I have a 1080p and hdmi cables but still shows it in 1080i
  • 556 Answers
If it is not being broadcast in 1080p you cannot pick it up in 1080p no matter what the cable you have also if this is a Mitsubishi the only input that receives 1080p is the rf(cable) input.
Posted on Sep 10, 2009
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
Tip
What is 1080i and 1080p what cable and HDMI version do I need
So you've got your new Flat Panel Plasma TV and Blu Ray DVD player what cable should you use, am I really 1080p HD Ready ?
So here it is in laymans terms
HDMI
stands for High-Definition Multimedia Interface. It's a digital interface to get the best, uncompressed digital picture possible.There are currently five versions that are setup as improvement on the last since its introduction in 2003
The first high defintion TV's were classed as HD Ready only the resolutions were set at 1280x720= 921,600 just under a MegaPixel per frame and were called 720p and are capable of viewing only 1080i signals with the correct cable the latest version is called HD Ready 1080p the HDMI standard for this is HDMI 1.3 which means that unless you have a TV that is rated for HDMI 1.3 your 1080p Blu Ray player wont work in full 1080p there will be no picture and the players HDMI output will have to be reduced to 1080i this can be done in the Blu Ray Players settings so you can still watch the video on your older HD Ready television
1080i vs 1080p - Basically both formats have the same number of Pixels 1920 across the top and 1080 across the side this gives a total number of pixels (1920x1080=2,073,600) aka 2 MegaPixels per frame assuming that the aspect ratio is 16:9 this is the same as a basic digital camera or phone jpeg.
You might also see written like this 1080p24 means that it originated from a progressive scanned 24 frames source and has become an established production standard Cimena and for your Blu Ray player will also have this setting if you require it.
When Compared to standard DVD with and aspect ratio of 4:3 which has 720x576=414,720 this is an increase of 500% in the resolution alone over the now humbled DVD Video format with interlaced video
The difference between the two is that one is interlaced (like normal DVD-Video) and the other is progressive OR non-interlaced scan which means that 1080p requires way more transfer speed than that of the 1080i format.
So the main disadvantage of progressive scan is that it requires higher bandwidth than interlaced video that has the same frame size and vertical refresh rate this is why DVD-Videos incorporate the interaced video due to the lack of a digital inteface like HDMI 1.3 rated cable is required to transfer this higher speed of transmission in contrast the 1080i signal requires a much slower speed and HDMI 1.2 rated cable might work.
As far as interconnects go you can still connect your full 1080p Blu Ray Player to your 1080i Plasma TV using the three cable interconnect that comes with the players but for the best possible connection you need to use a HDMI cable with gold plated connecitons. Prices range from £15 right upto £60 and beyond if you go with Monster Cables however the £15 version if it says rated for Blu Ray it will work just fine so save yourself £40.
HD Ready
HDMI 1.0 - combines a digital video signal (standard or HD) with a two-channel audio signal over a single cable used with the HD Ready
HDMI 1.1 - This version adds the ability to transfer not only video and two-channel audio over a single cable, but also added the ability to transfer Dolby Digital, DTS, and DVD-Audio surround signals, as well up to 7.1 channels of PCM audio.
HDMI 1.2 - This version adds the ability to transfer Super Audio CD signals in digital form from a player to a receiver most Home Theatre Systems require at least this type of cable for full capabilty however you can use a v1.3a cable works just as well
HD Ready 1080p
HDMI 1.3 and HDMI 1.3a These versions include improvements in both audio and video capability. With the advent of Blu-ray Disc it adds the ability to transfer the digital bitstreams for the new high resolution audio formats in addition to the standard 24-bit color depth we are used to, HDMI 1.3a has the ability to transfer color depths up to 48-bits, and can accommodate resolutions much higher than the 1080p resolution standard that is in use today on all TVs that are HD Ready 1080p
HDMI 1.4 and HDMI 1.4a HDMI version 1.4 adds practical enhancements for HDMI connectivity. If home theater components, such as HDTVs, Blu-ray Disc players, and Home Theater Receiver, the next step in HDMI of the future is covered by the v1.4a cables wrt to speed.
on Apr 15, 2010 | LG 47 in. Flat-Panel LCD HDTV
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Televison & Video
Ps3 only displays in 1080i
I have similar problem , ps3 320gb + 5 years old sony bravia 1080p = everything OK
but when i connect ps3 to new samsung ue46d7000 1080p = doesn't work (only 1080i)
I am using same HDMI cable
Jun 19, 2012 | Sony Playstation 3 (PS3) Console
So i was messing with the display resolution, it was working fine before i started messing with it... i changed the resolution from 1080i with component cables... to 1080p. I lost the picture unti i...
1080i only works with component cables and wont go to 1080p but your hdmi will set it back to 1080i and then switch back to the component cables.
Jan 03, 2011 | Microsoft Xbox 360 Console
My tv only shows 720p and i am not sure how to adjust it to 1080p ={
You have to adjust the settings on whatever is connected to your television. If you have a bluray player connected to your television with an hdmi cable you should be able to receive 1080p but you have to set the bluray player to 1080i. The tv picks up the signal automatically. From your cable box or satellite tv box you cannot get any more than 1080i from television programs at this time. You can get 1080p from bluray on demand. In certain circumstances you can get 1080p over component cables as well as an hdmi cable but in most cases you will only get 1080i. Once again you have to set your connected device to 1080 to get it on your tv
May 06, 2010 | Insignia 42" LCD Flat-Panel HDTV
How do I get from 480 to 1080p on my tv? I have an HD box on my vizio 42 inch tv but my channels are still showing 480?
1080P is a quality you'll only get with a blue ray quality video. Therefore, you won't get 1080P on cable tv. If your cable provider has HD channels available, you'll be able to get 720 or 1080i quality video (on those channels only). For the best quality, make sure you are using an HDMI cable. Just be sure your cable box supports an HDMI output. Your Vizio definately supports that type of input. If you have a PS3 or alternative blue ray player, you'll be able to watch 1080P.
Sep 12, 2009 | Vizio Televison & Video
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
HDMI Monster cables
I had the same issue. I think you have to reset your PS3. I don't remember how I fixed it but I did find the anwser in the PS3 user manual "Trouble Shooting".
Dec 27, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
My tv shows its's geting 1080i only
1080p signal... THE MITSU. WD-65731 has a resolution of 1080p its just the res your PS3 is pumping into your screen is loaded with a little bit more pixels than you 1080p res MITSU. I suggest getting a MITSU WD-57731 since it has a 1080P/24 input. and has great clarity and HD ample for the BD of your PS3. however the differences in picture rate and quality is very small. goodluck.
Sep 22, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
