Question about Nuvico NVJV-4000N Video Recorder
I notice that there is lan or rj45 connection in the rear of my Nvjv 4000.Does this in any way indicate that the stored video can be view remotly or over the internet?
Yes it does. and you can control up to 99 dvr's and control the settings as well. This model also has a self reconfig feature every time the ip address changes so you don't have to get a static ip address.
Posted on Apr 09, 2010
Nuvico nvjv 4000 beeps and shuts off
sometimes these will go into an automatic sleep mode and will restart once you power it down and restart..
Jan 19, 2014 | Nuvico NVJV-4000N Video Recorder
Remote starter doesn't work when pressed
I think that you answered it yourself. Give you 1 point. The continual is the processor searching but not finding its mate. Replace the battery and repair them.
May 11, 2017 | 5101 LE 1 Way Car Remote Starter System
My notebook NEC versapro VA75h doesn't have lan port and I need to connect with lan jack
You can solve this problem by buying USB to RJ45 Converter like this oneor RJ45 PCMCIA Card like this.Good luck!
Dec 23, 2011 | Computers & Internet
How can I convert the Nuvico NVJV 8000 from NTSC toPAL?
I have the DV3-8000; the service menu can be accessed by holding down keys 1 and 3 simultaneously; there is an option to select either NTSC or PAL; my GUESS is select PAL; don't know if there is more to it than that, but this is a start . . .
Jul 28, 2010 | Nuvico NVJV-4000N Video Recorder
I need to access a remote LAN through the internet. our church office is on verizon DSL with a westell 7500 modem. I have security camera's attached through an Ethernet cable. I need to be able to use...
You need to install a software that will manage your LAN's video recording. That software should work fine within your LAN and is usually provided with the Video Capture Cards where your cameras are connected. This software should have a web portal for you to access via internet utilizing your forwarded port. Thus, you must tell your video software to use your forwarded port for internet viewing. Without this web portal, you can't access your remote LAN videos via internet.
Feb 01, 2010 | Computers & Internet
Need to pull up my web browser in order to configure my router
Not actually, you only need to go to an address line. If you have your address line turned on on folders view, then that is consided a browser. To turn it on, go to any folder view, and click on view, then toolbars, and click on the address bar, and your set.
Thanks
Mark
Sep 17, 2009 | Airlink 802.11G Wireless 4-Port Router...
Compaq presario v3000
Unless you are purchasing an old desktop PC, I am pretty sure any system you purchase these days (whether it's from Dell or whatever) have atleast an integrated LAN Rj45 connection on the motherboard.
The cheapest computer on dell.com (the Inspiron) has an integrated LAN connection for example.
Hope this helps,
Bill
Sep 04, 2009 | Compaq Network adapter
I have a toshiba v000108500 motherboard, when lan cable is plug into RJ45 socket, lan work normally, problem is the yellow LED of RJ45 always on (doesn't matter two computers communicate or not), when two...
If you are not having any reception problems to the internet, worry not.
Normal is solid amber, and when it flashes that is a sign of activity on the line. This is not a indicator of a problem or potential problem.
Again if I understand you correctly the local area network is working normally. If this is not the case please write back.
Hope this helps, please leave rating. Thank you kindly
May 07, 2009 | Computers & Internet
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
Just connected the SWA-4000 wireless amplified to my samsung ht-z310 - the readout on the display is "Rear Chk" there is no sound from the rear speakers- any help is appreciated
swa-4000 wireless module isn't compatible with htz310. You need to buy Samsung's swa-3000 to work with your htz310. I had the same problem. It tells you in your owners manual under conectivity where it explains about hooking up a wireless module(pg.55-60). I hope this helps.
Dec 13, 2008 | Samsung SWA-4000
Nuvico NVJV-4000N Video Recorder Logo
153 people viewed this question
Top Nuvico Televison & Video Experts
Are you a Nuvico Televison and Video Expert? Answer questions, earn points and help others
