but if I use it right away, it will shut itself off again quicker.
I would say your cooling ran is not running, or your vent holes are blocked, or (if equipped) a filter is blocked.
Without the cooling fan, the magnetron overheats and its TCO (thermostat) shuts down all power to the oven until it cools back down to a safe temperature, then power is restored.
Feel free to e-Mail me at pupista@gmail.com if you need more free advice.
Sep 19, 2016 | Sharp Microwave Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Need to know why a 97 mercury cougar won't start until cooling fan and fuel pump stop running
I would think it's a problem with (CCRM) constant control relay module . This module has relay's inside that control the fuel pump , cooling fans , A/C compressor clutch , PCM - engine computer power relay . And thier are electronics involved , solid state circuity . Google CCRM
found this helpful answer from mercury mechanic on JustAnswer com
May 07, 2017 | 1997 Mercury Cougar XR7
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Microwave works, but not the fan. Then shuts off
The internal cooling fan (blower) is faulty and will need replacing.
Dec 28, 2009 | RCA RMW729 Microwave Oven
Over heat cooling fan load noise remove and replace
A bearing more than likely has went bad causing your fan to stop properly cooling your unit. Replace with a compatible fan and you should be all set. Hope this helps.
Jun 03, 2009 | Sony Computers & Internet
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Loud buzzing noise
Yes,it sounds like the color wheel motor is going,and yes it satais on untill lamp cools down
Oct 13, 2007 | Toshiba 62HM95 62" HDTV
Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV Logo
238 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
