Question about Cell Phones
LG GC900. Software update failure
I have a problem with a LG GC900.
During software update, usb lead disconnected from phone.
Now my PC wont recognise phone, and phone has "Version Mismatch" message on screen.
How can I continue update ?
My lg k10 2017 phone does not want to transfer photo's or music with cable from pc. error message : device has either stopped responding or has been disconnected.
Make sure that usb driver and GMobileSupportTool is installed on your PC.
1. Download Lg Mobile Support Tools using the link below:
http://tool.lime.gdms.lge.com/client/app/LGMobileSupportTool.exe
2. Execute downloaded file. Follow installation instructions. After executing LG Mobile Support Tool in Step2, you can download USB Driver:
img-mobile-support-nsatmeh50lx5u1woeaeqllmn-4-0.gif 3. Connect your phone to PC by using the bundled USB Cable
4. Click start updating
The phone software upgrade stopped before completion?
  1. Don't close the update tool, disconnect the cable and reconnect it. And check the USB Driver connection on our PC. After that, please restart the update.
  2. Otherwise, please select "Customer Support"-"Recovery Phone" in LG MOBILE SUPPORT TOOL. Then, you can start to recover your phone.
Mar 17, 2017 | LG Cell Phones
How can i upgrade my lg gc900 to an android?
  • How to install android on lg gc900 software: Transfer Android SMS to PC or anohter Android, convert video to Android, avi to Android, Recover Android Phone Deleted Image File Easi and more.
Mar 30, 2013 | LG GC900 Cell Phone
How to install software in LG GW525
  1. 1. Before installing the USB Driver, disconnect phone from PC
  2. 2. Please back up all files (through PC Suite etc) before upgrading the phone. LG Electronics will not be held responsible for loss of any data.
  3. 3. Please connect your USB cable directly to the PC (Do not use a USB Hub).
  4. 4. if the phone software upgrade stops before completion, please do not close the update tool and try to update again. If you close the update tool before completion Recovery Phone
    http://www.repair-dll.com/
Dec 07, 2011 | LG GW525 Cell Phone
My samsung sgh m-200 mobile problem 1Chalte Chalte hang ho jata hai.2. auto restart hota rahta hai.plz solv my problems thanks
For this you need to scan your handset and memory from a updated antivirus
if problem persists you need to flash your phone
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps) *Software Updater
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE *Install the "Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank don't forget to rate
Jan 28, 2011 | Samsung Cell Phones
I'm using LG GT505 phone. I got two problems , when I want to take a pictures or even videos, a messages comes out like this ''maximum limit of application reached'' but my mem.card still got full...
For this you need of Flash your handset To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Software updater by selecting this option) *Install the "Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank you
Don't Forget To Rate
Jan 24, 2011 | LG GT505 Cell Phone
GT 400 PC suite - where is it. CD did not come with phone, cant find it on the LG site. Downloaded update software & it doesn't recognise tjhe phone. I'm getting very frustrated**%##&^%$#@
Im having the same problem, ive purchased a gt400 and it didnt come with a instalation disk/pc suite thing. Ive downloaded the update software from Lg website but it seems to have every install usb driver accept for gt400. Does anybody know how i can install the phone/pc suite thing to my computer?
Oct 25, 2010 | Computers & Internet
Software update -N73's firmware
There in nokia software updater they strictily warned for Do not disconnect mobile device from pc while update in progress it will be reposible for damage to phone.
Now you must have to contact nokia care & re-Install phone software.
Thanks.
Oct 14, 2009 | Nokia Cell Phones
I WANT TO UPDATE MY LG KF600 MOBILE INTERNAL SOFTWARE UPDATE WHAT SHOULD I DO AS THE OLDER ONE IS POWER CONSUMING ALSO NOT INSTALLING INTERNAE SETTINGS SAYING MEMORY IS FULL, i have reset my phone many...
connect the phone to your PC. and open the phone software and then find a option inside that to update your phone software. generally all the phone softwares have it. while doing that make sure you dont disconnect the phone during installation.
Aug 03, 2009 | LG KF600 3MP InteractPad Triband Phone...
N73 start up problem
Your phone needs to be reprogrammed, only a repair shop can do this for you.
You need to download the latest Nokia PC Suite to do an update on your phone.
Before updating software you should check that there’s a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
May 05, 2008 | Nokia N73 Cellular Phone
Software Upgrade
install the cd that came with the phone, once that is done and you have connect you phone via usb cable to the pc, switch on the phone then when the pc has located and recognised your phone go to the update column and the pc will search nokia site for a new upgrade.
Dec 11, 2007 | Nokia N70 Cellular Phone
Cell Phones Logo
559 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
