Question about Dell 962 Photo All-In-One InkJet Printer
Scanning high Quality images
When I try to scan an image in 2400 dots pr inch resolution, it won't work. I get an error msg. Increase Virtual memory or increase RAM or decrease image size. The latter is of course out of the question. I've got 2 gb of ram and the virtual mem size is now increased to 16368 MB. So does anyone know what the problem is. Scanning in 1200 resolution is ok.
  • thoge Dec 22, 2007
    1. Windows XP
    2. It's possible to scan a smaller portion of the image, but that would take a lot of time. It' seems that the scan limit for image size is a little under 300MB(working size). Of course when I save the image it will only be 2MB.
    3. What I was hoping for was a solution that does not require me to scan the image in smaller parts and assemble them together in an editing program afterwards. I'm lazy.
Two questions for you to help with a solution:
1. What operating system are you using?
2. Are you able to scan an image of any size (even a postage stamp size) at 2400 dpi? (Try setting the scanner to just scan a small section of a larger image as a test for this.)
If you can scan smaller size images at 2400 dpi then it is possible to scan the image in two (or more) parts (upper half / lower half) and then re-assemble the image in an editing program.
Posted on Dec 19, 2007
  • Anonymous Dec 22, 2007
    What program are you scanning with? Is it possible to upgrade that program to a newer version? Also make sure you're using the latest drivers from Dell for this All-in-One unit.
    Following your math I too calculate that a 4x5 inch picture will take 325 MB of raw memory to scan, assuming 24 bits per pixel.
    Recall that some programs keep one (and sometimes two) copies of the image in RAM to aid in Undo features, so you could be stretching up to a gigabyte of RAM required.
    I'm beginning to suspect that this is a limitation in your software, not necessarily a hardware problem. A lazy programmer could have put in a check for scanning images at 2400 dpi at this size and just decided to not support it.
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
Text being scanned does not produce a clear print to our cannon ip18oo printer
alot of the time if you scan something it will streach the image because of the scanner resolution. check you setting on the printer. you might need to change the settings to stop it from doing that to make he image more clear. if that doesn't work than also some printers are just like that when you scan something. it will also make one page turn into two pages. that may just be the way the printer is.
Aug 13, 2008 | HP Office Equipment & Supplies
Tip
LPI, PPI,DPI conversions
Here is a conversion chart for DPI (Dots per inch) to LPI (Lines per inch) or PPI (Pixels per inch)
180 DPI................31 lines/inch or 68 PPI
360 DPI................63 lines/inch or 138 PPI
720 DPI................127 lines/inch or 280 PPI
1440 DPI..............255 lines/inch or 561 PPI
2880 DPI..................510 lines/inch or 1122 PPI
If you plan to enlarge your image, it is better to enlarge it when you're scanning rather than in your application. Each time you modify
an image, you lose some quality. Keep in mind when you enlarge a small photo, such as a 35 mm slide or wallet-size photo, you'll need
to scan at a high enough resolution to retain your image quality, but not so high that your file size is too large to be efficient. You must
manually adjust the resolution (dpi) to maintain the same image quality when you resize your image. For example, if you have a 300
dpi 2 x 2-inch image that you want to enlarge to 4 x 4 (a factor of 200%), increase the Scale setting to 200% or change the resolution to 600 dpi.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
Setting dpi on my nikon d3100
DPI (dots per inch) is an output specification and is irrelevant to the camera. The camera puts a value into the field simply because it has to put something there. The DPI is set by the printing program when it prints a picture. A picture printed at 4x6 will obviously have more dots per inch than the same picture printed at 8x10.
Nov 30, 2012 | Nikon D3100 Digital Camera
How do Print a scanned image
This is a complicated issue. You have to understand the computer term DPI, which stands for Dots Per Inch. This applies in three places:
  1. when you scan, you can set this
  2. when you display it on your monitor, your monitor will be usually 72 DPI or 100DPI depending on what resolution your video driver is set to
  3. when you print, it depends what resolution your printer can print at. Your printer can also stretch the image onto the paper by duplicating dots as needed.
Dots = Pixels
In PixWizard, we show you the image size in Dots.
Let's assume you scan at 300 DPI. You scan an 8x10 picture. This is saved as 2400 dots (8" x 300 dots/inch) by 3000 dots (10" x 300). Let's assume your printer is 600DPI. In dots, this is 4800 (8" x 600) by 6000 (10" x 600). For best results, you should scan at 600DPI and set the print options to use a 1:1 scale when printing. Our programs can also stretch the image to fit the entire printable area of your printer.
May 20, 2011 | Computers & Internet
How to enlarge a picture that is scanned or copied? When i scan or copy a picture it is too small and I want to enlarge it in order to view it better.
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Aug 07, 2010 | HP Officejet 5610 All-In-One InkJet...
They keep telling me that my picture is too big . It is a 4X6 picture on my computer.
More information on exactly what you are trying to do would be helpful... But it sounds like it's a resolution problem. Computer monitors usually display 72 or 96 dpi (Dots Per Inch) Printers usually print out images at 300 or 600 dpi Some newspapers are printed at only 50 dpi Scanners can scan a photo in thousands of dpi...
If your photo is a 4x6 at 300dpi, then when they try to display it in 72dpi, it will display as just a bit larger than a 16x20" image
When you are scanning a photo to email, then make sure that you set your resolution to 72 dpi to display on the screen - or vice versa, if you are going to print something, make sure you scan it at 300dpi
If you have any graphic programs, (Microsoft offers "PowerToys" for Windows XP) you can open the file in that, and usually find a setting for the Image Size that will let you set a new DPI. It's usually ok to lower an image's dpi - but there is a loss of quality anytime you try to add dpi, since you are forcing the computer to "guess" what all those hundreds of dots should look like, and they aren't good at that.
Oct 29, 2009 | Cameras
Scanning files to large
It's the resolution you are using to scan. Try a lower setting. for documents, 150-200 dpi is fine. That will produce smaller files.
Aug 25, 2009 | Dell 922 All-In-One InkJet Printer
Problem saving scanned negatives to laptop. Epson 2400 scanner.
If you are scanning in Color and in high resolution, then the file size will be very big. Try and close other programmes in your Laptop and try. If in color try 150 or 200 dpi option and also select JPG format. Alternatively you can increase your RAM in the laptop. S. Mohan
Nov 13, 2008 | Epson Perfection 2400 Photo Flatbed...
Scanner begins to hang.
Increase the size of the virtual memory or add RAM memory to computer. Check the Technical Support team at Canon also
May 25, 2007 | Canon DR-9080C Path-Through Scanner
Dell 962 Photo All-In-One InkJet Printer Logo
107 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
