MY VIRTUAL MEMORY IS LOW
WHAT DO I DO TO IMPROVE THE VIRTUAL MEMORY ON MY DESK TOP SINCE IT IS LOW?
    Novelist:
  • 110 Answers
Virtual Memory by default should be 1.5 x your actual memory installed. to make it larger you can increase your overall memory....
OR just right-click on My Computer, and select Properties. It will open a window called 'System Properties'. Click on the fourth tab on the top called 'Advanced'. Click on 'Settings'. It will open a new window called 'Performance Options'. Click on the second tab called 'Advanced'. On the bottom right there is a button called 'Change'. Click it, it opens a new window called 'Virtual Memory'. You will see three buttons called 'Custom size', 'system managed size', and 'no page file'.
If it is on system managed write down the number it has.. then choose the button 'Custom Size' and make it a bit more, like 2048 initial and 2048 maximum. If it is on custom size already, just increase the number by multiples of 512..... like 512, 1024, 1536, 2048, ect.
Good Luck
Posted on Sep 10, 2009
  • 1,511 Answers
Right Click My Computer > Properties > Advanced Tab > In Performance Panel, Click Settings > Then Advanced Tab (In the New Dialog-Box, that appears) > At the End you will see Virtual Memory Panel > Change/Increase it Accordingly.
I Hope this Solves your Query, This was for Win Xp, if you got some other Operating System, do tell me.
If I was helpful, Kindly do Rate! Regards, Waqar.
My computer runs slow. It takes a long time to boot up. Occasionally I get a message that virtual memory is low. Is there something I can do myself?
Hello
Yes, this is a very common problem for computers which does not have the sufficient amount of ram installed for the software the machine runs.
At the link below you will be able to read a couple of tips on how to improve your computer speed.
Click HERE.
Kind regards
Andrea
Sep 19, 2010 | Dell Microsoft Windows XP Home Edition
CAN YOU PLEASE TELL ME HOW MUCH VIRTUAL MEMORY DOES A PATRIOT 2006 LAPTOP HAVE
Virtual memory?
Virtual memory is created and used by windows operating system.
This value can be changed and solely depends on the hard drive space available.
Simply put There isnt any limit, nor a minimum. The amount of virtual memory depends on how much was set up and can be increased or decreased at any time.
The purpose of virtual memory is to allow windows to use part of your hard drive as rams.
virtual memory and rams (conventional memory are different things)
you can have as much or as little as u need. increasing it improves performance.
So No one can actually answer that question. Simply put any amount you want is the correct answer!.
Mar 01, 2010 | Computers & Internet
"Virtual Memory Low" error message on IBM Thinkpad T30
Right-click on "My Computer", goto "Properties".
Click the "Advanced" tab, and click the "Settings" button under Performance.
You will see Virtual Memory under there. Click the "Change" button, and switch to "Custom size".
Initial size: 500
Maximum size: 2096
Click the "Set" button, close everything out and restart the computer. You should notice a difference. If you have any questions, please feel free to comment! Please don't forget to vote! Happy Thanksgiving!
Nov 25, 2009 | IBM ThinkPad A31 Notebook
System says low on virtual memory even after I zero & format the hard drive with new operating installed?
this is virus instaled on computer bios or defective memory boards.
1st replace memory, and check-it.
2nd find a original bios on IBM website, and flash-it.
Nov 22, 2009 | IBM NetVista PC Desktop
Virtual memory is low computer is very slow
hello frnd, you can increse your virtual memory manually...
1.go to properties of my computer
2.go to advance tab...
3. there is option to change virtual memory.
4.click on it and change virtual memory accordingly..
hope this will help you
Jun 30, 2009 | Dell Dimension 2400 PC Desktop
Low virtual memory problem
your computer has used up its physical memory (RAM) and is currently utilizing and eating up hard drive space. A computer designates a certain amout of "FAKE" or wat they call virtual memory from the hard drive and when that is taken up it shows low virtual memory. Simply put this just means you need to increase the amount of ram on the computer :)
Mar 22, 2009 | Dell Dimension 2400 PC Desktop
Low virtual memory
You have to increase the Virtual memory.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Dell Inspiron 1300 Notebook
Windows-virtual memory minimum too low
Not Necessarily Not Enough Drive Its Your Virtual Memory May Just Be Set Low. Go To Your Start Menu And Right Click On It Scroll Down To Properties and Click It. Then Once The Prompt Box Pops Up Select The Advanced Tab. Your Gonna Wanna Locate The Performance Settings Button And Click It. Now Select The Advanced Tab And Go Down To Where It Says Virtual Memory, Click Change Up The Number Mines At 384 top and 1500 bottom. Now Click Set After Changing The Numbers And Select Ok,Ok,Ok On All Three Tabs. This Will Do It
Jan 14, 2009 | Maxtor One Touch II (EO1E200) 200 GB Hard...
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Running low i vitual memory
go to control panel, then system. Click the performance tab at top of screen, you will see virtual memory at the bottom, increase the amount to solve you problem. Good Luck
Sep 15, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
